Question about Hampton Bay 24002 Ceiling Fan
My ceiling fan has no reverse switch, how do i change the direction
  • 4 Answers
My fan does not have a reverse switch for sure so I scoured the net and got no real answer. I did come accross a comment that said that it worked internally at the remote box in ceiling. Here is how I finally figured it out after about 6 months of searching. Put the fan on high, Turn wall switch OFF, Hold the HI button on remote, Turn switch back on. IT WORKS!!!!!!!!!!!!! Sparq
Posted on Sep 24, 2009
  • 5 more comments
  • rlr7489
    rlr7489 Jul 08, 2012
    Thank you SO much!! It worked for us too!!!! Unbelievable!! =)
  • Debora S Jun 16, 2013
    It worked for me too!! Thanks you sooooo much. I was going crazy trying to figure out how to do that!
  • Capacitor Feb 13, 2016
    Pls I do I change mine, my fan has no remote.
  • Christi Wyckoff
    Christi Wyckoff May 05, 2017
    didn't work for me. :(
  • Jeff Davis
    Jeff Davis Jun 23, 2017
    It worked me but I had to press Medium speed button instead of High.
  • Albert Lim
    Albert Lim Jun 12, 2018
    turn "on" the wall switch, then "press" and "hold" the "high" button on the remote (fan is on high speed), then turn the wall switch "off", then "release" the "high" button on the remote. Then turn "on" the wall switch and then "press" the "high" once on the remote.
  • Richard Henkle
    Richard Henkle Jul 09, 2018
    Worked for my Hampton Bay San Juan fans by following steps as outlined by Albert Lim. Had to press 'high' AFTER turning switch 'on', not before.
  • 19 Answers
SOLVED: I have a Hampton Bay 54" ceiling fan (pewter color with leather coating), and it has no reverse switch either. It was running, but in the opposite direction I wanted. Out of the box it came with a remote wall switch that must be installed in the wall control box, as the fan's speed and reversal is controlled by a relay inside the fan. I haven't found a way to get this relay to "flip" without using the signal from the original remote. They wanted $70 for a new remote, the fan only cost $90~! Fark that!
However, if you lost this switch, there is another mod, if you open up the fan's housing, you'll find Black, White and Blue wires going into a small black box circuit box containing a green board with some capacitors. There is also a separate smaller box containing a small capacitor that says "4.5 uF" with red and white wires leading out of it. There are also four wires: Gray, Pink, Red and Yellow. You can rewire the fan thusly to use either no remote (always on) or use an aftermarket remote this way:
1, Black to Gray and Pink, (twist all 3 together)
2. White to Yellow and "Capacitor >> Red" (to do this, cut and use the white lead that leads to the capactor (leave the red lead connected to the capacitor. Don't cut the red wire.
To reverse direction, just reverse Black and White above. This works, you're in a fixed direction, but you will have speed control if you use one of those aftermarket remotes.
Posted on Sep 04, 2009
If you have the remote control with out reverse bouton, just open the remote control and there is a contact just below the fan on/off bouton. Turn on the fan, use the same keypad to touch that contact with out pad and the fan will reverse. That orphan contact is the reverse bouton. The original remote has that bouton in there and the old one does not have a pad bouton for it but below the plastic there is a contact for it.
Posted on Mar 19, 2018
  • Peter Piotrofski
    Peter Piotrofski Jun 20, 2018
    worked perfectly, thank you. Why would they not put that button in the darn remote??
What if that slide switch is only working in one direction?
Posted on Sep 05, 2012
    Problem Solver:
  • 5 Answers
Some fans come with a wall switch that replaces your light switch and the control is on this. If you can take the dome off the fan and see the wires there will be 4 wires. U can also buy a universal switch if some one tossed it away. If this doesn't work try getting a new fan, I install lots a of cieling fans and these days they all have the switch in plane sight.
Posted on Jul 28, 2009
    Problem Solver:
  • 7 Answers
Think you can wire it wrong and reverse the polarity making go in reverse
Posted on Jul 27, 2009
SOURCE: I have a Casablanca Intelli touch ceiling fan.
My fan operates the same way. To reverse it, turn it on a low speed. Then, turn it off and on, then off and on again, quickly. You should hear a series of beeps, and the blades will slow down and then reverse. You may have to play a bit with the timing of the off/on/off/on sequence to get it right but you should be able to get it fairly easily.
Posted on Sep 01, 2010
  • 4 Answers
SOURCE: Fan won't reverse to counter clockwise
I had a hampton bay fan that absolutely did not have a revers switch on the fan anywhere! MOST fans bought today will reverse. I was not about to give up. I scoured the net for an answer and could not find anything to help. I did however find a comment somewhere that said it could be done internally. After about six months I decided to search again (now). Nothing... so I started playing with the remote and the wall switch and Shazaam! I figured it out on my hampton bay fan. Turn the fan on high... Turn the wall switch off.... wait until the fan is pretty slow in rotation... hold the HI button on the remote.... Turn the switch back on. IT Worked for me! Hope this helps someone. SparqMark
SOURCE: Can't find switch to reverse direction (24002)
I found a pdf of the manual on "KingOfFans.com" and there was a graphic showing the location of the switch. It is on top of the motor underneath the small bulbs in the top section of the fan. It is really rather difficult to get to and not the best design but I found it and it worked.
Posted on Jun 12, 2009
  • 7 Answers
SOURCE: Unable to reverse Thomasville ceiling fan rotation w/remote
Buy a speed control with a reversing switch.
Posted on Jun 29, 2009
red54eyejp
  • 25 Answers
SOURCE: how do you reverse the direction on this model of ceiling fan
SHOULD BE A DIRECTION CHANGING SLIDE SWITCH ON THE MOTER AREA OF THE FAN...
Posted on May 10, 2009
Chief Leun ceiling fan 54-OR somehow changed directions. No reverse switch on fan how do I change it
Every fan has a reverse switch, it is on the barrel of the fan above the blades. small black switch, down is normal up is reverse rotation.
Jul 01, 2017 | Dryers
How do you reverse the fan direction?
Usually, there is a switch on the fan housing to accomplish this.
May 10, 2014 | Progress Lighting P2528-81 Ceiling Fan
Kendal ceiling fan will not reverse direction
Might need new receiver if no reverse switch on fan.
Mar 15, 2013 | Dryers
Hunter ceiling fan 22450 no reverse switch manual says there is.
The reverse switch usually is in the lamp housing directly under the motor. With a vaulted ceiling installation, you would need to use a ladder to get access to the switch
Jan 04, 2013 | Hunter 52" Ceiling Fan With Light And...
Hunter ceiling fan 52 ",
Hey dale. Sounds like either the integrated remote pack inside the fan housing might be bad, or the reversal switch part. If it has a switch on the fan housing to change it from forward and reverse, you could try going to a hardware store and replacing that switch. If that doesn't work, then it is probably a bad remote receiver pack iside the fan, it will be a bigger, probably black little box. If this is the case, your better off getting a new fan, as it will cost about the same. If your fan doesn't have a little switch to change blade direction, 9 out of 10 times it is the receiver pack. If your fan does have a switch for fan direction, there is a good chance it is a bad switch. It could also be both. After 10 years with the fan, you might seriously want to consider purchasing a new fan.
May 17, 2011 | Hunter Ceiling Fan Remote Receiver...
I need to reverse direction of fan
mcdevito75 here, Close to the ceiling but still on the fan motor shroud should be another small pull chain switch, this pull chain switch is the fan reverse switch, the switch may also be a toggle switch but I doubt it. Look close to the other pull chain switch for the fan, for the reverse switch.
Jul 26, 2010 | Hampton Bay 24750 Huntington III Ceiling...
How do I reverse the blades without a remote?
theres a black switch around the fan to change directions , thanks AJ
Jul 14, 2009 | Dryers
Reverse ceiling fan
are you sure theres not a switch on the fan body ,, up/down= summer / winter...There should be
Jul 04, 2009 | Craftmade International (LC52EB) Ceiling...
Reversing direction on remote controlled fan
There is no switch. Put the fan on high then hit the reverse button. Your fan should stop, reverse and you'll bet all set.
Nov 20, 2008 | Hampton Bay 52 In. White Redington...
Hampton Bay 24002 Ceiling Fan Logo
18,086 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
