My cold water just trickles in, is there a filter somewhere? The hot water seems fine. I don't see anything obvious that I can clean...
    President:
  • 1,136 Answers
Hi, Romeve the inlet hose and clean out the screen inside the inlet valve.
This should take care of the problem.
Vic
Posted on Jul 18, 2009
Lg intellowasher wf-t1081tp hot water intake slow.
wich is connecting with inlet hose & inlet valve,,back of the machine,,thre is one filter in side the valve, remove &clean it,,pls
Apr 12, 2014 | LG Washing Machines
Cold water slow to fill
It buzzes because 120 volt AC is within the hearing range and means electricity is trying to open the solenoid plunger.Make sure the faucet the hose is connected to is turned on. swap hot and cold hoses and see if the Hot water is now a trickle. The solenoid asm that the hoses connect to can be removed and dissambled. It's a no brainer. the parts are mirrors of each otherBe sure to unplug the washer first. Remove the hoses at the solenoid assembely the valve asm has wires coming to it that just push on. A loose connector MIGHT cause this problem. Draw a picture of the wire connections, noting the color of each connection.Now the fill solenoid asm can be removed. It's probably held to the cabinet with one screw. now there are some screws holding the coils to the plungers. disassemble the valve and clean it up. Don't lose the springs that push the plunger to the closed position. At this point you could even swap the plungers on the asm. Just clean the obvious lime and **** upp using a tooth brush and water.DON'T LOSE THE SPRINGS,DON'T EVEN WASH THEM. Assembly is just reversed.you should not have to buy any parts, but don't lose the springs.
Nov 30, 2011 | Admiral AW22 Top Load Washer
The cold water fill just trickles, I removed filter it was not clogged, hot water runs fine. I checked water flow at faucet, I checked for kinked hose. Did not find any obvious problem. Is there a check...
Good day,
The washer has a dual valve, Hot and cold. The cold side has failed. Valve needs to be replaced. Very common problem.
Before changing, turn off cold water supply, remove cold water hose at the machines valve, and turn on to check for proper pressure.
Dec 04, 2009 | KitchenAid KAWS850L Top Load Washer
Rinse water barely trickles out of my washer
Do you fill the machine with hot water only?
If so, this is what I suspect. The filters in the inlet hoses on the back of the washer need cleaning. Remove the garden hose connectors, remove filter, clean, replace.
When filling with hot only you get a lot of pressure thru one hose. When you rinse, the best you can do pressure-wise is cold rinse -- but the cold water filter is going to be more clogged than the hot so it delivers less water.
When you use warm rinse, you get mediium pressure thru both lines, again less water than al hot on filling the machine.
Apr 29, 2009 | Washing Machines
Ty for being here. I have a kenmore stack washer dryer. Washer is a model 417.94802 301. The hot water feed work fine comming into the machine. However the cold feed only comes in at a trickle. I...
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 05, 2009 | Washing Machines
Inside the machine you have a valve called inlet.
The inlet water valve will collect the cold and hot water lines, and open alternatively one or the other during cycle.
To access the inlet valve you need to take apart the machine, and that is not an easy task.
If you DIY remember to unplug power, there is high voltage running inside your appliance.
Below the inlet valve for your model:
1014350
Mar 05, 2009 | Kenmore Washing Machines
Cold water into tub of wash machine
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!
Cold water feed into tub seems somewhat pluged.
8. re-try.
Hot Water runs in fine but the cold only trickles into Washer,
There are 2 hoses. Hot and cold and if the nobs are not turned wide open then it will not give you the water like you want. Check to make sure that the hot water nob is turned to were the water should come out like the cold. If not that then check the water heater and see if it is set up the way it needs to be.
Nikki2913
Dec 02, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
