Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
How to change a drain pump in Bosch dishwasher?
How do I change the drain pump in a Bosch dishwasher? I have SGS43A32UK/01 and have found the correct part on e-spares. How do I go about changing it? I can't see any screws holding it in. Is it glued or do I need special tools?
  • 98 Answers
Are you sure you need the pump? I have written a guide you should review before you go through the hassle of the pump. Read it thoroughly and follow the directions. If you replace the pump and it is not the problem, you'll be going through all of these steps anyway.
<a rel='nofollow' href="http://www.squidoo.com/Bosch_Dishwasher_Drainage_Problem_Fixes">It is here.</a>
Posted on Jul 23, 2009
Water wont drain all the way
Hello
That sounds like your drain pump has gone out. Bosch will fix it for you... Im not sure how much they charge. Im looking up the part for your model dishwasher and the pump is $88 (part number is 167082) . You can call Sears at 1-800-469-4663. We will come out and fix it for you. The service charge is usually $55-$65 depending on where you live, and then its the price of the part plus labor. Usually with a dishwasher thats drain pump went out its more cost effective to buy a new one, EXEPT when it comes to Bosch because they are such high end dishwashers. Hope that was helpful.
Check your installation. Most likely the drain hose has not been installed with a high loop.This is the most common mistake I see with Bosch dishwashers.
You may want to search GW for High Loop to get more info on how to correct your problem.
Aug 08, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
My Bosch dishwasher is making a loud grinding noise when it drains
This video will explain what is wrong and how to repair yourself.
Bosch Repair video
Feb 16, 2011 | Bosch Dishwashers
Won't drain
I found a video that explains how to fix this issue, here is is.
Bosch Repair video
Feb 06, 2011 | Dishwashers
Bosch SGS5332GB dishwasher. drain pump runs all the time
There is a float under the machine that tells the pump to shut off. If the float is stuck or bad, the machine will keep draining. I am including a web site that might help. Bosch Dishwasher That Will Not Stop Draining Hunker
Nov 06, 2017 | Bosch Dishwashers
Bosch dishwasher doesn't drain anymore
I would check the pump if its clear but not pumping down correctly check the drain hose if that's also not clogged then look into replacing the pump.
Jul 04, 2017 | Bosch Integra® 500 SHX46L Built-in...
Thanks!
it changes it a bit for me as bosch and kitchenaid have quite a different design but they operate on the same principle.
can you supply me with the full model #?
you could have something caught in the drain pump.
Sep 13, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch SHU43C
My SHU43C is just over 3 years old. I had a similar problem recently. First, there were a few floods. Then, the Bosch only drained non-stop. Even when I used the Cancel Drain buttons the drain pump would run without stopping. When I tried to run one of the cleaning cycles, no water entered the machine. Corrective: I removed the base plate, and saw that the red plastic floatation device was in the up position. Using a flashlight and a wooden spoon, I lightly toggled the red float stem down. I pushed regular clean cycle and kept toggling with the red float stem until the rinse water started to enter the machine (turning the red stem seems to also actuate a step in the program). Now the dishwasher runs normally. Voila!
Jun 22, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHY56A05UC Drain Pump Replacement
It's not easy. I just look at my sister-in-laws and I think the tub needs to come off. I plan on working on it this week.
Bruce
Jan 13, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch sgs43a32uk/01 dishwasher
clean filter outlet, pipe is ok ..remove stainless steal screws in side door it should be easy to fit seal then.
Nov 27, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
4,997 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
