Question about All-Pro Heating & Cooling
Will not light, has spark and the fan comes on will not fire its 50,000 BTU
  • 3 Answers
Is it spark to piolt or spark to burner
Posted on Jul 20, 2009
5 Suggested Answers
tbugger
  • 232 Answers
SOURCE: DAYTON 210,000 BTU OIL-FIRED HEATER WON T LIT UP
You write "FUEL SPRAYING AND FAN WAS WORKING"
If the fan was working, but the fan is not working now after replacing the whole kit, then something was installed incorrectly during the installation, possibly the rotor gap or rotor thickness is not correct or vane/vanes installed 90 degrees off.
Posted on Dec 08, 2008
SOURCE: have a 120000 btu fuel fired torpedo heater that
fuel is atomized by the blower fan, and a sparkplug provides the ignition source. this sparkplug provides constant ignition spark for the process.
Posted on Jan 03, 2010
heatman101
  • 43501 Answers
SOURCE: Reddy Heater 50'000 BTU - Puffs Smoke and Leaks Out The End
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Oct 31, 2010
  • 224 Answers
SOURCE: I have ready heater 150,
No fuel!! Several things can cause this, empty fuel tank, dirty fuel filter, plugged screen in the nozzle assembly,or plugged nozzle. So lets clean up the fuel system by first removing the top section of the heater and exposing the burner tray. Remove the tray and locate the fuel nozzle, remove the nozzle, now they say you can not clean them, I say with a q-tip, tooth pick and carb cleaner you can just be careful not to damage the nozzle. Behind the nozzle is a screen assembly these corrode at times so clean it up too. Below the nozzle assembly is the flame sensor, clean this with windex and a soft terry cloth rag, make sure it will have a clear unobstructed view of the flame.Put the nozzle assembly back together, and now inspect the fuel line for cracks, holes,and dry rot replace if necessary. Trace the lines down to the side where they come thru the case. Remove the side cover and locate the fuel line and in line filter, remove the filter. Cleaning this is easy you need a compressor and blow gun, all you do is blow air backwards thru the filter and instantly its clean. Inspect fuel lines and reassemble. Now make sure that you have clean fuel in your tank, and there is no water in it as well.Plug it in and you should now be heating like new. If not it could be your fuel pump!
Posted on Dec 27, 2010
7 flashes no ignitor
Check spark wire if OK bad module
Mar 28, 2014 | Coleman Propane Forced Air Heater...
My Coleman direct vent forced air furnace 7995-656/D will fire up but the auto fan does not come on. I can cheat this by cutting the fan to on after the burner heats up. Whats my problem?
two things the pressure switch not working or the fan control afc not working could need cleaning at the back of the afc try this the afc works on temp rise to bring on the fan afc temp fall to shut of fan so it sound like the afc is not coming on at temp rise, also check if air filter is clean
Jan 19, 2011 | Coleman Propane Forced Air Heater...
Model rlp50 50,000 propane heater fan will run, will light, but won't stay lite when you release button, fan still runs
i have the exact same heater with the exact same problem. tested the thermocouple seems to be fine, tested the relay, it seems to be fine, could it be the gas valve????
Jan 12, 2011 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater-50,000 won't fire, fan comes on for few seconds than shuts off
Here is a tip that I wrote that tells you how to troubleshoot a Torpedo or Reddy heater...
heatman101
Sep 17, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
I have a 50,000 BTU, 0987539 that smells like it
make shure that you are using the proper grade of fuel and that therebis nothing blocking he airflow past the fan.
Jan 17, 2010 | Reddy R115DT Oil Filled Utility Heater
I have Rheem furnace imperial it will not fire up
Without much detail, I can tell you that one of the most common reasons for a furnace not to come on is a failed thermal couple. If this is the case, you can start the pilot light when holding the switch down, but it will always go out when you turn the pilot switch to the on position. It is a relatively cheap part, it is the copper wire with a steel point that sticks out above the pilot light. Replacing it should cost less than $20.
Jun 24, 2009 | Coleman Propane Forced Air Heater...
Coleman furnace wont fire
Check inside the door panel next to the wiring schematic, you should find the diagnostic codes. Look up 7 blinks. This should narrow down the problem. ( It sounds like a bad hot surface ignitor).
Good luck.....
Mar 31, 2009 | Coleman Propane Forced Air Heater...
Coleman space heather,when burners goes on it blow's out
it sound like the pilot is too small which would make the pouf sound pilot could be blocked , it should light with a wow wohumph
sounds silly but it the best way to say it or the burner lights smooth
Feb 07, 2009 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
130 people viewed this question
Top All-Pro Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Mack Baxter
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
