Question about Coleman Mach 15 Air Conditioner
Appears to be condensation leaking from the Carrier roof A/C in 2009 Pleasure Way Plateau RV. Leaks on back bed and floor. Thanks, Richard
  • Mike Butler
    Mike Butler May 11, 2010
    If condensation not running off roof while AC is on, you may have plugged drains. Is there any run-off the roof?
    Champion:
  • 233 Answers
There should be a pan under the evaporator coil in the roof mounted unit, the pan should have a hose on it to remove the water to a non objectionable place, you need to locate the drain and pressure it up to clear it, I would also remove the top covaer and check the cleanliness of the coil drain pan itself
Posted on Jul 20, 2009
Why is my roof rv a/c leaking condensate water inside Pop Up
if everything has been cleaned properly, is trailer level. good luck!
Nov 04, 2015 | Heating & Cooling
Why rv ac condensate leaks into rv
Drain holes on underside of unit on roof are probably plugged. Need to get up and look under and use a stick or similar to unplug drain holes. Should have condensation running across roof , if not, the drain holes are plugged. If worse comes to worse, may have to remove cover, only takes a minute, just be sure to shut power off prior.
Jul 14, 2014 | Dometic Rooftop RV Air Conditioner
I am facing the RV Roof leaks and does not know the solution?
Hi, There is a product called "White Lightning" that is a paint on application for Aluminium roofs on RV's. There is also a product that is a rubber paint on application for RV's as well...don't know the name. If your roof is anything but rubber, I'd recommend a SOLVENT based product, much more durable in my opinion. I had a 34' motorhome with a leak along the canopy rail and I used a solvent based building caulking product used when putting down plywood flooring in homes to stop any squeaking, and it was great, acts as a glue as well. Can't recall the name, PCL Professional, something like that. You need a caulking gun to apply it, comes in a large tube. Hope this helps you stay dry !!! Cheers, Gary
Apr 07, 2014 | Blinglights Trailer RV Camper Mobile Home...
2009 F-150 moon roof stuck open/motor works
There should be some way to manually close it. Look at the owners manual for help. All Power roofs that I have seen, has a small trim cover hiding a bolt or something like that. All it takes is an Allen wench or socket to crank on and close it. For more details
RV Roof Repair Leaks Repair
Jan 12, 2014 | 2009 Ford F-150
RV AC is working fine, but the water is leaking from the ceiling Where is the drain tube on the unit, The AC unit is a roof type, Duo Therm serial # 43404934, Part # 3105459
Normally, the condensate will drain out of the unit onto the roof and off the edge to the ground. Remove your cover inside (probably 2 screws) and tighten the 4 bolts you will find inside. If they are tight, go to your RV supply place and get new roof gasket. Remove the AC and insert the new gasket and resecure the AC to your roof.
Thanks for your question @ FixYa.com
Jul 26, 2011 | Dometic Rooftop RV Air Conditioner
My rooftop A/C leaks condencer water on the bed. Rain water does not leak inside.
Either your condensate pan is cracked or more likely it is just an issue that the drain is plugged.
Jun 05, 2011 | Dometic Rooftop RV Air Conditioner
Water leaks from the roof unit
This is condensate (which of course is water) that is coming from your unit. This is very normal ... Is it leaking inside or running across the roof and down the side of your unit? If it is going inside, there is a drain in your roof unit that is clogged. You must clear the clog. Remove the cover and inspect the base. Turn the unit off first.
Sep 19, 2010 | Dometic Rooftop RV Air Conditioner
I have a carrier air conditioner and the handler is leaking water all over the garage floor. What do I need to do?
You need to clean the drain. If you have a condensation pump it it still leaks after you clean the drain. It most likely needs replacing.
Please rate solution
Sep 20, 2009 | Carrier Heating & Cooling
Coleman tsr rv air conditioner leaks into rv when running
It probably has a clogged condensate drain. Take off the cover on top the RV and check hoses or tubes leaving unit for debris or lint. Often this water is used to help cool the condenser so look for leaves pine needles etc in the pan. There may be a cover you can remove on the evaporator section that will allow you to clean the collection pan and hose or trough. Is it possible the RV is far enough out of level that the condensate can't "run uphill"? Always power off while working on this unit unless you are electric savvy. Good luck!
Jun 28, 2009 | Coleman Mach 15 Air Conditioner
Condensation leaks inside rv
maybe thermostat setting is too low moisture builds up fast enough, recommend @22C/ 74F
May 19, 2009 | Heating & Cooling
Coleman Mach 15 Air Conditioner Logo
264 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
