Question about Code-Alarm Code Alarm Transponder
I have just bought a 1999 Rover 75 cdi club.Tried to lock doors and set alarm with the remote key fob acept it does not lock the drivers door
  • 3 more comments
  • davewjones Jul 21, 2009
    yes it does shane
    Thanks Shane ,I rang xpart (Bradburys of Barmouth)but he wanted me to take it in so they could put it on the T4 thingy and charge me £55.00 for the privalage.
    thanks again will do.I am trying to register on roversport.co.uk at the moment waiting for the second email.
    I called in to a local garage today and asked about this problem the chap said same as you only he mentioned solenoid in the latch assembly!I all so mentioned the about the T4 he said he had a better system that does all cars and charges £25.00,is he right or does it have to be The T4?
    Rgards Dave
    Thanks again.
    Is there a how to on your site re removing the door card and actualy replacing the latch assembly?
    brill hope I never have to do that repair.
    I have joined up this one all so.
    Cheers Shane.
    Problem Solver:
  • 9 Answers
Does the drivers door lock manualy?
Thanks
roversports.co.uk
Posted on Jul 21, 2009
  • 2 more comments
  • Shane Jul 21, 2009
    Chances are its your latch assembly, which is inside the door,
    Give xpart or rimmers a ring and they will have the part in stock, just let them know the problem and they will confirm it is the same thing ;o)
    Thanks
    roversports.co.uk
    yeah it is the main computer they plug it into, it will tell if there is any faults, something you could try if you dont mind getting your hands dirty is , go on to ebay and look for some 1 breaking a 75 or mgzt and get a cheap latch assembly then fit it yourself, if you have a haynes book of tricks it should be really easy.
    Any problems give me a shout at roversports.co.uk (free)
    The T4 is really just based around the mg/rovers, like he says he will have a computer that will do most cars (not all), but £25 is about right, the part i told you about is £70 from xpart/rimmers just so you know and wont get ripped off (i dont trust garages which is why i do 99% of the work to cars myself and the other 1% is at a garage my mate works in)
    there is a guide here: http://www.the75andztclub.co.uk/forum/sh...
    This is another website well worth joining
    Shane
How do I get my alarm system to chirp instead of beep when it goes off or when I lock my doors with the remote entry key fob?
Check to see if your vehicle honks when you press the "lock" button on your key fob. Press the "lock" button multiple times in a row. Many devices won't beep unless you double-tap the button after locking. If the horn doesn't honk, but the lights flash, your chirp feature is probably disabled.
Use your keyless fob and ignition key to enable the audible chirp. The process varies considerably on different makes and models. You must usually consult your owner's manual, a dealership or the alarm manufacturer for the correct process.
Jan 29, 2015 | 2006 Hyundai Tiburon
How do activate the remote alarm 1993 acura vigor
anytime you lock the door with the key fob or press the drivers door lock the alarm is on. if someone opens the door without the key the alarm will sound. test it by locking the door with the remote with the window down then after a min open door with the inside door handle by reaching in through window
Mar 13, 2013 | Cars & Trucks
Alarm sounds when i try to start it i bought it used and dont have the remote door lock fob if i wait for alarm to qiut (about 30 seconds) it will roll start but still wont crank any help ,thanks
trun the key on an leave the driver door open an unhook the postive cable on the batt then hook it back up with the key on an door open.then try to start it after
May 10, 2011 | 1999 Volkswagen Beetle
I own a '99 Range Rover 4.6 hse. I recently reinstalled a battery that had gone dead. I cranked the engine but the alarm went off and the vehicle did not start. I am getting this message: gearbox fault. I...
Unfortunately, there is a trick to replacing the battery.
1) Open the Driver side door.
2) Open the Bonnet and take the battery cover off.
3) Use your remote to lock and unlock the car (keeping the driver side door open)
4) Pull the Negative Lead from the battery first, followed by the Positive Lead.
5) Change or replace with charged battery.
6) Closed down Bonnet.
7) Your windows, sunroof, and key FOB will not work... so follow the next steps.
7a) Insert your key, with door closed into the exterior lock on driver's side.
7b) While turning the key to lock the door, hold down the "lock" button on your remote for 5 seconds while in "lick" position
7c) Your remote will reset, and you should be able to use your remote now
7d) While driving, roll each window down twice. On your third attempt, you should only have to touch the window button, and the window will have reset
Enjoy your Rover!
MIke
May 21, 2010 | 1999 Land Rover Range Rover
Central locking
turn key twice when opening, ie turn right. once drivers door will unlock, turn twice passengers doors will unlock, and locking is turn anti clock wise once will lock all doors, turn twice will set door dead locks.dead locks will stop openand lock internal button working and handle from opening door. the same actions can be applied to the remote one press drivers door, two press passenger doors, press and hold unlock button for 5 seconds and rear window will open.
Apr 23, 2010 | 2003 Land Rover Freelander
I have a 1999 jeep grand cherokee. the alarm goes off whenever i open the door if the vehicle has been locked the alarm stops when i start the vehicle i only have a key, no remote any ideas on how to fix...
If ithe alarm is factory when they will have to reset the alarm module with a scanner. If the alarm if aftermarket go to the control module and see if it has a reset button. FOBs (remote) can reset alarm. You Jeep is always set for break-in mode. The FOB sets this when ever the FOB is used to lock the doors. May be bad alarm module - Sorry - Good luck
Oct 17, 2009 | 1995 Jeep Grand Cherokee
Rover 75 Connoisseur SE Sat/nav 2004 (53). The central locking button on top of the driver's passenger door doesn't pop down when the interior central locking switch is pressed,while the other 3 door...
It may be set in the main menu to lock only by the fob. I know on GMC's there are about 7 different locking options. I'm not a specialist in Land Rovers but the cheapest way out is to check all your options on the dash/steering wheel buttons.
Sep 09, 2009 | 2004 Land Rover Discovery
Code-Alarm Code Alarm  Transponder Logo
548 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
