Question about Cooktops
Cracked Glass cooktop
Can I just replace mthe glass surface or do I have to replace the entire cooktop unit? I have a GE JP350 (white on white).
    Sniper:
  • 70 Answers
The glass top can be replaced.but u want 2 find out the cost of it first.they are pretty expensive and sometimes run almost equal to the cost of new stove.compare it to the cost of a new cooktop.
Posted on Aug 19, 2009
Glass cooktop cracked
Glass cooktops can be removed/replaced with the aid of two small screwdrivers. Gently go around the outer rim using the two screwdrivers like tyre levers don't due too much pressure and it will generally lift quite easily.
Mar 23, 2014 | Samsung NE595R0ABSR/AC 30-in Smooth...
Glass top is scratched and discolored...can you replace just the glass top? Susan
GLASS MAINTOP ASSY
Part Number PS253905
price around $812.92
Replaced main glass cooking surface on cooktop
First, shut of the breaker to the cooktop.
Then removed two screws to release brackets holding cooktop down. Then lifted the cooktop out of the recess in the counter top and removed the screws around the outside of the glass top. Removed the old, cracked top, by unplugging from the motherboard.
Turned the new cooktop upside down on table and placed weather stripping around the entire underside outside edge (to keep spills from going under the cooktop and cushion the cooktop from the counter top.
Then plugged the new cooktop into the motherboard, replaced screws around outside edge, lowered the cooktop into the recess in the counter, and reinserted the two screws into the hold-down brackets.
Turned the breaker back on.
Note: Just need Screw drivers and 40 minutes of your time.
Feb 03, 2011 | GE 36 in. Profile JP968 Electric Cooktop
I have a GE Profile 30" Ceran Schot cooktop mottle black glass.One of the burners has burnt in partial ring that will not come off with the recommended cleaners. Is it possible that it has literally...
If there was sugar in the item that boiled over, it will not come off it etches the glass. If it was with out sugar you might try a razer blade to scrape it off it will not hurt the glass if you use it flat
Sep 27, 2017 | GE 30 in. Profile JGP989 Gas Cooktop
Knob is turned off but burner light is still on and burner area warm
If this is a glass top cooktop then yes the bunner light will still be on when you turn it off. Also the bunner area will be still be hot. The reason why the light is still on it is telling you that the bunner surfas is still over 95 degrees. Once the bunner area is under the 95 degrees the light will go off. It is a safty warning for people saying that the surface is still hot.
Good Luck and please rate 4 thumbs up for the free answer.
Jul 07, 2010 | GE 30 in. Profile JP350 Electric Cooktop
Burner only cooks on high heat.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
Aug 30, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Scratched cooktop
as far as i know its normal to have an scratched in glass ceramic hob defend how long to use or many times of use.do u think is same usage? its normal defend on usage.
Jun 20, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Broken selector switch
TURN OFF CIRCUIT BREAKER. Lift out cooktop, remove all machine screws holding the glass frame. Remove plastic knobs and lift glass top straight up. Make sure rubber gromits are not ripped or torn. Unscrew the small screws on the selector switch and then lift up and tilt over the small aluminum chasis holding the switches to expose the wiring connections. Pull off the wires and pull out the defective switch. Replacre switch, connect wires, re-seat switch chasis, and secure switch with screws. Carefully drop in the glasstop lining up the switch shafts and the rubber grommets. Secure the top with machine screws and drop back in the cutout.
Apr 18, 2009 | GE 30 in. Profile JP350 Electric Cooktop
GE 30 in profile jp350kccc for sale
I have this cooktop with a bad burner. What are you asking for it?
T
Oct 23, 2008 | GE 30 in. Profile JP350 Electric Cooktop
Glass top
The cooktop will need to be removed from the counter. Turn it upside down and remove the screws. The biggest problem will be removing the cooktop from the counter. Sometimes it is not worth fixing as the part could cost around $400. NEVER use a cracked top as it could suddenly explode. This is tempered glass and very unstable if cracked or chipped.
Jul 10, 2008 | GE 30 in. Profile JP350 Electric Cooktop
Glass cooktop keeps cracking in same area
The cooktop box has a metal flange. Make sure the cooktop when dropped into the countertop is resting on ther metal flange and not the glass edge by itself. If it rests on the glass alone the weight will cause the glass to crack at some point in time.
Dec 20, 2007 | Cooktops
Cooktops Logo
618 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
