It was sold in New Zealand so will be an Australian model.
SOURCE: Electrolux Model E switch wiring diagram
The black wire coming from the power cord connects to one side of the switch and the other black and the red wire go to the other side of the switch. If it turns on with the switch in the off position reverse the sides. Good luck. If you need anymore help just ask. Please rate me so I know if I helped. Thanks.
SOURCE: vacuum won't switch on;got it apart;cord ok;need wiring diagram
Its a great idea to write on paper how its connected . So it helps with dis assembly & reassembly . I tried a Internet search . Looks like it'd cost money for a service manual. Though. I found a Kirby Spares Website that could help. Although it doesnt have Document downloads with repair help. There are spares & there is a telephone number for an engineer available during office hours. That you could ask for repair help. With wiring connections for your Kirby G3.
http://kirby-owners-club-shop.com/faqs.htm
The Engineers Telephone Number is 0845 388 9301
I repaired my Parents Kirby Heritage some while ago. With a new set of Brushes. Bulb Repair.
They are a Great Machine. Bit Expensive. Though Tough & Well Made !
Gary
SOURCE: how do you wire in new switch on rainbow vacuum
Hello. I am sorry but, if you don't already have the knowledge to do this, I would strongly reccomend you do not attempt it. Rainbows have a large wiring harness. Here's the main reason: Rainbow vacuums are designed to work with a water filter. If you wire the vacuum wrong, or, if one of the connections come loose, it could mean a possible injury to yourself or damage to the unit, which I know you paid good money for. This repair should only be handled by a qualified vacuum service tech. Thank you.
SOURCE: Eureka 5892BVZ ON/OFF switch burnt
COUNT ME IN ON A CLASS ACTION IF ANYONE KNOWS A GOOD LAWYER.
Here's my story, posted on other solutions here, especially on the Model 5893; many people with burned wiring and switches. Major fire hazard imo! Okay, here's the skinny on my upright Eureka POS vacuum:
Had a problem with my upright Eureka Model 5893
bagless kinda starting and stopping. Eventually, the handle would get hot, and finally it just
quit. When handle was disassembled, the wires were melted and it was
toast. Ordered a switch after talking
to several repair men. Talked to Eureka, too, and they were absolutely
no help. Cheap wiring and switch made in China. Good luck trying to
find a switch. vacuum-depot.com has switches, so you might try there,
but make sure you get the 3-prong switch (same switch used on Eureka's
Genesis). It is Part #27871.
