Question about Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966
Broke pull cord
I have a yard mechines gas trimmer by mtd with 31cc troy built motor curved shaft . how do i get the cord holder out to replace the cord.
  • Cheryl Robertson
    Cheryl Robertson Jul 24, 2009
    I fixed my problem myself. it took a curved pix to pull the lock washer off the shaft to get the cord return wheel off.
  • Tim Swiercinsky May 11, 2010
    What model is it?
5 Suggested Answers
  • 127 Answers
SOURCE: replacing pull cord on 4 cycle gas trimmer, troy bilt
these usually are threaded counter clockwise need a pair of channel locks to hold the flywheel then with the other hand crack nut open
Posted on Jun 30, 2009
moretons
  • 155 Answers
SOURCE: pull cord
try this site it may help its called pats small engines
Posted on Jul 26, 2009
SOURCE: I have a Yard machine by MTD, Model # zr700r.
You nnnd to un-screw the srews that attach the housing to the engine. There will be 4 more srews to un-screw to get to the cord
Posted on Aug 04, 2009
rycgl
  • 1545 Answers
SOURCE: trying to replace pull cord for troy built weed
You will have to remove the main cover and possibly more parts to access that area. Enter your model # info stuff on this search page and you will be able to see what is involved. Torx head fasteners hold the covers on. Go to:
http://www.ereplacementparts.com/
Posted on Aug 18, 2010
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy bilt pull cord wont retract
Recoil spring is broken or slipped out of retention slot. Coil needs to be retentioned or replaced. Unless you have done this before I recommend taking to pro. This is easy job if you have the jig but almost impossible if you don't.
Jun 29, 2014 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy bilt weed eater
I have a troy built 2 cycle pro-line tb90bc spring assist trimer.
its getting fuel and it wouldn't start I took out the spark plug and it was wet with fuel. pls fwd any info to ss.beepat@hotmail.com
May 06, 2013 | Troy-Bilt Tb90bc 17-inch 31cc 2-cycle Gas...
My 4-cycle troy-bilt string trimmer: string is locked up. I can not pull the string
Your String needs to be re-wound. You are almost out of string or your string has Jammed under the Motor and placing a DRAG on the Trimmer
Apr 08, 2013 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Gas mix?
Straight Gas no mix for a 4 cycle.
May 16, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Tryingto replace my troy built weed eater's head
Replacement head can be purchased from amazon, here Amazon com troy built head. I hope this helped you. Have a nice day. Vince
Jul 12, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I have a Troy Bilt TBP6040 XP 4 cycle weed eater with the spring assist starting. The pull cord broke and I am trying to replace it but I can't seem to get the cord to go all the way back in. I need help....
I just had this same issue. I found out that you have to take the cord out of the handle then put the spool in. You then rotate the spool back in and align the spool with the spring and fish out the cord which will put a small amout of tension on it. You keep the tension on it and put the handle back on.
Rgds,
Mark J
Apr 16, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Replacing pull cord on troy built mower model # 8654r 4hp
Remove the housing covering the clutch. The cord spool can then be accessed. Replace the cord. Be careful that you maintain the proper spool spring tension. Check operation before reassembling
Jan 10, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966 Logo
279 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
