Question about Black & Decker Garden
Spool Cap Fall Out
Spool cap keeps falling out but does not appear to be broken. It is not locking into the slots.
SOURCE: Worx WG150 Cordless Grass Trimmer spool nut keeps falling off
Thanks for update. Glad you got some resolution.
Would you mind rating my response?
thanks...
Charlie
Posted on May 30, 2009
tonyw514
  • 66 Answers
SOURCE: broken spool cap
I would say yes, here is a site for parts, if this is not helpful please specify your model number
http://www.toolpartsdirect.com/blackdecker/blackdecker-41.html
also here is the actual black and decker parts site.
http://www.blackanddecker.com/CustomerCenter/Parts.aspx
Posted on Jun 01, 2009
s_s_m_o_k_i_
  • 162 Answers
SOURCE: String caught in spool. Need to remove spool but
look for a notch in trimmer head above spool close to shaft and corrosponding notch in shaft.
these notches are for holding shaft in place with a screwdriver so you can losen the tap cap screw...
speakin of screwdrivers anyone see where my vodka went?? lol
Posted on Jul 31, 2009
MNfisherman
  • 11896 Answers
SOURCE: I need part for a Craftsman Weedwacker
You can either go to sears, or craftsman website or even easier if you can get one off of ebay
Posted on Aug 18, 2009
rycgl
  • 1545 Answers
SOURCE: I have a craftsman weedwacker model 257 799750 and
Spring, spool then cap....if that way doesn't let the line out correctly, then it is possible you have wound the line on the spool in the wrong direction. Try taking the line off and winding it on the other way.
Posted on Aug 07, 2010
How to keep center wheel cap on 2004 f150 from falling off
Those are a tight fitting plastic snap in unit...
If they are falling out the CENTER CAPs need to be replaced. To be replaced properly on the vehicle... they need to be aligned... and snapped into place... The popular approach was to hit them on... if they didn't snap in...
HIT THEM HARDER... (wrong)
http://www.yourcaliforniaford.com/
Feb 10, 2016 | 2004 Ford F150
Can not remove engine oil cap keeps turning
filler cap, on valve cover.
bad cap,? stripped out? over tightend by jiphphyboobs.
you will have to force it off and replace it,
a tedious process. get help if not knowing how to proceed.
you dont want cap parts broken off , to fall in there, see?
id attack the top part and collapse it and pull it with no debris.
Feb 07, 2015 | 1999 Jeep Grand Cherokee
Need instructions on changing the spool on electric grass trimmer/edger
Turn the trimmer over, I put it in my lap.Remove the orange spool cap by squeezing with thumb & forefinger. It will come right off. Remove & discard(there has got to be something they can be recycled as?) If you are right handed, hold the new spool firmly with left hand with flat side with the arrows up, keep a firm grasp & use small needle nosed pliers(I use hemostats) etc. to free the loose end of the line where it is looped thru the 2 slots. Keeping hold of the spool so it doesn't all unwind, let enough out to feed thru the hole on the side of the compartment where the old spool was. 2-3" will be enough. Then, place the spool into it's compartment with the flat arrow side up.Keep a good grip on the spool until you get it into place. Replace the spool cap by aligning it in the 2 slots that it came from & gently squeezing again until it locks into place & you are set to go. Don't worry about feeding the line out to proper length, it will do that all by it's self.
Aug 03, 2013 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
Sewing machine design
It sounds like the spool cap is broken or defective. It should fit snugly on the spool pin. If it is constantly falling off, then try finding a replacement. The horizontal spool pin design helps the machine pull the thread off the spool because the thread spool does not need to spin. The added pressure of spinning a thread spool contributes to tension issues (especially if you are using large thread spools that are so common now days).
On new machines, frequently the thread cutter is on the back of the presser foot lifter.
The thread guide above the needle is usually threaded from the left side because the thread tends to be pulled toward the right.
Unfortunately, what you are experiencing are pretty much common functions with most newer sewing machines, so even changing machines may not result in any greater degree of satisfaction.
Mar 31, 2017 | Singer Sewing Machines
Gettin spool off to change string
1.Twist the cap off counterclockwise.
2. Remove the cap and spool.
Note: If the spring falls off, install it before installing the spool.
3. Thoroughly clean the cutting head and cap and inspect them for anydamaged or worn parts.
May 29, 2011 | Toro& Electric String Trimmer
Bird nesting I think something is missing like a washer on the spool shaft under the cap and I don't know what should be there
common problem especially with new users who are used to fixed spool casting, when casting with a multiplier you should keep your thumb over the drum so you can slow down the drum as your cast slows to fall in the water, if you had a drag washer you wouldnt be able to cast, you will get the hang of it with practice, but even with 30 odd years of use i still ocaisionaly get a nest.
Jul 06, 2010 | Pinnacle Inertia Baitcast Reel
Need info on putting line on troy bilt 4-cycle string trimmer. Need to know how to get spool off trimmer to replace trimming string on the spool.
Hold orange spool containing string while twisting the black plastic cap in the center, counterclockwise. This retaining cap is loosely spring loaded, so watch for the spring falling out. Once this locking cap is removed, the spool pulls right off.
Mar 27, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
How to Exchange Gas Caps On a 98 Camaro
Unhook from opposite end odf cap . Just gently lift plastic cable holder off of grommet
Apr 04, 2009 | 1998 Chevrolet Camaro
Water leaks under veg bins.. Cannot tell where it is coming from. Accumulates slowly
This refrigerator look like mine (Picture).
Mine did the same thing. If it is the same then this is what I did.
Look under the there is a collection tray.
This tray collect the water.
At the bottom of the refrigerator (Inside where the water collect) is a cap.
The cap has cap would have holes or a slot that allow the little water to fall to the collection tray.
Mine has slots and was block up.
clean it out and that should do it.
The water should be able to fall to the tray at the bottom.
I do hope this help you.
Mar 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Garden Logo
41 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
