Question about Kitchen Ranges
Converting (older) Frigidaire OVEN from natural to lp gas
I have a Frigidaire stove (model GPF300PAWA, serial# VF30916396) that was natural gas but I need to change to propane. I flipped the regulator lid, and adjusted the orifices for each stove top burner and all are working well, but I cannot find a way to change the oven. I don't see an adjustable oriface. Can you please tell me where it is or how to change the oven. Do I need to take out the whole burner underneath? Than you.
  • bydabayou Jul 23, 2009
    This article was full of interesting information but did not answer my question: where is the adjustable orifice for the oven on my unit. I ended up having an appliance repairman look at it who, first, told me how to remove the bottom of the oven from inside the oven box (remove two screws in the back, push up and back to free tabs at front) and then, where the orifice was located: at the very bottom at the rear. It was not visible from inside the broiler, but was visible after lifting the bottom of the oven box out.
  • 6,674 Answers
Sometimes it is a matter of turning oven orifice clockwise all the way, until it bottoms out. I obviously don't have info you were given, but does it say anything like that?
Posted on Jul 23, 2009
  • 1,170 Answers
1) New ranges ship from the factory already set up for natural gas. There at least a couple of reasons for this:
a) A higher percentage of our population uses natural gas
b) It's easier to convert to LP than back from LP to natural
There are basically two types of ranges to deal with: those with sealed top burners, which are pretty much the standard today, and the conventional, 'non-sealed' ones.
While they operate in much the same way, their conversion is usually different. There are still a few ranges that use adjustable sealed burner orifices, but most are 'fixed' and must be individually replaced to convert each burner from one fuel to another.
(An orifice is simply a small brass fitting with a specifically sized hole very accurately drilled through it, and, if adjustable, has a provision to change the size of this hole by turning closed a threaded portion).
Either way, basically what you're doing when going from natural gas to LP is changing to a smaller orifice to allow for the higher pressure supplied by the 'bottled' gas (The available energy in each ft of gas is different too, but for our purpose here that's not important). Natural gas supplies typically run around a pressure of 5.5 inches water column, while LP runs at twice that pressure, averaging around 11 inches. The orifice through which the gas travels to the burner must be smaller to accommodate this difference.
Adjustable orifices are simply 'snugged' down, clockwise, with a 1/2 inch open-end wrench, to convert them. Nearly all oven burners use these too - more about that in a minute.
Fixed orifices are replaced, and the good news is: the LP parts are usually included with the new range. On some brands (GE being one), the unused set is attached to a storage point on the stove, and this is a great idea. This way, they can't get lost, and if you ever want to convert back, there they are!
The not-so-good news: these little top burner orifices very often require a metric wrench to remove & install. And some can't be changed without a very slender wrench or nut driver.
A very useful tip I picked up many years ago: to hold that little orifice in a regular nut driver or socket, tear a very small piece of paper towel, hold it over the open socket, then push the orifice into the socket. The paper does a great job of holding the orifice into the wrench, preventing its being dropped into the 'innards' of the range.
The installation instructions that come with your range will usually be pretty clear on which orifices go into each burner head. Many new cook tops use as many as three different sized burners, each with a different BTU rating and orifice size. I usually start by laying the correct orifice beside its corresponding burner, just to be sure I get them right the first time. Again, the instructions should be clear on this. Some use a color code system, while others use size numbers. (Note to manufacturers: here's another area that needs a standardized system!)
One detail that's commonly overlooked on these is the simmer settings. Each top burner valve has a small screw inside its shaft that can be adjusted to provide a low simmer. This adjustment must be made on each burner once the range has been converted, or 'simmer' settings will be far too high to be useful.
A small-bladed screwdriver is needed for most of these. If you can't find one small enough, it's possible to grind one down to fit. I've noticed some of the most recent ranges are using a larger screw that's a lot easier to access, and that's a welcome change.
That should help get you through the top burner conversion. Not as hard as it sounds, and stay with us -the rest is much easier.
First convert the regulator. This is the part to which the inlet connects. Remove the vent cap, flip the insert over and reinsert it (You'll usually see 'NAT' on one side and 'LP' on the other). Reinstall the cap, and that's done.
Then, find the brass orifice that supplies the bake burner (usually under the range, behind the drawer), and if included, the broil burner (usually inside the oven). These are adjustable, and, like adjustable top burners, are simply 'snugged' down clockwise with a 1/2 inch wrench.
Then turn the oven on, keeping in mind that it may take up to 2 minutes for ignition to occur. Watch the burner flame. If, after burning for a minute or so, it pulls noisily away from the burner, it's getting too much primary air. Simply loosen the screw on the air shutter, where you just turned down the orifice, and close this shutter down a bit to reduce air into the mixture. If the flame is yellow-tipped and appears 'soft' (you'll know if you see it), open the shutter a bit to increase air into the mix. This adjustment isn't critical, and will rarely have to be done. But you should now about it. Again, the instructions should mention this.
Congratulations! Your new stove's flames should be a cheerful, even blue, and you just saved yourself some serious money.
Posted on Jul 18, 2009
Recently acquired an older Hot Point Cooking stove with self cleaning oven. Need to know if I can convert to propane and how to do so. There were no manuals with the stove..
Stove conversion natural gas to Lp - YouTube
? 6:08
https://www.youtube.com/watch?v=iXX2mS6FrxI
Sep 2, 2014 - Uploaded by Clay Rogers
If anyone can do it so can you. ... Stove conversion natural gas to Lp ... How to Convert Your Natrual Gas ...
Nov 15, 2015 | Kitchen Ranges
Brown TM210-4 kitchen range... how do i switch from LP Gas to Nat. Gas on this model? Is it just a regulator adjustment? or do i have to change the orifices as well?
Both. If this is a sealed top range, then you will have to change out the orifices and flip the cap on the regulator. If this is an open top style range (the top lifts up around the burners) then the orifices need to be adjusted and the regulator cap flipped. The oven/broiler orifices will also need to be changed or adjusted, depending on which kind they have. Some older models also require converting the oven thermostat from LP to natural gas (and vice versa) by turning the screw to the correct marked setting. If you have your owner's manual, it explains the conversion in it. If not we may be able to find it online for you to download. Douglas
Oct 09, 2010 | Brown Stove Works TM210 Gas Kitchen Range
I have a Frigidaire Stove, Model # FGF316ASA. It was changed from propane to natural gas. The oven works well. The burners, however, will only burn a low flame. Is there a solution for this?
When converting an appliance from propane gas to natural sometimes a technician will drill the orifice to a larger size rather than replace the orifices. Either way is fine, but sometimes the orifices don't get drilled to the correct size. The regulator must be on the propane setting if it is a convertible regulator. If your oven is working fine.... the top burner orifices probably need to be checked that they are the correct size. A simple fix.
Tom
Aug 11, 2010 | Frigidaire FGF316 Gas Kitchen Range
Gas stove need to switch to propane
Hotpoint supplies the orifices and instructions with each range for converting. It is just that it is hidden, they attach it to the gas regulator. The regulator is near the bottom back typically. Here is a cut out from your use and care manual.
CONVERTING TO LP GAS (or converting
back to natural gas from LP)
This range leaves the factory set for use with natural
gas. If you want to convert to LP gas, the conversion
must be performed by a qualified LP gas installer.
The conversion instructions and LP orifices can be found
attached to the range next to the pressure regulator.
Keep these instructions and the orifices in case you want
to convert back to natural gas.
May 13, 2010 | Hotpoint RGB745 Gas Kitchen Range
Recently purchased Frig. gas stove.Want to convert from natural gas to Lp.Do you remove spud and insert Lp oriface in spud then screw spud back onto line?Lp oriface is a lot smaller than oriface for...
Not really sure which model you have but when converting the over, ether bake or broil burner you tighten down the orfice cap. If you remove the burner off the oven valve you will notice that you can put a wrench on the orfice cap. Just tighten snuggly. If you over tighten you will crush the orfice under the cap.
Dec 22, 2009 | Frigidaire Ovens
I have a frigidaire gas stove model #FGF337AWJ.
I went through that once and believe it or not it was the ignitor. Instead of a thermocouple these new ovens use the amount of current going through the ignitor to prove the flame. Seems like after it gets ot a certain temperature the amps drop off enough to cut out the flame and then it will try to recycle. If it is not that it would be the thermostat but they very seldom go bad. I would reolace the ignitor first I think it will solve your problem.
Nov 14, 2009 | Frigidaire FGF337BC Gas Kitchen Range
Converting a stove from natural gas to lp
Crank down the orifices and flip the regular nut.
Jan 05, 2009 | Kitchen Ranges
Flames are extremely uneven and high
okay, DO NOT USE THIS STOVE ON LP GAS.
It's not intended to be used with LP gas, because LP gas requires a smaller orifice than natural gas. Call your propane supplier IMMEDIATELY...DO NOT USE THIS STOVE UNTIL IT IS CONVERTED TO LP GAS (if it's even possible)...this is extremely dangerous and you could hurt yourself if you continue to use LP gas on a stove that was designed to run on natural gas.
Dec 06, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Change from lp to propane on my whirlpool stove
Propane is LP...(i.e. Liquid Petroleum)
The burners are working only as a fluke. It is extremely dangerous to operate a natural gas stove on propane. STOP USING IT IMMEDIATELY. Call your local propane supplier and ask them about converting it to LP/Propane.
Jan 15, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Kitchen Ranges Logo
123 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
