Question about Black & Decker Le750 Lawn Edger
LE750 will not run
Al of a sudden it stopped running.
My club car gas golf cart was running good then al the sudden wont go over idle speed
Perhaps it's a stuck carburetor float valve, bad fuel pump (if it has one) or clogged fuel filter.
Jul 03, 2015 | Cars & Trucks
It just stop running
seems to be issues with wires not seated properly, I had a wire that was not seated in the trigger switch. reinserted wire. Be careful on putting the wires back in place, not a lot of play. If not the switch, check the wires at the armature.
Mar 12, 2014 | Black & Decker Le750 Lawn Edger
I need to dowload a user's manual for Edge Hog LE750
Go to this link:
http://www.blackanddecker.com/outdoor/LE750.aspx
Wait until the page loads (Slow!)
Then click on instruction manuals and download your manual.
There are LE750 Type 1 - Type 5 manuals.
Here is the direct link for the Type 3 manual:
http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/243420-02,LE750.pdf
Thanks for choosing FixYa,
Kelly
Aug 31, 2011 | Black & Decker Garden
The edger is not cutting very well. Any tips to make it work better?
You said cutting, not running, so I suggest removing the blade and sharpening on a grinder or buying a replacement blade.
I hope you find this very helpful.
Aug 21, 2011 | Black & Decker Le750 Lawn Edger
I have lost my manual for my Black and Decker Edge Hog model LE750 any help in finding one would be greatly appreciated. Thanks for any help you can provide, Bill
Which type of the Black & Decker Edge Hog do you have? (This will be on the plaque with model and serial number.)
Black and Decker has the manuals for type 1 through type 5 on their site: http://www.blackanddecker.com/outdoor/LE750.aspx . Click on the Instruction Manuals link.
The direct link for the manual for type 1-3 LE750 Edge Hog is http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/243420-02,LE750.pdf .
I hope this helps.
Jun 21, 2011 | Black & Decker Garden
Problem with my B&D LE500 lawn edger. Will run good then quits. pressing trigger several times edger starts. may keep running or quit. are there points or something electrial that could be problem?
Check the switch, it could burnout. The trigger switch made on this model are very cheap and can not supply current to motor for a long time without burning out. So it could be that switch has melted, and plastic is covering parts of the terminal.
Apr 29, 2010 | Black & Decker Le750 Lawn Edger
The edge guide on my Black and Decker LE750 has worn out!
Exploded views (Printable) and parts can be found HERE.
Hope this is helpful,
Dolf-
Oct 18, 2009 | Black & Decker Le750 Lawn Edger
Ialmrnt5 display driver stopped working,
buy a better graphics card the one you have is just finding it to difficult to run sims3
Sep 23, 2009 | Computers & Internet
Hyundai accent 1.5 td stops all of a sudden
possible...also fuel filter cracked vacuum lines start with that look under the hood for cracked loose disconnected vacuum lines ck air filter ..
Aug 24, 2009 | 2003 Hyundai Accent
Need manual for edge hog
you can buy it from amazon.
http://www.amazon.com/Black-Decker-LE750-Electric-Landscape/dp/B00004DTNH
thanks.
Jun 09, 2009 | Black & Decker Le750 Lawn Edger
Black & Decker Le750 Lawn Edger Logo
159 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
