New light engine installed in Samsung HLR6168W but not getting a picture. I get sound, and there is light (screen lights up but just gray). I've adjusted the light tunnel and it is properly aligned (no black horizontal or vertical blocks on the edges), but I'm still not getting a picture. Any ideas would be greatly appreciated Thanks, Mark
  • maestro_m679 Jul 19, 2009
    Thanks Skyassoc, you were pretty much on the money. I finally figured it out...turns out it was a bent pin on the DVI cable which was caused by an obstruction in the female DVI connection (where it connects to the TV, not the light engine). Finally, after 3.5 months my TV works. I soooo hate Samsung - unbelievably horrible service. They are truly awful!
    Thanks Skyassoc, you were pretty much right on the money. It turns out I had a bent pin on the DVI cable on the end that plugs into the TV. This was caused by an obstruction (a piece of plastic) on the TV side of the DVI connection.
    Anyway, after 3.5 months I finally have a working TV again, no thanks to Samsung. They are truly awful...worst service I've ever experienced and I'll never buy a Samsung product again.
  • 668 Answers
Double check that you did not over look any plug connections or ribbon connections when reinstalling light Engine
Posted on Jul 18, 2009
Samsung flat panel TV. I have sound with a black screen. Can you help me
Hi Cherie, The link below is a YouTube video showing how to fix a Samsung television NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS.. Samsung UN46D6000 No picture Sound OK problem FIXED BN95 00497B BN41 01662A
May 01, 2016 | Samsung Televison & Video
Gray bar on top only
Hello, I will need a picture of the screen and a model number to be sure, but it sounds like it has a bad screen.....tks...Terry
Mar 22, 2014 | Samsung Televison & Video
I have a sony KDL 46xBR2 when I turn on powers up green light stays on but a dark gray screen no picture or sound
The green light merely indicates that power is getting to your TV. The symptoms you describe point to internal power supply failure
Mar 17, 2013 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Samsung monitor blue flashing light, black screen
The picture board of your monitor has developed fault. That is why the screen is black.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity, because the fault is not something you can fix in other not to complicate issues..
The repairer will help diagnose and replace the faulty picture board and your monitor is back and better.
Take care.
Apr 19, 2010 | Samsung SyncMaster 203B LCD Monitor
I have a Samsung HLR6168W DLP that intermittently shuts itself down,the sound stops, the picture disappears, the screen goes dark but not completely off. A few moments later the picture returns, but no...
its the problem of inner lamp that is near to end of its life and it needs replacement.and what the thing is happening is the indication of faulty lamp.
how to replace the colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
how to replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
how to replace the ballast with diagram and procedure
http://www.consumermeet.com/entry/samsung-dlp-ballast.html
Mar 11, 2009 | Samsung HL-R6168W 61" HDTV
I have an RCA Scenium HDTV DLP, Model HDLP50W151. Turned it on and went through it cycle, whining sound but the screen was gray. turned it off and then on again...no picture and there was no whining sound....
Sounds like the Color wheel on the Light engine has failed. Its a major repair. Contact Thomson at 1-866-465-7157 to find a local authorized repair center.
Jun 04, 2008 | RCA Televison & Video
Shadowing on right side of TV
Replacing the "light engine" fixed the problem. The technician said that there was a felt-like lining in the light engine to prevent undesirable reflections from the insides of the light-engine hardware, and that it becomes detached and blocks an edge of the picture.
We had a dark line along the right-hand side that was like looking at that portion of the picture through a 1" strip of very dark glass.
Because the DLP is new technology, we purchased an extended warranty from Best Buy (actually, their Magnolia subsidiary) which covered it.
The new light engine was slightly different physically, and the technician had a hard time getting the picture centered and aligned on the screen after installing the new one. In fact, he gave up on the first one and fetched a second one from his truck. He also had problems with the second one, but finally got everything aligned.
Feb 22, 2008 | Samsung DLP HL-P5663W 56" TV
DLP TV: Left half normal, vertical 6" band center is gray, right half almost black. What's wrong?
No. The optical engine is OK. You need an adjustment in the light tunel. Call a tech to do it.
Nov 06, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Televison & Video Logo
165 people viewed this question
Top Televison & Video Experts
Electro Med Services...
