Question about Konica Minolta Di1610 Copier
Minolta 1030 blank copies?
Please need help, replaced toner cartridge in unit, now copies are blank, can you give me some suggestions, thanks. George
    President:
  • Konica Minolta Master
  • 990 Answers
Hello George;After you replace the drum, you have to push drum unit and developer unit closer,and the fasten it if stll don't work go to check the charge unit see there have broken crona wire ,if they do repace it.
Posted on Jul 18, 2009
MINOLTA EP 1030 CF3
Have the image unit replaced or have tech come out and have the developer replaced the counter cleared and run F8 run, after the developer is installed. Also replace the fuse on the image unit so the copier thinks its getting a new image unit when only its getting a developer changed. Try finding a image unit first. try below Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Nov 22, 2012 | Minolta EP1030/1030F CS/PRO Copier
Prints blank pages.
This issue occurs if toner is low. Remove the toner cartridge from the printer. Shake the cartridge back and forth several times, and then reinstall it. If this doesn't resolve the issue, replace your cartridge toners.
I suggest you contact Lexmark Technical Support if the suggestions above did not work. Please make sure to have a copy of your print quality pages before giving them a call.
Jul 28, 2011 | Lexmark C533DN InkJet Printer
My copies have a thin blank streak about 1 inch in on the left side. the streak is about 1/4 inch wide and goes down the whole sheet of paper
Start a print or copy, and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at the drum and the paper underneath. If the issue is there at that point then it would point to the cartridge. If not then it is in the fuser area.
Clean the loose toner up with a dry lint free cloth.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 20, 2011 | Brother DCP 1000 All-In-One Laser Printer
I have a Minolta EP1031F that has been working perfectly. It ran out of toner and I replaced the toner cartridge per instructions on the toner box. My 1st copy after to toner replacement had a down the...
It is better to use the machine as much as possible when it is only used now and again it causes a lot of issues your problem is probably going to be with the developer unit it is best to have an engineer certified on this product give it a general service and replace what ever needs to be replaced the cleaning blade and developer will most likely need to be changed
Feb 18, 2011 | Minolta Office Equipment & Supplies
What is the drum cartridge?
A drum cartridge is the rotating drum that puts the toner onto your copy's! You would need this to make copy's and after its empty, it would need replacing.
If this was helpful please rate with a 4 thumbs up!! Thanks for using fixya.com!!
Apr 22, 2010 | Konica Minolta Magicolor 2530 DL Laser...
My al-1631 gives blank copies. just replaced toner. no warning lights of any kind. no message lights. it just prints out blank paper. could it be the drum? can't find instruction manual. purchased...
Was the copier working fine before you changed the cartridge? If so I think your cartridge is the problem. If it started making blank copies right after you changed it. If this is not the case the first thing I would say is it is not the drum. Try opening and closing the right side door. There are contacts in the door that will cause blank copies. I have had several customers do this and it fixed the problem. You can also try pulling out the toner and then pull the drum unit partially out and re-seat it. Then re-install the toner.
Good Luck
Jan 05, 2010 | Sharp AL 1631 Copier
Copies blank
This is normally the corrona wire that needs to be replaced in the transfer unit and drum unit.
Sep 14, 2009 | Minolta EP4000/5000 CS/PRO Copier
Vertical blank line in printing
Problem 1:The laser lens is dirty.
Solution: Clean the laser lens.
Problem 2: A toner cartridge may be defective.
Solution: Remove the toner cartridges with the color causing the abnormal image. Replace it with a new toner cartridge.
Problem 3: The drum cartridge is defective.
Solution: Remove the drum cartridge and check for damage. If it is damaged, replace it.
To get help with cleaning copy and paste this link into your internet browser window:
http://kmbs.konicaminolta.us/productsattachments/manuals/magicolor2430DLUserManual.pdf
Wait for the pdf to load.
Then go to page 78 of pdf. Cleaning instructions are written with diagrams.
Do give my solution the highest rating if it solves your problem. Thank you for using fixya.
Aug 07, 2009 | Konica Minolta magicolor 2430 DL Laser...
Minolta copier 1030, changed toner makes no copies
take the toner bottle out. turn off the machine then turn it on with the bottle out. once the machine, ask for toner install the bottle.
Jun 18, 2009 | Konica Minolta Office Equipment & Supplies
Replaced toner in a Canon image runner 2200 copy comes out blank
1) you do not dump toner into the drum! Juo dump it into the toner unit.
2) didi you after replacement put the blue toner handle (right from toner unit) into the left position?
May 27, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Konica Minolta Di1610 Copier Logo
79 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
