Question about HHB BurnIt CDR830 CD Recorder
In the process of burning a CD the unit stops. When trying again, I get a "Repair" message. What could be the problem?
  • 77 Answers
  • probably there might have occure some error while burning
  • check of the cd has any scratch
Posted on Jul 18, 2009
Target drive not ready
This message means that the burning drives are not recognizing the blank media. There are a few things to try and remedy this though the unit may need repaired.
First, try using all of the duplicator bays by burning to another drive bay. If all other drives burn fine then the one drive may need to be replaced.
2nd, try a different blank CD or using a different brand. The most common fault for this message is a bad blank disk.
3rd, It is OK per Microboards to open the unit and check for a loose drive cable. A loose cable can cause this error too.
Finally, try cleaning the drive bays by using compressed air to blow any dust out of the system.
If the error still continues then call Microboards tech support at 952 556 1639 to set up a repair.
Apr 15, 2013 | MicroBoards (DSRDVDD882) Burner
Problems burning a cd with Sonic DigitalMedia Plus v7, I am on an HP notebook running XP
Try different software. I use CDBunerXP with no problems. It's free. Just don't install any extras (add-on programs) they include.
You should let it burn with no other activity during the process.
Oct 16, 2012 | Computers & Internet
DURNING FINALIZE MODE IT STOPPED WITH1:30 LEFT--- THEN I TURNED IT OFF AND TRIED AGAIN TO FINALIZE AND IT CAME UP WITH A READING OF---REPAIR--
That's a normal response to an interrupted Finalization.
http://www.retrevo.com/support/HHB-CDR830-CD-Players-manual/id/3875ci874/t/2/
The recorder was switched off/unplugged after recording without ejecting the disc. The recorder could not write essential recording information onto the disc.
While REPAIR is displayed, the recorder automatically examines the recorded area of the disc and updates the track numbers and recording time data. This process takes about 40 minutes for a fully recorded disc. Finalization or further recording is possible once the REPAIR message disappears.
Jan 23, 2011 | HHB BurnIt CDR830 CD Recorder
My cd burner on my compaq cq60 is not working. im trying to burn a audio cd in itunes iv tried to lower the burn speed and that worked for 1 cd now its giving me the 4450 message again. anyone know how to...
hello
i've seen this before --
How to FIX error code 4450 ? Fixing Error 4450 manually is a difficult process and it is not recommend unless you are an expert in this field.
Therefore, we recommend you to use Regservo. It is reliable PC Repair tool that can do all the hard work for you.
Please follow the 3 steps below:
(1) Download and install (Error 4450 Repair Tool). RECOMMENDED
(2) Click the "Scan Now" Button. and wait for the scan to finish.
(3) Click the "Fix" button to fix all identified errors.
Nov 17, 2010 | Compaq (120192-B21) CD-ROM Drive
When I try to burn tracks to a CD itunes says that there is no burn software.
That is probably because the cd is already used or somebody canceled the process of burning the cd, also once you have started a burning process with the cd you can not use the cd over again so basically you need a blank cd make sure you check to see if the cd is blank before trying to burn the cd.
Nov 10, 2010 | Apple iTunes
I have tried downloading from the samsung website lastest firmware update, which is an iso file when extracted it saves it to disc as a xuf file and the blu ray wont read this what am i doing wrong??
Read the Upgrade Guide (PDF) for instructions on how to do this. It says to burn a CD. The ZIP file extracts to ISO type. The guide tells you what format it needs.
http://www.samsung.com/us/support/search/supportSearchModelResult.do?menu=SP00&searchWord=bdp1400&searchInputBox=bd-p1400&find_button=
READ the PDF file under Upgrade Guide. Make sure you designate the proper file type when burning CD. Check your burning software.
How to make a firmware update CD
Please follow the below procedures.
1 Download the new firmware file from www.samsung.com
2 If the firmware file is compressed (*.zip), the file should be uncompressed to CD image file
(*.iso).
3 Please burn the CD image file on a blank CD-R/RW disc
1) Recommended CD Burning Program is Nero Burning ROM.
2) Burning Options (in case of using Nero Burning ROM)
A. ‘Recorder’ menu ?? ‘Burn Image…’ ?? Select an uncompressed image file(*.iso)
B. Please check ‘Finalize CD (No further writhing possible!)’
C. Please refer to your own CD burning Program Manual if you want to use any other
CD burning program for burning ISO image file.
D. Make sure if the downloaded software is eligible for your BD-P1400.
E. The System Upgrade will not be executed if using the update CD made with NOT
following the upper procedures.
Warning
The following events may interrupt the upgrade process and MAY RESULT IN PERMANENT
DAMAGE TO THE UNIT WHILE UPGRADING.
1. Unplugging the power plug
2. Power outage
3. Dirt or scratches on the burned CD-R/RW disc
4. Closing or opening a disc tray during update processing
How to upgrade the BD-P1400
1. Press OPEN/CLOSE button to open the disc tray.
2. Insert the upgrade CD.
3. Press OPEN/CLOSE button to close the disc tray.
4. Please wait about 6 minutes while verifying.
Verifying Firmware Version.
5. When below message box comes up, please check the date of the Firmware version.
Do you want to update Firmware?
>Current Version : 070730.02_XAA
>New Version : 070903.01_XAA
Yes No
6. Press ‘Enter’ button to choose ‘Yes’ for upgrade and please remove the disc on the tray.
If you select ‘No’, BD-P1400 will be automatically powered off.
If you don’t see above message box, try another disc. Generally, this is caused by disc
quality or a disc creation problem.
7. Please wait for about 7 minutes.
Firmware Update.
Now, Processing…
Please, do not turn off the power.
8. When finished, the screen and the power will turn off automatically.
9. Turn on the unit again. The tray will close automatically. Below screen will show up. Please
select the language you want with a corresponding number button.
MENU LANGUAGE SELECTION
Press 1 for English
Pulsar 2 para Español
Touche 3 pour Français
Macrovision : BSS01
10. If you want to do System Upgrade through the network, please refer to ‘System Upgrade’
Article on the User’s Manual.
Aug 18, 2010 | Samsung BD-P1400 Blu-Ray Player
Cd writer cannot write
try lowering the speed when you burn
Jun 03, 2010 | Toshiba Style Bay DVD-RAM Drive Kit...
Nec dvd+-rw nd-6650a stop burning dvds
It's time to replace the defective (and probably warranty-expired) unit.
If your computer is a notebook, not a desktop, it's best to take the computer to a qualified technician, to disassemble your computer, and replace the drive.
Jan 02, 2010 | NEC ND-6650A DVD RW Dual Layer Burner
Unable to login. when i start the computer after windows screen appers on blue this message is appering. could not even in save mode. this is the message STOP: c000021a{Fatel System Error} The Windows...
Have you installed new hardware recently? if yes, try to remove it again.
other option is to boot up using your windows xp cd, choose the rescue console, and type "chkdsk c: /f" ( without the quotes)
if that still doestn fixes it, you boot again using the cd, and then choose repair installation. let it do its thing. It will reboot when done.
Mar 08, 2008 | Computers & Internet
Sony rcd w500c recorder
Higher laser power is needed for high speed dubbing - does it work ok at normal speed? If so would point to a failing laser. Sony charge a lot for these but in the US there may be a fixed fee out of warranty repair cost.
Nov 03, 2007 | Sony RCD-W500C 5-Disc CD Recorder
HHB BurnIt CDR830 CD Recorder Logo
219 people viewed this question
Top HHB Audio Players & Recorders Experts
 Grubhead
Grubhead
Sam Palermo
Sam Palermo
Are you a HHB Audio Player and Recorder Expert? Answer questions, earn points and help others
