Question about Dometic Rooftop RV Air Conditioner
I have a comfort control 2200 thermostat. I changed the batteries and the thermostat is set to 80 degrees. The air conditioner stays on and the temperature on the thermostat is stuck at 80 degrees but the house temperature is down to 75 degrees and the air conditioner will not shut off unless I turn the thermostat setting to 81 degrees.
  • Dometic Master
  • 6,674 Answers
May be the location of the thermostat. Try another thermometer right beside wall thermostat & see what it reads.
Posted on Jul 19, 2009
Set thermostat at 74 heat pump will not cycle it will cycle at 75 degrees ?
check stat calibration. see if you can measure temperture at stat. the thermostat cover temperture reading is not that accurate.
Jun 01, 2014 | Goodman CLQ36AR49 Air Conditioner
Simple comfort 2200 thermostat not working properly
We have a Simple Comfort 2200 Electronic Thermostat and last night it quit blowing cool air and the # sign beside the air temp (the set to temp) starting blinking
Aug 11, 2012 | Heating & Cooling
When it's very hot, the cold air doesn't stay on long enough. It's fine in 80 degree weather, but it's 100 degrees now, and my little place is an oven, even with the thermostat set at 60...
This sounds like a low voltage problem .. you can check all your connections AFTER you shut down the power and tighen them all the way back to the breaker.. When electrical demand is high it is common for voltage will dropp. Hope this helps
Jul 23, 2011 | LG Goldstar WG6005R Wall/Window Air...
UNIT IS NEW, IT IS HOT IN TEXAS, BUT SHOULDN'T THE DOMETIC (DIGITAL THERMOSTAT) SHUT OFF AND CYCLE, WE WERE @ THE LAKE OVER THE 4TH OF JULY, THE UNIT NEVER CYCLED OFF AND ON, AND WHEN YOU TURN...
Sounds like you have fan in the "on" mode instead of "auto" mode. Here's a link to download an operators manual for that system. Should help.
http://www.dometic.com/FileOrganizer/1-international/Operation%20&%20Installation%20Manuals/Air%20Conditioners%20-%20Vehicles/Comfort-Control-Center_operation_EN.pdf
Jul 04, 2011 | Dometic Rooftop RV Air Conditioner
I have the Haier HWR08XC7 (8000 BTU) and my problem is that I have the thermostat set at 70 degrees, but it stays at 77 or 78 degrees... What could be the problem as the unit is 2 yrs old??
Hi!!
Check your owners manual, probably have unit set at automatic comfort level or some energy saver mode. It should say something on the remote about it.
Good Day!! Don't forget to rate this post!!
Aug 13, 2010 | Haier Heating & Cooling
Carrier Comfort Zone II Smart Control in one zone frequently cycles unit (every 20-30 minutes) even when temperature in the room does not change significantly and the indicated thermostat temperature does...
sounds like your zone control tstat needs calabrated or maybe replaced,in owners manual there should be a section on calibration if not you may have to replace it
Sep 09, 2009 | Heating & Cooling
Thermostat reset???
after you changed the battries did you check the set point. it is also possible that the batteries have ruined the stat
Aug 30, 2009 | Heating & Cooling
Thermostat location on York Diamond 90 gas furnace
Augold, sometimes its best to set the thermostat where you "feel comfortable" . I.E. set it and leave it til you feel the need to be cooler or warmer.
A thermometer on a thermostat will not always be accurate and setting it will only get it within 2 to 5 degrees which is enough to "feel".
Now from the stand point of is it working properly????
Assume you feel comfortable and the heat stays on to keep you comfortable is their anything wrong with this? I assume this is the goal. Even if it says 90 (and you know its not 90) and your comfortable you could leave it alone and be OK. If this kind of thing is whats bothering you a new thermostat may not be much better, unless your ready to invest in one and accept it however it should be closer to the place youd set it. Id recommend an electronic type they are more accurate and level doesn't matter so much to these types.
If you want to set the temperature and are determined to go by a thermometer to "feel Comfortable" I recommend you buy an electronic thermometer and set it close by the thermostat. Make sure you have no lamps or other heat sources close to the thermostat area.
Remember the far end of a room or a chair by a window Especially with little or no curtains and on the prevailing out door wind will always feel colder and be colder than the area by the thermostat even if both are in the same room. If your too cold try running the thermostat up a few degrees. If too warm set it lower. The equipment doesn't care how cold or warm it is.You will not increase your utility bills to the national debt by being comfortable
If this helps please grade me accordingly and Good Luck.
Mar 03, 2009 | Weather King 10AJA3601AH Air Conditioner
Air conditioner and heater come on by itself
Has anything been changed since it last worked well or normal? Thermostat ?
Aug 04, 2008 | Coleman Mach III Air Conditioner
Edgestar 12000 heating problem
bad thermostat. the stat can be as must as 5 degrees off. try, if possible testing the unit in a differeent location
Dec 24, 2007 | EdgeStar Portable Air Conditioner Heater
Dometic Rooftop RV Air Conditioner Logo
320 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
