Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune washer has bad odor, city water.
Is there a filter in the maytag neptune front load washer? where? If not how do I get rid of this odor? My clothes don't smell..but when you open the washer it smells like mildew.
  • 525 Answers
There is no filter in your washer that would cover the odor issue.
The website link below will give you all the information concerning odors in a Maytag Washer
http://maytag.custhelp.com/app/answers/list/kw/odors/p/293/r_id/108284/sno/1/search/1/session/L3NpZC9RRDdZdDhEag==
Posted on Jul 18, 2009
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    My Neptune front load washer has a foul odor. I have tried the HE tablets, wiping it, etc. but it smells bad. When I spin it with my hand, there is water in the background. How do I get rid of the smell?...
    Add 3 cups of Sugar Soap concentrate. Then fill the machine and leave it for 24 hrs.
    Then put it through wash cycle with no clothes.
    If not fixed........machine has to be stripped apart and manually cleaned.
    Oct 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
    My Maytag Neptune leaks water from the bottom (immediately) as it fills with water
    usually this is from the front door seal going bad remove the front panel and door to replace it
    Apr 30, 2009 | Maytag MAH6700AWW Neptune Front-Load...
    Sometimes there is water that fills in my washer after I use it. It does not happen right away but by the next day. I don't know the model but I do know this is an old washer....gold....I have had it for...
    Q - My washer seems to keep filling  with water, the water keeps coming in the washer and going out the drain without the washermotor running.
    A - This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
    1. Boot change helps
    2. Consumer Display Code Table on the Electronic Display Maytag Neptune Front load washer
    3. Free on-line repair manual for the Neptune washer MAH3000, MAH4000, MAH5500, MAH7500  ( Acrobat reader required )
    4. How to access the console on the mechanical timer models
    5. How to access the workings of the washer
    6. My washer door is locked and it will not open up...HELP
    7. My washer will start when I push the start button, but a few seconds later, it will shut off
    8. My washer will not pump out + pump noise problems
    9. My washer will not spin
    10. Odor complaints from the front load Neptune washer - mildew complaints + a new "freshen up" procedure
    11. Parts breakdowns/exploded of the Maytag Neptune front load washer ( mechanical timer models )
    12. Problem chart for MAH3000 & 4000 Neptune washers
    13. Readers repair tips
    14. Trouble shooting tips from the Neptune manual for MAH3000 and MAH4000 models
    15. Tips from our friendly engineer on changing the boot and re-installing that clamp and spring
    16. Tips on changing the washer belt  ( acrobat reader required ) Belt parts link
    17. Tips that show what components need to be checked/replaced if a certain resistor on machine control board is bad. It is as follows: Burnt resistors in Maytag Neptune washer models MAH4000 and MLE/MLG2000
    18. Washing one item in a front load washer
    Apr 01, 2009 | Maytag Washing Machines
    Maytag neptune front load odor
    its better do a maintenance, or put it to wash without cloths, only water and clorox, and varsol with the max level (water)
    Nov 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
    Dirty sock smell
    My suggestion is to contact Maytag. I have the same problem. Maytag can tell you what you can do to reduce the odor. I think the problem originates from the fact that the drum always has water in it and the rubber seal has a bad smell.
    Sep 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
    Maytag Neptune rinse cycle doesn't start.
    cold water valve screen plugged or bad valve, just check it!
    Aug 06, 2008 | Maytag Neptune MAH6500A Front Load Washer
    Maytag Neptune MAH5500B Front Load Washer Logo
    1,845 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
