Question about Sony DVP-FX810 Portable DVD Player
My dvp-fx810 will not charge any longer
Is there any way that I can determine if it's the machine or the battery?
    Problem Solver:
  • 10 Answers
TRY CHARGING USING ANOTHER BATTERY
Posted on Jul 18, 2009
INTERNALERROR 0X50
1. Restart the machine to check the network connection is correct (especially crystal head)
2. Determine whether the full duplex.
3. The data line is too long can cause data transmission can not be normal
4. Reinstall drivers
www.ezbuybatteries.com
www.chargerspc.com
http://cordless-drill-batteries.com/
laptop batteries
Replacement AC Adapter and Car Charger for Notebook Laptop PC Ultrabook...
Cordless Drill Batteries Replacement Cordless Power Tool Batteries...
Dec 08, 2014 | HP LaserJet Pro 400 M401DN Laser Printer
Replacement battery size MTD 13ao695G062
925-1707D is the factory part number... any local battery shop can replace this with an after market equivalent. expect to pay around $45-ish
Nov 16, 2013 | Yard Machines Garden
Manual strat
your machine would require an inspection ot determine that every mechanical supplimenmts afre availabel to start working. Engine oil, diesel oil, battery power.
May 13, 2013 | Garden
Sony DVP-FX810 Portable DVD Player 8 laiser repleament
Lazer is available in warantee of (Sony DVP-FX815) .send us email about your problem .
Email ,salmanwaheed2008@gmail.com
Thanks
Nov 17, 2011 | Sony DVP-FX810 Portable DVD Player
Travelmate 4150 overheated, alrready clean-up the dust, but doesn't starts.
This is the point where you need to determine whether or not the laptop has sustained permanent damage due to the overheating. Most laptop manufacturers have a safety cutoff that is triggered when the device becomes too hot and this feature will usually prevent permanent damage.
To determine if it is damaged you can:
Remove the battery from the laptop, and simply let it sit for a couple of minutes. Let it cool down, then reinsert the battery and attempt to reboot the machine. If it powers on, there is minimal or no damage. Best case scenario, your device will be fully functional.
If the device still does not power on:
Your options are to take bring the computer to a store that will run a diagnosis for you and determine to what extent the laptop has been damaged or you may accept defeat and start shopping for a replacement (worst case scenario).
I hope my answer has been helpful.
May 25, 2011 | Computers & Internet
Computer replaced batteries - screen lights up but does not function when rowing - not registering meters
Check the mtion sensing magnetic switch thats under the seat rail. It determines if you are rowing and sends a signal to the computer. Make sure all connections are fully seated. You may have loosened a wire when you swapped the batteries.
Feb 24, 2011 | Concept2 2 Rowing Machine
The battery is no longer charging when I plug it in. It will play but has to be plugged in at all times now.
There are two possibilities, the battery needs to be replaced because it will not charge, or the charging circuits on the main board are defective.
Feb 08, 2011 | Sony DVP-FX810 Portable DVD Player
If pluged into light not powering at all
Firstly insert the battery. When you plug the PSU into the machine does a charging light turn on? If not then check the fuse in the mains plug as it may have blown. If the fuse is OK then you may have a defective PSU, although the motherboard could also be defective. Try a new PSU to determine if which component is faulty. <br /> Now remove the battery and insert the PSU. Will the machine turn on or do any power lights illuminate? If power lights illuminate and the machine will not turn on then I would suggest the motherboard is at fault. If the machine turns on briefly the turns off before displaying the splash screen then I would suggest the RAM, CPU or motherboard is at fault.<br /> If the unit works without the battery installed then it is probably a battery problem, although it is possible the charging circuit on the motherboard is fried.<br /> Hope this helps,<br /> www.PuterCare.com<br />
Aug 30, 2010 | Dell Latitude D600 Notebook
Why when i switch my hp 6720s on does the battery light flash amber then goes white nd the laptop switches off? all in 5 seconds
It sounds as if the battery is too low to power the unit on.
If the unit works without the battery installed then it is probably a battery problem, although it is possible the charging circuit n the motherboard is fried.
Hope this helps,
www.PuterCare.com
Jul 04, 2010 | HP Compaq 6720s Notebook
My Acer Aspire One model D250 cannot power on even if i already put the power adapter.Is it the battery pack problem or the motherboard?
Hope this helps,
www.PuterCare.com
Jul 03, 2010 | Computers & Internet
Sony DVP-FX810 Portable DVD Player Logo
205 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
