Need a reset code
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
My 39" Westinghouse will not respond to the remote or buttons. It worked one day, I unplugged it and moved it to another room for a party.. 2 days later I plugged it in and now says "Please Run Channel Auto Scan" but will not allow any menu, input, channel, volume changes etc.. I have unplugged several times, putting the HDMI in slot one, then in #2 .. the the VGA cable... nothing. If it is plugged in it goes directly to the Auto Scan message but will not scan and will not even shut off.. Can anyone help??
Can someone help me please, my Westinghouse tv keep asking me for the access code , it never did this. I don't know the access code. It doesn't even let me hook up the antenna unless l out the access code
