I have a mitsubishi vs-5042 projection tv. It's old but still working. Is there a capacitor kit I can buy for this tv? And or is there something else I can do to keep it going. The projectors are a bit worn out, but it still works, I just want to give it some new strength.
  • 668 Answers
To my knowledge there is no capacitor kit . With this sets age, you would have to replace way too many to count to even consider doing.
It was a very fine product for it's time, but it may be time to let it go in peace.
Posted on Jul 18, 2009
Main power supply failur, how do i replace the part. where do i find it?
Try website like Tvrepairworld.com to buy a refurbish power supply board for the replacement or u have all the tools and know basic electronic and soldering buy a capacitor kit,they put together and replaced those dying capacitors.Capacitors are dying are alway bulging up or puffing up on it tops.
Mar 15, 2011 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi vs-60609 will not power on when it is pluged in the green light flashes three times. The manual says this means the microprocessor is functional. I ran the self diagnostic (as suggested in the...
Unplug,replug it an hour later tv now,resetting back to factory setting.Should work now,not than the DM power supply board is dead.Try website like Tvrepairwold.com to buy a capacitors kit to replaced those dead capacitors on the DM power supply board.
Sep 09, 2010 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi TV VS-55601S Convergence Problem
Convergence it dead.Must replaced convergence,know how to solders?Tries these websites for convergence kit.Tv repair World.com,or Tv Repair Kits.
Nov 17, 2009 | Mitsubishi VS-55601 55" Rear Projection...
My mitsubishi vs-5042 when i turn on power i here it click on but does not show pic or sound
temexchic213 : I
Had the same problem with my vs-5042, take of the front cover for the speakers and unscrew the flat wood panel inside you will see some wires right in front like blue,white,yellow ect. wiggle those wires all over in their make sure the TV is on but be care full. It worked on mine i just had to find the right one. Good luck.
Oct 30, 2009 | Televison & Video
I have sound but no picture it is a mitsubishi tv projection tv vs-5042 I was told it may need to cleaned not sure how to clean it or if that needs to be done
Hello more than likely you have lost heater voltage to your CRT, also may of lost High Voltage, but usually when you lose HV the set will shut down. This model is notorious for open Heater voltage resistors.
Have a technician come out and confirm.
Sep 27, 2009 | Televison & Video
VS-5042 Sound but no picture
It is not bulb, are you talking about the tube ? At the neck of the tube you will see some connections.Carefully abserve if any cracks on the solderings(we call them DRY SOLDER), then connect them with soldering iron. Always make sure you have disconnected the TV from the mains. If the problem still persists, you will need to reffer to a qualified and Experienced person. He need to look for the LOT section(Auxiary power supply), video amplifier, CRT sections.
Aug 23, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Mitsu vs-5042 Works then picture goes out. Thumping works sometim
If you occasionally have a picture then you stand a good chance of repairing this tv. There are bad grounds on the deflection board. Start with the board that has the flyback. I do not know the year of your tv. Sometimes the same model may have an option improvement than one couple of months earlier. The first suspected problem would be the vertical IC. In some cases this ic is located on the convergence board and in others the flyback board. It has seven pins and is the TDA version. Located on a large heatsink. Resolder this and any other grounds on both board. Some will tell you the P I P board is bad. This is a free standing board that can be removed and replaced. But please do the earlier option first.
Jun 28, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Black horizontal lines. Looks like I am looking through venetian blinds
OK this problem is caused by a failing electrolytic capacitor back in the power supply. It's job is to filter AC interfence from that voltage source. Locating the correct capacitor is something not for a do-it-yourselfer. A respectable tv shop experienced with Mitsubishi tv's can usually repair this problem in your home. Average repair cost would be between $200 and $300.
Apr 27, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
137 people viewed this question
Top Televison & Video Experts
Electro Med Services...
