We had a thunder Storm come thru and now the infinity control read "System Malfunction Call tech.
  • 1 more comment
  • robertpelech Jul 18, 2009
    Thanks Rus, I turned off the circuit breaker and it ran for about 2-3 minutes and then I got the same message again.
    Thanks Russ, I found two buss fuses non-35 between the ciruit breaker and the compress. One of the fuses was bad, replaced it and the unit works fine now. I guess whoever install the unit put the extra set of fuses as added satefy for the unit. I really appreaciate your assistance in this matter.
  • 614 Answers
Turn off power to complete system and then restart it should clear. Rus Carrier Dealer
Posted on Jul 18, 2009
  • James Stopp
    James Stopp Jul 18, 2009
    Sorry with the Infinity Systems they are very touchy. Call a service tech. The infinity I sell comes with extended warranty. Should not cost you anything fo repair. Russ
06 Nissan maxima code 1148
Definition of Diagnostic Trouble Code P1148 Audi: Oxygen Control (Bank 2) System too rich Ford: Closed Loop Control Malfunction Infiniti: Closed Loop (Bank 1) Land Rover: Lambda trim post-catalyst bank 1.Short circuit to ground Lincoln: Closed Loop Control Malfunction Mazda: Generator 2 Control Circuit Mercedes: IAT Sensor Circuit Malfunction, Bank 2 Mercury: Closed Loop Control Malfunction Nissan: Closed Loop Volkswagen: Oxygen Control (Bank 2) System too rich
Jul 09, 2015 | Nissan Cars & Trucks
Lights blinking
The best information you could get is from Carrier. Here's their website:
http://www.carrier.com/homecomfort/en/us/for-owners/
There is a toll free number to call 1-800-Carrier (1-800-227-7437)
Apr 27, 2014 | Carrier Performance 2 Stage 17 Series 2.0...
Code p1443
without knowing your make or model:
  • p1443
    Evaporative Emission Control System Control Valve
  • audi
    EGR Valve Position Sensor Signal Too Low
  • bmw
    Leakage Diagnostic Pump Control Circuit Signal High
  • ford
    EVAP Control System Purge Control Solenoid or Purge Control Valve Fault
  • hyundi
    EVAP System Tank Cap Missing
  • infinity
  • lexus
    Secondary Air Injection Vacuum Switching Valve Circuit Malfunction Bank 2
  • mazda
    Evaporative Emission Control System Large leak detected
  • mitsubishi
    EVAP Purge Control Valve 2 Circuit Malfunction
  • nissan
  • suburu
    Evaporative Emission Control System Vent Control Function Problem
  • suzuki
    EVAP Purge Control Valve Malfunction- Stuck Open
  • toyota
  • volkswagon
  • Dec 07, 2013 | Cars & Trucks
    P1446 infiniti FX35
    for your infiniti FX35,
    P1446 - Infiniti Type Powertrain - Manufacturer Controlled DTC - Manufacturer Controlled Description Evaporative emission (EVAP) canister purge control valve - malfunction
    Cause Wiring, EVAP valve, mechanical fault, ECM
    or you can ask the 24 hrs live technical support http://www.spobd2.com/service/, they will like to help you, good luck
    Jul 06, 2013 | Infiniti Cars & Trucks
    Infiniti i30t emission control system malfunction light steady on
    Check for codes
    One would assume you have done that
    for the last 30 years
    Google the codes & get an idea what system
    has a malfunction
    Then have a repair shop start all over & diagnose it properly
    Feb 23, 2013 | Cars & Trucks
    How do I fix fault code po443?
    P0443 INFINITI - EVAP Canister Purge Volume Control Solenoid Valve
    Possible causes- EVAP control system pressure sensor
    - Damage harness or connectors to the Purge Control Valve
    - The valve circuit is open or shorted
    - EVAP canister purge volume control solenoid valve may be faulty (The valve is stuck open)
    Tech notes It's a very common problem with Infiniti vehicles. If the harness is not damaged, it's very likely that the problem is the canister purge volume control solenoid valve.
    Read more: http://engine-codes.com/p0443_infiniti.html#ixzz1yqKLq8YE
    Jun 25, 2012 | Infiniti J30 Cars & Trucks
    After a thunder storm, my laptop will not power on. Any suggestions on possible causes, such as malfunction issues or any faulty parts that may cause this?
    you may have had a power surge test your PSU and motherboard + INSURANCE policies house and content
    hope this helps
    Aug 10, 2010 | Computers & Internet
    Lightning Storm/Affinity Washer
    During a lightning storm, a lightning strike could have induced a high voltage surge in your incoming power lines. Left unprotected from these power surges, the weakest link ( normally low voltage electronic controls) are the most susceptable. Just because you had power available at the wall receptacle after a storm doesn't mean that your washer control system wasn't exposed to one of these surges and got damaged. On the contrary, it is extremely likely that the washer took a 'hit' and was damaged.Other devices plugged into the same receptacle may have survived that hit because electricity travels the path of least resistance.. In this case.. that path may have been thru your washer.. My point being is that your washer could have sustained a power surge and was damaged so don't rule that out. Of course, that surge could have taken an internal fuse or other component out too..
    Jul 17, 2008 | Frigidaire Affinity ATF7000E Front Load...
    JVC 48" HDTV Ready Widescreen Projection TV
    Terrible thunder storm can create electrict shock to our appliances thats why we recomended that if you donot use your tv pls unplug it, and it mostly if you use outdoor antena when the thunder hit the tv will damage.
    Jan 10, 2008 | JVC HD-61Z575 61" Rear Projection...
    Heating & Cooling Logo
    288 people viewed this question
    Top Heating & Cooling Experts
    paulcarew
    Dan Webster
    Dan Webster
    Donni Steen
