SOURCE: How to set user codes
Hello sir ; Press user tool key, then touch on screenfor copier system setting and follow the instruction to setting.
SOURCE: i have gestetner 2722ztd copier when i replace the
Please check after replace the continuity the expo lamp,expo thermofuse.The E codes are displayed in the copy counter.To display both digits of the E codes press the enter key.
E 11 - Exposure lamp error.Possible cause: expo lamp open,expo thermofuse open,power supply defective,main board defective.
E 12 - Exposure lamp error.Posible cause:AC drive board defective,main board defective.
E 13 =Zero cross signal error.Possible cause:main board,power supply defective,zero cross line open or the conector on the main board is not conected correctly.
For reset turn ON/OFF the main switch unplugged wait 10sec and turn ON or:turn ON the main switch,turn DIP switch 101-1 ON/OFF and turn the main switch OFF/ON.The DIP switch is located in the rear parts into the main board.
SOURCE: how can I solve error code E-1 on my gestetner
u need to get a full error code press star or hash key to get the rest
my gues its 101 which is exposure lamp brocken or something to do with optics
