Question about Sony Cyber-Shot DSC-T1 Digital Camera
The image is blurred, i couldn't arrange anything from teh settings, it seems to be from the lenses
  • 123 Answers
No.the camera is damaged you want to go to a near by service center
Posted on Jul 18, 2009
My casio exilim camera captures images and save it blurred, seems like the lens is affected pls what can I do
No model? please make sure your lens is switched to auto focus (AF)
When the lens is smudged, please only clean it with fluid special for lenses. Never use normal glass cleaners, because lenses do have coatings that come of easy with normal house hold cleanres. If you already tried cleaning the lens that way, I think we have found what is wrong. Without the coating the lens can't give good pictures.
Mar 28, 2015 | Casio Cameras
Blurred image on display panel itself
I already did answer this? But I forgot the point, If your lens is dirty (must be bad) you only can clean it with a special lens pen or a micro five cloth, if a special fluid is used. Never clean lenses with anything else, because the coating on the lens is easy damaged. When the coating is damaged, you never will get any clear pictures os videos.
Jan 13, 2014 | Sanyo Xacti DSC-S1 / VPC-S1 Digital Camera
Blurry pictures of moving wildlife
check shutter speed, problem to slow, increase aperture if light level permits hand shake can also blur image.If in full auto mode change to manual settings mount camera onto tripod THIS WILL SOLVE HAND SHAKE PROBLEMS the most common cause of blurred images.
Nov 22, 2013 | Canon EF 75-300mm f/4-5.6 IS USM Lens
I'm getting blurred images. what will be the
Blur images can caused dirty lenses please clean the lenses if the problem persist then take to any service center and do cleaning of the internal parts as sometimes due to moisture this type of problems are created.
Feb 16, 2010 | Canon PowerShot A710 IS Digital Camera
Focus is blurred yet lense works in /out
check and see the min and max distance for focus in the manual. also slight movement can cause this also.
Oct 16, 2009 | Sony Cyber-shot DSC-S600 Digital Camera
Blurred Images with Olympus E520
When operating any digital camera, the camera tries to capture the best focus and exposure for that particular scene. By pressing the shutter button half-way down, the focus and exposure is being set. There will be a green circle on the upper left hand corner of the screen, then your camera is ready to take the picture. Slowly depress the shutter the rest of the way down to take the picture.
Mar 23, 2009 | Olympus Zuiko 70-300mm f/4-5.6 Digital ED...
Blur image in viewfinder and LCD display
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Dec 23, 2007 | Canon PowerShot S1 IS Digital Camera
When i dont use the flash on a nikon it is blured
When taking a picture the camera needs a certain amount of light to hit the sensor before it can record a good image. If you are outdoors in the sun and the camera still takes blurred pictures due to a long exposure time then there is a malfunction. In bright lighting situations the camera should decide on its own not to use the flash. For indoor situations the camera has to either supplament the available light with the flash, or increase the duration of exposure to collect more of the existing light. There is no way around it - the sensor needs a certain amount of light to create a quality image. On some cameras you can override the shutter speed setting and force a fast exposure but without proper lighting you will just end up with dark images. You might also be able to override the F setting to the lowest possible value which would let in the most light. However, these cameras are generally very good at deciding how much light they need to take a quality image. If the flash is set to auto and the camera decides to use it then there is simply not enough light to get an exposure with a fast shutter time. This is one of the factors that gets better the more expensive the equipment is. Higher end point and shoot units and SLR units can collect more of the available light with their larger lenses and thus get good exposures in lower light conditions while still maintaining fast shutter speeds. Additionally "image stabilized" cameras help compensate for this situation by electronically assisting the photographer in stabilizing the image - allowing longer exposure times to be shot hand-held. You could also try a tripod if that is appropriate to your needs, that would help you shoot longer exposures in low light without so much image-wide blurring. Of course anything in motion will still blur. David Millier Advance Camera Repair
Feb 18, 2007 | Nikon COOLPIX S6 Digital Camera
Sony Cyber-Shot DSC-T1 Digital Camera Logo
74 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
