Question about Compaq Presario 5000 PC Desktop
Dead mouse port
Hi, my keyboard and mouse ports are dead,no lights on the key board.I keep getting the "no mouse found" message, so I tried the serial port with a converter with no luck.I was told it could be a fuse on the mother board,please help!
    An expert who has answered 500 questions.
  • 620 Answers
Good day Godlyman
A lot near problem with your PS2 port, and Keyboard /Mouse.port
sometimes depending on the MOBO, you can use , if you have no money to buy a new MOBO , buy a USB mouse and keyboard. that should help you to this point. But you also check another mouse or keyboard, and see if work, change according.
good luck
Posted on Nov 19, 2007
I think your motherboard is got corrupted so please check it with another motherboard. if it solvs then of until change the motherboard.
    Problem Solver:
  • 9 Answers
Had u checked it with new mouse..
If showing same problem.. u need to replace the motherboard..
My usb ports do not working.When I put my mouse in it, the mouse lights become on but in the desktop the pointer is on its place and no hardware are found.I check 3 more mouse and key boards but the...
Follow the steps given below to refresh USB ports.
1. Right-click My Computer icon on the desktop, and then select Properties.
2. Click the Hardware tab.
3. Click the Device Manager button.
4. Click the plus (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click OK to confirm the removal of the device.
Please note, repeat Steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the computer restarts, a "Windows has detected new or added hardware" message window will open.
The above steps will refresh the USB ports.
Now connect the USB devices like mouse, video camera, your external usb hard disk...usb hubs...whatever you like and the drivers should install automatically.
Tip: It is always recommended to connect the main usb devices at the rear end usb port, as they require more power to initiate.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 01, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Intel d 865 gsa mother board is working but not display no beep what is the problem
i thinks it's not working, check again.....
no display, no beep.....simple symptom of a dead MB
the quality of the MB is all components will work together, even if one component in it fails the MB is dead.....
this rule is not applicable to the following devices in the MB
inbuilt sound cards, or
either of the USB ports or
mouse port, keyboard port
As you can use an external device like a USB sound adaptor insted of the internal sound card for your speaker/sound.
The same goes for mouse and keyboard, you can buy keyboards/mouse that work thru USB
The same is of a USB port, if one of the USB ports fail you have the other ports to use, if all of the USB ports fail then you can use a external USB connector to a LAN port and make the LAN port a USB device.
also.....there is no option..... that you can change one of the components.....they all are embeded in the circuit board, it's cost effective to get a new MB than repair the defective component.....
all the best
Nov 18, 2010 | Intel Motherboard
My keyboard will not work
Keyboard Is Dirty:
Keyboards should be cleaned with "spray-n-wipe" cleaner and a cloth or tissue on a monthly basis. Ensure that computer is not powered up while cleaning the keyboard. Compressed air can also be used to clean between the keyboard keys. Another tip: clean the keys with a cotton swab dipped in alcohol.
"Keyboard Not Found" Message:
Your keyboard is not plugged into the computer securely. Unplug it and plug it back in and the problem should go away. If this doesn't work, follow procedure: "Computer isn't taking inputs from keyboard" (below).
Key Is Stuck:
1. If a key does not work or is stuck in the down position, you may try to remove it with a CPU "chip puller" tool. These simple "L" shaped tools are great at pulling out keys. Once you've pulled out the stuck key, you can try to stretch the spring to "reanimate" its action.
Computer Isn't Taking Inputs From Keyboard
1. Is keyboard connected to computer? Ensure that the keyboard is plugged into the keyboard jack and not into the mouse jack. If the keyboard was unplugged, plug it back in and reboot the computer.
2. If the keyboard still doesn't work on boot-up, power down the computer and try to borrow a friend's known-good keyboard for troubleshooting. Plug the new keyboard up and boot up the computer. If the new keyboard works, the old keyboard is bad and needs to be replaced.
3. If the known-good keyboard doesn't work, check your BIOS to make sure it sees the keyboard. It should say, "installed." If the BIOS recognizes the keyboard, then you probably have a bad keyboard port.
I Plugged Keyboard Into Mouse Port
1. Many mice and keyboards today use a PS/2 connector
. If you plugged your keyboard into the mouse port (or viceversa), follow steps 2 and 3.
2. Shut down the computer and plug the keyboard into the keyboard port. The keyboard port is usually marked with a "keyboard" symbol. Plug the mouse into the mouse port (usually marked with a mouse symbol).
3. Reboot the computer; the keyboard should work now. If keyboard doesn't work, check your BIOS to make sure the BIOS recognizes the keyboard. You should see the words, "installed" or "enabled" under the keyboard.
4. If the BIOS recognizes the keyboard but it still doesn't work, you may have a bad keyboard port.
I Spilled a drink on my keyboard!
1. If you spill any liquid in the keyboard, turn it upside down ASAP. Drain all the water out of the keyboard, shaking it if necessary. If you've spilled water into the keyboard, just let it dry. You may use a hair dryer to dry out area under the keys (remember, too much heat and you could damage the electrical components).
2. If you've spilled a soda into the keyboard, completely rinse it in warm water. No soap please! You may use a hair dryer at this point or just let it dry for 2 days. Ensure the keyboard is perfectly DRY before you attempt to use it again. Don't plug a wet keyboard into electrical equipment. Think safety.
5. If the keyboard still doesn't work, replace the keyboard.
Nov 13, 2010 | Dell Computers & Internet
Ok just installed new hard drive for Gateway ES2 300x...mouse and keyboard do not work now...keep in mind they both worked fine before installing new hard drive...what is going on?
ithink it is not related to the hdd.check port of board mouse and key bord changing other if not work usb port look deveice manager it is installor not?
Oct 28, 2009 | Gateway 2520915 Keyboard
I cant get my logitech desktop ex 100 keyboard to connect, but the mouse does...anyhelp would be appriciated thanks
we should keep battery in mouse and key board. we get three thing . mouse key bord and usb conneter or usb wire less relay. when we keep it on usb port of computer mouse and key bord auto matic detected we seeon screen ( nepal)
Oct 11, 2009 | Logitech Cordless Desktop Ex100
How to turn keyboard and mouse on
make sure there is new batteries in both the mouse and keyboard. Also the wireless receiever that connects to the computer is responding as well.
After you get new batteries put in and also have the receiever plugged in. press the caps lock, num lock keys and see if they light up on the receiver. If they light up then things are working, if they don't then bring up the notepad and see if any of the keys show up in notepad when you type and also see if the cursor on the screen moves for your mouse.
Hopefully both of them will work once you change batteries. If both don't work after changing batteries then you'll need to get a new wireless keyboard/mouse kit.
Jun 29, 2009 | Logitech Wireless Access Duo Optical...
PS2 keyboard mouse not functioning
First look usb or pst driver is stall or not. if install your port may be damage or shourt. then check usinge y- cable. where one side usb port and another side we get ps2and usb. then we use mouse and key board once atime.. . ithink u solvev your problem. if not .there is another way . you can add usb card in *********** bord . Which help you to operate usb key board and mouse once time. thanks
Jun 17, 2009 | Acer Aspire™ T180 PC Desktop
Serial keyboard
have you tried just plugging keyboard have usually 2 ext ports one for ext keyboard and one for mouse you can also use usb keyboard/mouse.
if you have a problem with existing keyboard have you tried the on screen keyboard....start,all programs,accessories,accessability,on screen keyboard..when u say serial port do u mean the com port..
for com port you have to assign keyboard and you will need drivers cos not recognised as plug and play
Jan 22, 2009 | Dell Latitude D600 Notebook
Mouse, keyboard lockup
Install Linux.If u keep M$ winblow$ yer windows will blow again and again.
Mar 12, 2008 | Computers & Internet
Compaq Presario 5000 PC Desktop Logo
73 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
