Question about Car Audio & Video
Connections for speakers isnt just a positive and negative, its a connection block with four wires, how can i still fit new speakers
    Problem Solver:
  • 5 Answers
U should check out in which point the negative and positive wires fits properly and give sound out put the 2 wires r for woofer nd two are foe speakers
Posted on Jul 18, 2009
Hook up radio to jeep cherokee
buy a 12 volt lamp tester (like a screw driver)check the wires when car ignition switch is turned on ,connect the wire side of tester to metal ground of ur car which supposed to be negative and other side of tested pin to the wires jack of ur car which is for radio connection previously,find out 2 connection points which are positive terminals one lights when igni switch is turned on the other one is permanent power terminal.now there are three wires of ur new radio one is black which should be connected to ground or metal body of ur car negative terminla and yellow connected to permanet power terminal and red one should be connected to power turned on with the swith which is called switched power
.now try to find out other four groups of terminal two for front speaker two for rear speaker each speaker has two wires ,can find out the connections by connecting a dry battery cell to the wires to identify which wires of speakers sound when battery is connected ,front pair of wires is for front left grey pair is for right front green pair of wires of ur new stereo is for left rear speaker and purple or blue pair is for right rear speaker
.these colors are globally known .the wires of speakers must not mixed with each other
black is for ground negative red is witched power and yellow for permanent power.
donot use long screws to fit ur new radio .Best of luck
Nov 18, 2013 | JVC KD-S5050 CD Player
I cannot find a diagram of how to wire a boss audio phantom p128dc dual voice coil subwoofer with there being 4 binding posts on each side of the woofer.
I will assume that you mean four posts total and not four on each side. It's a dual voice coil and you will need a jumper. Take a small strip of speaker wire and connect the positve and negative of one coil together. Take a close look, there is a dot on one positive and a dot on one negative. Jump these two together. Now wire the other positive and negative to the amp's positive and negative.
May 24, 2011 | BOSS AUDIO SYSTEMS P128DC Car Speaker
SOMEONE GAVE ME SOME BOSE 6X9 CAR AUDIO SPEAKERS. THE SPEAKER HAS FOUR HOOK UP WIRES. TWO TO THE TOP OF THE SPEAKER AND TWO TO THE BOTTOM. MY QUESTION IS WHEN INSTALLING THESE SPEAKERS IS IT OK TO MAKE...
Hook up the speaker wire like this...Positive wire to positive terminal on top then run a loop from the top positive to the bottom positive. Next run the negative wire to the negative terminal on the bottom then run a loop from the bottom negative to the top negative.
Dec 06, 2010 | Bose Car Audio & Video
I am attempting to wire an original mrk3 escort radio cassette player with a non-existant wiring block in my 1981 escort. i have made up a live feed via the fuse box and a negative feed as well the thing...
First of all the positive feed will go inline with a fuse to your ignition wire down in the fuse box area, drivers side kick panel if you can locate an ignition switch wire, put a test light to the thicker wires found in the kick panel under the carpet or if visible to the eye. Usually in ford vehicles the ignition wire is RED with a Light Green stripe and 12V+ Constant is Yellow which in your case you will not use. The negative feed or black wire is ground and that will go directly to the chassis ground on the vehicle or any ground wire you can find. The remaining wires will go to your speakers. Let me know if this works for you, I need to know if you have speakers and what colors are their wires. Let me know if you get stuck.
Good luck,
Lex..
May 20, 2010 | Car Audio & Video
What wires are for what on my kd-g200
The cables for you In-Car stereo are as follows:
Black - Earth to to the chassis.
Yellow - Live that should be connected directly to the car battery and not the igniton.
Red - To an accessory terminal in the fuse block.
Blue / White stripe - To remote antenna (if fitted)
White / Black stripe - Front left speaker (negative terminal)
White - Front left speaker (positive terminal)
Grey / Black stripe - Front right speaker (negative terminal)
Grey - Front right speaker (positive terminal)
Green / Black stripe - Rear left speaker (negative terminal)
Green - Rear left speaker (positive terminal)
Purple / Black stripe - Rear right speaker (negative terminal)
Purple = Rear right speaker (positive terminal)
That covers all off the cables that you should have with the car stereo.
Apr 11, 2010 | JVC KD-G200 CD Player
How do i properly connect the wires for a JVC SX-SW5th
Connect the speaker output of the reciever to the input of the speaker. Make sure you connect negative receiver output to negative speaker input and positive receiver output to positive speaker input.
Sep 15, 2009 | Audio Players & Recorders
I have had a set of Polk Audio SDA1 speakers that I had attached to an old but great Pioneer SPEC-1 pre-amp and SPEC-2 power amp. The old speakers had one connection for the right speaker positive and...
bi-wiring requires the removal of the copper jumpers between the hi and low speaker terminals. you can use two wire pairs twisted together at amp out connections and the four separate ends at each speaker, but the quality of sound will not be as good as buying quality bi-wire cables. But a pair of quality single set of wires at each speaker would be fine, but put jumpers back on and attach to the top terminals, they are designed that way. bi-wiring does allow the crossover to put out a little better sound. Hooking up four sets of wires to the a and b speaker terminals sounds bad. i have had alot of trouble with my rti10's and learned the hard way that it is best to pay more for wires with quality terminations.
Jun 21, 2009 | Polk Audio RTi A7 Main / Stereo Speaker
Speaker wiring
Here' s the colors to look for in the dash:
1994 Ford Probe Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/White
Car Radio Ground Wire: Black/Pink
Car Radio Illumination Wire: Orange
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Light Green/Yellow
Left Front Speaker Positive Wire (+): Blue/Green
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): Blue/Black
Right Front Speaker Negative Wire (-): Blue/Orange
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Green/Orange
Right Rear Speaker Positive Wire (+): Green/Yellow
Right Rear Speaker Negative Wire (-): Green/Blue
Jun 03, 2009 | 1994 Ford Probe
Need a wiring diagram
HI,
1999 GMC Sierra Truck Radio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
please rate my suggestion....
May 22, 2009 | Car Audio & Video
Speakers wont fit in car
Look at the old speakers to find out which cable is positive (+) and the other negative (-). Cut the connectors off one at a time, strip the wires, connect them to your new speakers. Negative to negative positive with positive then tape them good with black electrical tape. That's all! If the cables are to short connect more speaker wire.
May 07, 2009 | Car Audio & Video
Car Audio & Video Logo
47 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
