Question about Yamaha Full-Size Keyboard
Sustain pedal on Yamaha DGX not working
When pedal is plugged into jack, the tones are sustained even if I'm not pressing the pedal. Ironically, when I do press the pedal, the tones are not sustained. Do believe the problem does not lie in the pedal itself.
Hi, I had the same problem, but I have an easy solution. I am trying to connect an FC5 to a Casio CTK-3000. The problem is open vs closed circuit in the pedal and the way that the casio interprets the info. Paulll's fix is correct, but you do not have to use soldering. Simply remove the cover, unscrew the silver screw, and you will notice that the black contraption that holds the two metal strips has one side that pops off. Pop off this side.
Now, notice that the short strip is on top and the long strip is on the bottom. The way the strips bend mean that the circuit is closed when there is no pressure on the pedal. When you press the pedal, the white knob on the long strip pushes the long strip down and breaks the connection with the short strip.
What you need to do now is remove the two strips and slide them back into the black contraption with the long strip on top and the short strip on the bottom. The white knob on the long strip should be facing up. Make sure when you do this that you hook the short strip over that little horizontal black plastic rod so that it will easily contact the long strip when the long strip is pressed down.
By bending the top (long) strip a little, you can make it so that the long strip does not touch the bottom (short) strip in the relaxed position. Make sure that the ends of the strips where the wires join do not touch each other either. You now have an open circuit in the relaxed position, which is what Casio recognizes as NO PEDAL.
Pop the side piece back on the black contraption and screw the black contraption back in place with the silver screw. Set the spring back in place and reattach the 'pedal'. Make sure that there is enough clearance between the top of the white knob and the inside of the pedal so that the circuit remains open in the relaxed position.
Now, if the two strips are NOT touching each other, when you plug it into your Casio, the Casio will not recognize the pedal, which is good. When you push on the pedal, you will close the circuit and the Casio will recognize the pedal.
If you push on the pedal and nothing happens, then the two strips are not contacting each other in the fully pressed position. Take the unit apart and try again.
If the Casio still recognizes the pedal even though you are not pushing on it, then the two strips are contacting each other at any place along their length. Take the unit apart and try again.
Enjoy your new working pedal!
Greg
PS. If you Casio won't work with your computer, there is a fix out there for that too. It involves removing (or renaming) some files that Logitech loads on to your computer when you install a webcam. Weird, but true.
Posted on Jan 27, 2010
  • 1 more comment
  • cswag Dec 31, 2010
    Hey thanks Gregberd this solution worked for my Yamaha FC4 as well with the exact same procedure. Very thorough instructions thank you!
    A couple of things to note (at least on the FC4)
    1. The side of the black casing that is removable has what looks like tiny screws. Don't try to remove these, the side just pops off
    2. BE CAREFUL not to snap the wire. Mine was VERY delicate and snapped.
    Thanks again!
  • lonnie Jul 29, 2012
    THANKS!!! this procedure worked with my fc-4 pedal.
    Thanks!! this helped with my Yamaha Fc-4 pedal.
I had the same problem, its to do with the polarity of the pedal. My pedal had a polarity switch on the bottom just flick this over and this should fix the problem. Otherwise another solution was to hold the pedal down and turn the keyboard on.
Posted on Jul 23, 2009
  • 4 Answers
I had the exact same problem with my Casio keyboard and a Yamaha sustain pedal I bought.
I'm not an electrical genius, but I was able to get it to work by opening it up and doing a little modification. Of course I first just tried switching the white wire with the black one but that didn't change anything at all when I tried it. It turns out the Casio wants the circuit completed to sustain, and broken for no sustain, which is the opposite of what the Yamaha pedal does.
I opened it up and mine had three three flat metal strips let's call them Top, Middle and Bottom. The Middle and Bottom ones were joined together on the right side, and the Middle and Top ones were touching on the left side when the pedal was not pressed. These seperated when the pedal was pressed, thereby breaking the circuit because the wires were on the top plate and on the joined Middle/Bottom plate.
So to flip it I:
1. Unsoldered the Bottom wire
2. Cut apart the Bottom and Middle plates on the right.
3. Bent the Middle plate on the right to touch the Top plate instead and soldered those together.
4. Soldered the Bottom wire back on.
That's it! Once I figured it out, it took only a few minutes to fix.
Paul
Posted on Aug 15, 2009
P90 sustain sound won't stop some times when am playing
You could have-
dirty contacts on the switch inside the pedal
dirty contacts in the jack the pedal cable plugs into
a cold/loose solder joint where the cable connects to the plug or to the switch.
If you rule those all out it's an internal problem with the pedal, which you can check by using another pedal, or it's internal to the P90, which will need to go to the shop.
Feb 25, 2015 | Yamaha Music
I replaced sustain pedal jack...now sustain is on ALL the time, even with pedal unplugged
When you replaced it, you either have the wrong jack, wired it wrong or it is shorted out where you connected it. Recheck the connections.
Dec 18, 2014 | Casio Wk500 Wk-500 Keyboard Workstation...
I plugged a sustain pedal from my Yamaha DX7 on the dumper pedal jack but it works opposite as it should (by pressing the pedal sound cancels as i release the keys; when pedal runs completely free sounds...
every sustain pedal got different polarity.. normally just go to global setting on your keyboard and change damper polarity setting to plus or minus (select which one work with your sustain padle).
Jul 26, 2011 | Korg M50 73 Note Workstation
Fc4 sustain pedal is in "sustain" mode at all times -- it won't release the sustained notes. I tried plugging the pedal in (to a roland ep-9) before powering up and had the same problem.
Sorry, but the Yamaha pedal has the opposite sense (it is a normally open contact) than what is REQUIRED by Roland equipment. Roland requires a Normally Closed contact. Unfortunately, one is confused because the Roland jack for the sustain shorts itself to no sustain when you unplug a pedal. SOMETIMES one can open a pedal and with soldering iron change a wire to reverse the pedal sense IF the particular pedal has both contacts available.
Jun 16, 2011 | Yamaha FC4 Piano Style Sustain Pedal
Hello- my P95 sustain pedal does not work when plugged in but the sustain works when you disconnect the cord from the back of the keyborad
This is confusing... you say "the sustain works when you disconnect the cord"? How can that happen? and doesn't work when it is plugged in.
MOST sustain pedal problems are due to people using a different pedal than the keyboard is designed to use. It is very common that someone tries to use a Roland sustain pedal on a Yamaha and oof course it doesn't work because the Roland pedal is normally closed and Yamaha usually requires a normally open contact.
A FEW keyboards now check the state of the pedal input when power is first turned on and configure the pedal polarity accordingly. For these keyboards, make sure the pedal is plugged in before power is turned on.
Apr 02, 2011 | Yamaha P95 Digital Piano
A bought an Yamaha DGX 640 grand a week before and the note sustain for a longer duration and overlaps with the current playing notes. I checked the sustain in the function setting and it is also showing ...
The function setting is for the PANEL sustain (Page 68 of your manual)
The other method of sustain is by footswitch or pedal option. See page 13.
If you use a footswitch, it needs to be a normally open contact type. If you plug a Roland type in, it is opposite polarity and will sustain UNLESS the pedal is pressed. Make sure nothing else is plugged in the sustain jack... headphones that are inadvertently plugged in there would sustain.
Mar 06, 2011 | Yamaha DGX640 Music Keyboard
Hi. I'm Using PX330 as a midi controller that plays "Galaxy pianos" in cubase 5. I'm interested in buying a continuous sustain pedal (the one I got with the piano is an On\Off pedal). can you...
The Yamaha FC-3 uses a TRS (three conductor plug). The PX330 does NOT use TRS jacks for the sustain and sostenuto pedals so they are NOT compatible with the Yamaha FC-3. Therefore I would conclude that continous sustain that the Yamaha pedal would be used for is NOT supported.
Feb 15, 2011 | Casio Privia Keyboard Case
Sustain is in reverse yamaha p-85
I have the same problem, But I have been using the same pedal since new. Infact it came with this pedal. Then suddenly it started doing this. Could I have changed soem setting by accident?
Jul 08, 2009 | Music
Sustain Pedal Opposite Effect
I found that if I plug in the sustain pedal BEFORE turning the power on, it works fine. If I plug in the sustain pedal AFTER turning the power on, then it works in the opposite way. Probably just the design. So I would try playing with that before doing anything drastic.
Feb 16, 2009 | Yamaha Full-Size Keyboard
Yamaha Full-Size Keyboard Logo
1,877 people viewed this question
Top Yamaha Music Experts
Matthew Spark
Matthew Spark
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
