Question about Karcher K 5.85 M Electric Pressure Washer
How do I fix a problem with my Karcher K4 pressure washer.
I see my pressure washer without any problems but when I went to use it again the next day only a very small amount of water is coming out and so cannot use it?? Please help. Thanks. Sharon
  • Lucy Gibson
    Lucy Gibson Aug 17, 2017
    Sharon, I'm sorry that your pressure washer is only allowing a small amount of water to come out. My parents just noticed that their pressure washer is also broken. It sounds like they might need to replace a few parts. I'll have to do some research to make sure and get the right items for their particular make and model. http://quickstoppressurewashingsupplies....
    Top Expert:
  • Karcher Master
  • 11,573 Answers
Sharon, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Grumpy gits and useful tips
How to FIX Karcher pressure washer
Karcher North America Home Garden Online Help
Posted on Aug 09, 2016
I used my K4 pressure washer without any problems but when I tried using it again the next day there is hardly any water coming out and so can't use it. Please help. Thanks. Sharon
Sharon, check to sure you are getting sufficient water to machine open tap all the way, also check the small filter where garden hose connects to power washer is not plugged. You may have to have a repair tech. diagnose and estimate repair if problem not solved above. Check the attached links,instruction and guides, Good luck
Troubleshooting
Aug 09, 2016 | Garden
How do I fix my pressure washer when the high pressure hose keeps blowing off.
If hose fits over a hose barb try using a hose clamp from any auto supply store Or replace the hose barb GL
Oct 08, 2015 | Karcher K 367 M 1750 PSI 15 GPM Electric...
Karcher 2500ph pressure washer spill valve has been replaced pull wand trigger pressure good for 3 or 4 seconds drops off for a second or 2 goes back to good pressure for 3 or 4 seconds drops off again for...
If you have a Karcher then you should always post your machines barcode.
full article on nozzles :
http://repairshed.blogspot.com/2013/09/pressure-washer-lance-nozzles-what-you.html
The spill valve operates at approx 20% higher than specified pressure washer operating pressure. If you have any lance issues then the pressure could be running higher than specified (machine running at same pressure as spill valve operation pressure)
your machine produces a fixed flowrate of water (maybe 8 litres per minute) and your nozzle is a fixed size. the diameter of the nozzle determines the back pressure. A piece of debris could further close your nozzle orifice and increase the back pressure. Using a new lance that has the wrong nozzle fitted can also cause this issue.
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Aug 15, 2013 | Garden
Hi Bought karcher k5.80 some time ago It didnt work well and I put it away however got it out again its blasts then trickles water on for couple of seconds the off again. What if anything can I do?
I got the same problem as msellar1. Anyone got any ideas to resolve??? medcalf.chris@virgin.net.
Thanks.
Basically, turning the spray nozzle to reduce the pressure works - but this is next to useless for cleaning anything. I fixed the leaky tap in case air was getting into the system but no. It's been like it since day 1, on and off, but now more stop & start than ever! Maybe thats why it was reduced to I think £150 from £275???
May 07, 2010 | Karcher Garden
Karcher K4
think it must be faulty power
Jun 10, 2008 | Karcher 2500 PSI Pressure Washer
Karcher K 5.85 M Electric Pressure Washer Logo
300 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
