SOURCE: John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
SOURCE: Why would my sst18 john deere zero turn steer in
there is a servo under the main body on the right side win sitting in seat thats broken from [email protected]
SOURCE: John Deere 4210 brakes are locked up
On both sides of trans housing just in front of axles is where brake shafts go into trans.To fix this you have to spray alot of lube between shaft and housing while trying to rotate shaft.This may take hours to free up and also check for the return springs to still be hooked up to lower roll bar frame.I have seen this alot in the 4000 series tractors.
look at the plastic coupler that holds the shaft down to the gear
My skid steer has brakes. There is a brake disc. You have to pull the drive motor of and its in between the motor and the drive sprockets in a brake housing.
if that is the case , it will be a big job and a workshop manual will be a definite requirement if you do the job yourself
