Question about Car Audio & Video
I have a vm 9412 in a 05 nissian sentra. when i turn my radio on it comes on for a half second then then it goes back off. it does that repeatedly i know that i supose to put a code in but it doesnt say on long enough for me to put it in can u please help
  • 3,230 Answers
You need to contact your car dealer to get that code. they will provide you free of cost.
or you follow the below link to get the code -
http://www.radio-code.com/?gclid=CKnF4PP65pkCFRxNagodckU4Rg
Good Luck!!
Thanks
Posted on Jul 18, 2009
Hello I have a 2005 Nissian Sentra S it has recently started cutting off while I'm driving . I took the car to Auto Zone where I was given a code of P0335 which was a crank shaft sensor. I replac
Unfortunately, replacing a sensor only fixes the problem about half the time. The code means the computer is not getting a signal from the sensor, not that the sensor has failed.
The problem could be in the wiring, or the part that the sensor gets the signal from.
Feb 25, 2013 | 2005 Nissan Sentra
Oxygen sensor for a nissian Sentra, how many do I have?
2 sensors, first one is up stream for air fuel metering and second is down stream for converter readings and air fuel mixture.
Jan 28, 2011 | 1996 Nissan Sentra
07 Nissian Sentra will not start
Spray some starting fluid into the airbox where the air hose goes into the injector. You only need a one second squirt, if it starts then shuts off, it's your fuel pump, or a clogged filter. If it doesn't start, pull a spark plug wire and put a screwdriver in the end and set it a couple millimeters from the engine block or a body panel. DO NOT TOUCH IT WHILE THE STARTER IS BEING TURNED! Have someone turn the starter and see if a spark jumps across to the engine or body panel. If there is no spark jumping then your problem is most likely the ignition module, but could be a host of things in this world of computer driven cars. Hopefully it's an easy fix like the fuel filter. Good luck.
Apr 15, 2010 | 2007 Nissan Sentra 2.0 SL Sedan
2003 nissian sentra car will only go 10 mph i
I had that exact problem on my 03 sentra gxe 1.8L , turned out to be the alternator had died and it was trying to use the battery. Are you having any electrical problems? Because when this was going on with me, the lights would barely work inside and outside the car - new alternator and battery and its been fine ever since
Mar 21, 2010 | 2003 Nissan Sentra
1995 Nissan Sentra - I've had the "brake" light on for years (only when engine is running). I replaced the back cylinder brakes and the "brake" light is off but the "malfunction light" is on.
you can try and reset your comp, take hot side battery cable loose, hold for 7 seconds, put back on and check, the switch on brake pedal could be bad, also check the fluid, if you had new brake cyc put on make sure they are not leaking, also on older nissian, the emergency brake will sorta fall down, making the light come on, get somebody pull brake, and emergency brake up and hold check and see if light is still on
Feb 06, 2010 | 1997 Nissan Sentra
I HAVE A NOISE COMING FROM THE PULLEY THAT THEBELT GOES UNDER NEATH IT. 2005 NISSIAN SENTRA
need to replace the pulley becuase it means the belt is loose or the bearing is going out
Jun 04, 2009 | 2000 Dodge Neon
Vehicle will not start
is the engine turning very fast and making an uncommon noise . if it is then you more than likely have a broken timing belt . if this is not the case then you need to check for spark .
Dec 08, 2008 | 2003 Nissan Sentra
Transmission problems
I would recommend you change the fluid and the filter, many times this condition is caused by dirt in the fluid, not all is filtered out, u would be amazed how little a piece of dirt it takes to cause shift problems and other weird issues.
Sep 08, 2008 | 1988 Nissan Sentra 2 Door
Car Audio & Video Logo
19 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
