Question about Sharp R-1750 Microwave Oven
No sound Our R-1751 doesn't make any sound.  It started happening intermittently and stopped completely a few years ago.  It works perfectly otherwise so we haven't done anything about it.  I just ran across this site (great idea, BTW) and thought I would see if there are any simple solutions. Thanks, Dave
  • dkaylor Nov 19, 2007
    The fan works fine. The problem is that regardless of the setting (beep, melody, or none), the microwave makes no sound when it is done. Thanks.
  • Sharp Master
  • 9,098 Answers
You mean it heats the food but the fan seems to not be running?
If so, that could result in overheating damage to the magnetrn very quickly!
Or do you mean that it doesn't beep anymore?
If so, that may mean that the beeper got turned off somehow.
To select the desired sound (if any) press Setup, then select either Simple Beep, Melody or No Sound and then press Start.
We have the entire owner's manual on our site at:
http://www.microwavedisplay.com/r1750_r1751_r1752_r1754_om.pdf
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Posted on Nov 19, 2007
  • William Miller
    William Miller Nov 19, 2007
    I would suspect that you have a bad connection on the circuit board at the beeper or on a driver resistor or transitor.
    We can repair this for $39.95 postpaid, but I'm not sure you'd think it's worth the trouble. But if so, we're happy to help.
    If you or a friend decide to look into it, we have the entire service / repair manual plus critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
My microwave stopped working one day. A few times before it completely stopped working, the magnetron would pulse and then shut off. Now the only time it does that is when nothing is in the microwave. If...
If this is an older oven, or an oven that has heated a lot of popcorn, or other low water content foods, then you might be looking at a magnetron that has become intermittent. The symptoms you describe, however, do not match the symptoms you usually see with this type of failure.
Based on your description of the problem, I'd investigate the possibility of an intermittent power relay. The contacts on these eventually burn and sometimes don't make a good connection. After the contacts first close, there're is an initial surge of current that might make the relay functional for a second or two, and then the damaged contacts no longer make contact.
Jun 06, 2016 | In Microwave Ovens
Microwave stopped working
Probably a problem with the door latch safety system. This happens every so often with our microwave, which is over 25 years old, and otherwise works perfectly.
If yours is new, it may still be under warranty. If not, there are places that specialize in fixing microwave ovens.
If it is an older, or less expensive oven, it might be time for a new one.
Jul 22, 2014 | Sharp R-1500 Microwave Oven
For a while, the microwave would intermittently work. Then we started getting "Sensor Error" on some modes. The microwave completely stopped heating, although the other features would work. We repl
The magnetron can look perfect but it or the inverter (power board) and a large diode often used usually cause this--all will look ok.....
Nov 06, 2012 | Microwave Ovens
I have a Sharp R-305KS stainless microwave. It is about 1 year old and until recently, I haven't had any problems with it. About two weeks ago the cancel button on the front panel started to work...
Hi and welcome to FixYa, I am Kelly.
This microwave has a 1 year warranty. You are going to need a new keypad to correct your symptom. Let Sharp pay for it.
http://www.sharpusa.com/~/media/15710197EE3140AD888B896ACDC912DD.ashx
(Choose "open" ) Then go to page 2 for contact information. Page 3 sates Parts and Labor 1 year.
Thanks for choosing FixYa,
Kelly
Apr 07, 2011 | Sharp R305KS Microwave Oven
Panasonic Counter top Microwave model # NNT695SF Often when I push the start button, the microwave will go for a few seconds and then cut out. I then open the door and then shut the door and push the...
Issue with your Main Panel Power Fail to innitiate ..Du to Component mal-functioning inside the unit ...Possibility Magnetron defect, Or main Transformer Over heat, Also check for safety swich on the door for bad connection...
Sep 30, 2010 | Panasonic NN-T695SF Microwave Oven
Clicking sound sporadically
That particular skillet is just too heavy a load for the turntable system to handle.
I would suggest a lighter skillet or a different container, otherwise, the motor or shaft or both will be damaged.
It is of course perfectly okay to put metal in a microwave (after all, that's what they're made of!) but you just have to do it only according to the instructions in the owner's manual.
And as you know, metal in convection mode poses no problem at all.
You just need to use a lighter or different container.
Jan 04, 2009 | Sharp R-1480 Microwave Oven
Goldstar MV1502W
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again. If you remove the fuse, then press the meter lead sagainst the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 20, 2008 | Goldstar MV-1526 Microwave Oven
Microwave quit
I would suspect either door switches or an intermittent control circuit board, either of which can be repaired. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure over time. I have a text file on my site called "doorsw.txt" which helps in diagnosing and repairing door switch problems. You can find the file via a Google search. It will help you check and replace the door switches if you or an able friend is so inclined. In some cases, the problem is a bad connection or a bad relay on the control board. That's something we see fairly often, and we repair them for only $32.50 nationwide.
Oct 12, 2006 | Panasonic NN-T990SA Microwave Oven
Sharp R-1750 Microwave Oven Logo
123 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
