Question about Kenwood KAC-X401M Car Audio Amplifier
Power Cap or Deep Cycle Battery?
I have this kenwood amp and iv decided to put it in my car and when the bass hits the whole car goes dim. I no that its drawing alot of amps and im gona need a capacitor. I was all set until I heard someone talking about deep cycle batteries. Which should I go with and also if I were to go the cap way whats an appropiate capacitor to get interms of farad rating? Knowing the power of this amp what cap should i get to do the job if im going this rout. Im a student on a budget here and I dont want to break the bank here. Any help will be great.
  • 111 Answers
Your amplifier has the following specs:
Output Power at 12V:
1 x 200W @ 4 ohms (0.05% THD, 20Hz - 20kHz)
1 x 400W @ 2 ohms (0.5% THD, 1kHz)
Output Power at 14.4V:
1 x 300W @ 4 ohms (0.05% THD, 20Hz - 20kHz)
1 x 600W @ 2 ohms (0.5% THD, 1kHz)
a .5 farad cap should work fine for 12v applications, a .75 will work fine for 14.4v applications. If you plan on upgrading the stereo system in the future, you should probably just pick up a 1 farad now and save trouble later.
when mounting the cap, mount it as close to the sub as possible. i recommended a deep cycle battery in an earlier solution due to the power handling requirements for the amp and speaker combo, any time you are working on a competition or semi-competition setup, you will want to isolate your audio system as much as possible from your vehicle's main electronics. i normally use a deep cycle battery if it's going to be a comp/street combo as you can sit at the lake and jam all night without killing your main battery. for comp only use, i stick to optima batteries, they seem to work well and can dump loads of amperage pretty quick.
if you go the dual battery route, you will want to buy a battery isolator to make sure the two batteries are independent of each other.
hope this helps,
Posted on Nov 19, 2007
When the bass hits the amp light goes on and off ?
Make sure you have good solid connections on your power and ground wires. Make sure the ground wire is touching bare metal if it is grounded to the chassis.
Jun 03, 2011 | Kenwood KAC-7203 Car Amp
There is a smell in my car every time I play my system for long periods of time. Its a burning smell. Everything is wired correctly and I have a separate battery in the back of my car to power my subs. I...
The problem could either be the amp over-heating or the subs could be over-heating as well. One of my friends owns an Alpine MRD-M1005, and one day they decided to clean it inside and out and realized they had some burnt spots on the circuit board, although they never smelt anything burning, and the amp still works fine.... As for the lights dimming you should probably buy a power Capacitor, atleast a 1 Farad or larger.
Hope this helps.
Nov 08, 2010 | Alpine MRP-M1000 Car Audio Amplifier
Makes head lights dim wen bass hits.
You need to install someting called a power cap. the amp needs so much power to produce the big bass thump that the alternator cant keep up. Use a powercap and its like a power reserve.
Jan 13, 2010 | Power Acoustik Car Audio & Video
Lights dim when bass hits....
you need to upgrade your electrical system.
First easy thing you can do is buy a bigger battery. Get a battery with the highest cold cranking amps(cca) that will fit. Yellow top would be great.
If you have the $$ have a higher amp alternator put in. these are very expensive.
this is an advanced solution, and any vehicle with a big amp should have this done. Its called a big 3 upgrade.
Get some at least 2 awg hook up wire. you will need enough to run a wire to the neg of the battery to the chassis to your altinator. and enough to run from the pos on the bat to the pos on the altinator. and from the neg to the frame of the car.
Use copper lugs and solder them on the ends of the wires. Use a blow torch and pliers to hold it and heat it up. Melt solder into it about half way full, and then push stripped end into it, then squelch it with a damp cloth and wipe it off.
Do this for all, and hook everything up.
You can install a CAP if you want. I personally don't believe in them. They help the car dimming a little, but the lower the voltage at the amp.
Dec 15, 2009 | Jl Audio 500/1 Car Audio Amplifier
What does it mean if my amp light dims and shuts off when the bass hits
Could be a number of things: Low power to amp, bad ground connection, faulty amp, or even speaker being overloaded or wired wrong. Check your connections and the wattage of the amp and speakers.
Dec 06, 2009 | Kenwood KAC-X520 Car Audio Amplifier
Amp turns off for a bit and back on when it hits hard
You do not have enough power coming from our car battery, your alt. may be going out. Look into a 5 farad power cap to store more power...
Apr 18, 2009 | Kenwood KAC-9152D Car Audio Amplifier
T1500-1bd burnt mosfet
Fosgate's get very hot.My first amp was a fosgate and I freaked out because it got really really hot. And smelled bad. So I moved it so where it could get more air That should help you out a lot and the smell went away on its own. As for your battery dying. Basically your stressing out your battery and your alternator is having a hard time keeping the battery changed. I'm sure you see your light dim when a low bass note hits. Invest in a cap. This will help save your battery your alternator and should even sound better.
Feb 08, 2009 | Rockford Fosgate Power 1500.1BD Car Audio...
Jl audio
If the amp was hot, it probably has a serious problem. You should have it checked out by a qualified tech. Don't continue to use it. More serious damage could occur.
May 29, 2008 | Jl Audio 1000/1 Car Audio Amplifier
How can i get my power to my EQ?
What kind of eq is it? First thing I would do is hook up the +12 and GND to the same place the amp is hooked up. I think the eq is having a hard time getting ample current, therefore shutting off all the way when the bass hits. Caps are good, but second battery and battery isolator are far superior.
Dec 06, 2007 | Clarion EQS746 Equalizer - 7-Band In-Dash...
Kenwood KAC-X401M Car Audio Amplifier Logo
112 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
