Question about Intel SE7520AF2 (SC5300AF2NA) Motherboard
SE7020AF2 Hi i have a SE7020AF2 motherboard on my server,it seems have vga but my monitor have not receive any signal,(of course windows work properly), i checked another monitor but error persist,there is another pci-x **** but it didnt work too,my windows work on this computer now and i manage it remotely, what is the problem and how i can solve it?
    Sergeant:
  • 449 Answers
Monitor seems defectived and needs replacement.
Posted on Jul 20, 2009
I connected up vga and HDMI cables and power, etc to ASUS desktop. All inputs are without signal. If I set monitor for vga, it says no vga signal. Same if set for HDMI input: no HDMI signal.
I would check your source for why it is not sending signal rather than why the monitor is not receiving. Of course, that being said, is this a new monitor or an old one that could be shot?
Dec 26, 2015 | ASUS Computers & Internet
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
Hp2009m not getting VGA or DVI signal, all plugs checked and plugged in properly. It has been working fine, this is the first time this has happened since I purchased the setup?
Greetings,
I would definitely make sure the "source" button is on the appropriate output (monitors can switch between dvi/vga inputs). Try toggling that button on the front of your monitor to see if that improves the situation.
Jun 03, 2011 | Computers & Internet
I installed an ASUS M4A78LM Motherboard also with a AMD Triple core processor. 4GB RAM. 32bit Windows XP. The computer starts up nicely, but the monitor doesn't turn on. Everything seems to be plugged in.
Make sure that you VGA/DVI card is in the motherboard slot properly, also just check that your power cord and plug on the back of the P.C is connected properly.
Thanks
Jason
Oct 14, 2010 | ASUS M4A78LM (90MIBB70G0EAY00Z)...
I just bought my 875WP1-E and hooked the monitor up to the onboard video port and when I power up the computer the monitor just says "no signal." What's up?
This is due to your system is not switched ON or not properly configured. Follow the below steps will resolve your problem.
1st Step: Have you hear any beep sounds? If yes insert the memory modules properly.
2nd Step: check whether the keyboard lights are flashing while switch on the system. if no, check the SMPS or SMPS connections.
Revert back for more assistance and give your valuable feedback/rating for the solution provided.
Thank you for using Fixya.
Feb 20, 2010 | Intel Server Board S875WP1-E Motherboard
AGP Problem.- Intel D850MV motherboard
Hi there.
Try clearing the cmos fdbf23f.jpg. move the plastic jumper the alternative position, power the pc up (Nothing will happen if you have it correct, then put it back in its original position and try to boot the machine again, don't forget to clean the memory as a precaution.
Good luck and thanks for using Fixya!!
Feb 13, 2009 | Intel D850MV Motherboard
New Motherboard & Processor not working
Usually this symptom has to do or with memory modules with problems or the VGA adapter (integrated) could be damaged. First try to reset the BIOS of *********** taking out the battery and using the reset jumpers informed in the Mother Board manual. Then put the battery and the jumpers back to the factory default position and try again.
If this doesn't work, try to plug the power cord to another 220V as the ground could cause this type of problems.
You can also try to install another VGA adapter to check if you receive the VGA signal in your monitor.
Hope it helps...
Please tell us about your progress.
Best regards
Eduardo
Oct 04, 2008 | Computers & Internet
After many faults my monitor is not receiving signal from my computer
Unplug your VGA cable and Switch on the monitor. It Should display a message that Cable is not plugged in like. If that message comes then monitor is alright. Once again plug and check the VGA cable of your monitor. If it works than its ok. Otherwise there is a problem in your display card which is present in the motherboard. You can insert an new display card or graphic card into your motherboard. Thank you.
Sep 09, 2008 | Computers & Internet
My monitor does not light up but just clicks
if ur monitor is not coming up... check uplugging the monitor cable from the tower.... if u receive a msg on screen "No input signal" or "No VGA Signal" then Monitor is working fine... if not received monitor is not working properly.
if Monitor working... open the tower and remove memory (RAM) and switch on the pc... u should get beep codes.. if u dint get it.... Motherboard gone bad....else... try inserting RAM in other slot... even then its not lighting up...RAM problem or RAM solt problem..
Aug 20, 2008 | Computers & Internet
IBM starting problem.
Hi , if your dont have any data, try to get the IBM Netfinity CD for 4000r which supporting the OS 2003. Usually IBM provide a cd on each NEtfinity server. Check on the IBM website for more details about your Server Compatibility on 2003 server. then proceed to re-intalled the OS.
Aug 10, 2007 | IBM Netfinity 4000R 8652 Server
Intel SE7520AF2 (SC5300AF2NA) Motherboard Logo
63 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
