2010 Nissan Armada Platinum Logo
Brigitte Nagel Posted on Aug 08, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to remove panel in cargo area 2010 Nissan Armada
Clicking sound from rear a/c actuator
SeabeeMechanic
Level 3:
  • Nissan Master 1,367 Answers
  • Posted on Nov 16, 2016
 SeabeeMechanic
Nissan Master
Level 3:
Answers
1367
Questions
Helped
411813
Points
3754
2 Related Answers
Anonymous
  • 346 Answers
  • Posted on Aug 09, 2010
SOURCE: I HAVE A 2006 NISSAN ARMADA WITH THE REAR RUNNING
Under hood, near firewall, right (passenger) side of the vehicle behind the strut tower is the second fuse box.
If the fuse isn't blown, check the bulbs. There is a chance that they both blew.
nobody322
_-__-___-_
  • 20706 Answers
  • Posted on Jan 09, 2015
SOURCE: replace door lock on nissan
nissan sells the book, FSM, factory service manual. buy one?
OUTSIDE ONLY? so inside works, the latch is good.!!!
does car have electric locks? is yes, that is 3 ways!!
mag solenoid, key out, and lever inside) 3 ways.
so id bet all 3ways are not failing, huh? implied,
the tumbler , fails?" (metal key) this would be just rod drop off.
if in usa, (not stated, so all answers wrong, can be...)
  1. remove skins (cards) from door, like call cars, google it or youtube it to learn
  2. then any plastic film there.
  3. roll window up or down to get mitts on latch.
  4. operate the latch directly, it unlocks.!
  5. repair bad parts (inpections)
  6. if all this is greek why not ask any shop to do this simple fix.
The FSm assumes you have skills, the books shows, what is unique on this car, some steps are detailed, such is this.
why not post full symtoms, of all 3 ways to open door.
1helpful
3answers
2001 volvo v70 tailgate lock/unlock relay location. Tailgate not locking checked fuses, no sound from tailgate, however do get click sound from fuse area.
Check the wiring to the rear hatch. The cables break and cause a variety fo problems like yours. You will have to take the plastic cover off and expose the cables.
WHAT IS A CLICKING SOUND IN THE PASSENGER REAR PANEL INTERIOR. NISSAN ARMADA
How would someone that has never been in your
vehicle & heard it & then tried to diagnose the issue,
know that?
Silly-- not thought out question
3helpful
Loud clicking noise from rear
If you have the EXT model Trailblazer, the clicking you hear is from the rear HVAC system and likely is one of the mode actuators trying to move a control door. The rear system is located behind a plastic panel in the rightside cargo area.
1helpful
I have a loud clicking sound in the very right rear in the molding. It sounds like a circuit breaker clicking on and off?
The clicking is an actuator for the rear HVAC system. It is trying to move but it is either stuck or the door it is trying to move is stuck. To access the rear HVAC, remove the panel at the rear right side of the cargo area.
My heater is not putting out hot air when its on and there is a clicking sound in the back of the vehicle. The vehicle is a 2004 ford expedition
There is an actuator motor behind the panel on the right rear cargo area. it is a temp control door actuator that has failed probabaly if you dont have temp control in back. I have replaced several of them, and they are similar in windstars, and excursions also. You will need to remove seatbellt attaching points to get this panel off, and the actuator costs about 65 dolla. Make sure the control door itself is not broken, as this is a common ford headache.
3helpful
Clicking sound in dah board
the most common cause of this is a faulty AC/heater temperature contreol door actuator motor, it is a tiny electric motor which runs a tiny gear drive, they get worn and the gears slip teeth and click. The bad news here is that the dash assmebly must be removed to access this door actuator..
Tyfhgjydjhjdtyy
If the noise is coming from the rear with rear A/C it sounds like you have a mode door actuator bad, same if noise is coming from front in dash. Have seen this before. In the rear you will have to remove pass. rear cargo area side panel, you have 2 actuators back there just feel which one is making noise, one on top is mode door and one on side of A/C case is temp. door. Hope this helps.
13helpful
95 Pathfinder Fuel Pump
In the rear cargo area you pull the back plastic strip that runs around where your hatch latches and pull the carpet FROM the rear right to the front left of the cargo area until you see the round/square panel with 4 10mm bolts.  That is the cover that you remove to get to your pump without having to pull your gas tank.  be sure to label your fuel lines.
James Mac Earn Cash Sleeping
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Nissan Expert? Answer questions, earn points and help others
