Question about Hampton Bay 24002 Ceiling Fan
Ceiling fan base gets loose and rocks and makes noise when running. can't sleep with it on. It seems the main stem attached moves back and forth loosening the base.
    Problem Solver:
  • 5 Answers
U may also have a balance issue with the fan blades. U can buy spacers or weights at any hardware store. These will go were the blades are attached to the motor.
Posted on Jul 28, 2009
  • 77 Answers
  • THE PROBLEM IS BECAUSE THE ROTATOR IN THE FAN IS GETTING WEAK AND PROBABLY IT WILL TAKE MORE ELECTRICITY THAN THE REQUIRED
Posted on Jul 18, 2009
IMy 97 4x4 gmc jimmy makes a clicking sound underneath when I drive at slow to moderate speeds. The sound isn't consistant but kind of sporatic. I checked the right rear wheel hub and when I had both rear...
You may have a axle bearing going out. You should jack the truck up and rock the wheel from top to bottom and see how much play is there and there should not be any rock. You could or should compare the rock from one side to the other side as a comparison. Just be aware you can get noise that travels along the frame in some cases and it is hard to determine just where it is coming from.
May 22, 2017 | 1997 GMC Jimmy
My flush ceiling fan is wobbling and hitting against the ceiling making an awful noise. How do I fix that issue?
The fan blades appear to be out of balance. First, check the screws that hold the fan blade irons to the fan motor. Tighten all that may be loose. If that doesn't solve the problem. the fan hanger bracket behind the ceiling cowl cover may be loose (it's attached with thin screws). In addition, the electrical box, that the hanger is attached to, may have come loose from the ceiling joist. If the electrical box has come loose, the box will need to be reattached to the joist with 1 1/2" long screws.
Hope this helps to solve the problem.
Mar 14, 2011 | Heating & Cooling
Speedo is not accurate and the faster you go the more inaccurate it gets. It seemed to start doing this when it got cold. The needle moves back and forth at freeway speeds. There is no noise though....
Based on the age of the vehicle I would check the speed gear on the transmission for being worn or loose. If the Speedometer actually has a cable attached to it replace the cable totally. This symptom is more a sign of a worn cable than a twisted cable.
Feb 22, 2011 | 1996 Toyota Tercel
How do you get started to wind a BMW watch. There is no resistance when I wind the crown. There does nt seem to be any plastic or anything in the way. I ve set the date successfully. Its a BMW Chrono...
mcdevito75 here, BMW watch, nice watch, Actually there are 2 ways to start winding an automatic or self wind watch. Since you feel no resistance in the winder (crown) which if you did, would mean the automatic mechanism is attached by gear to the mainspring and winding the crown (stem) would start the winding process. Without any resistance winding the crown, your automatic mechanism is free-lance as a way of saying, in your watch which simply means your BMW watch winds solely on wrist / arm motion. First, make sure you hear the automatic mechanism moveing inside the watch when you move the watch in almost any direction, now simply hold the watch in your hand and with a rocking motion, say from 12--to 6 rock your hand back and forth for about 30 seconds. You can also make circular motions with the watch in your hand for 30 seconds, any motion that will cause the automatic movement in your watch to move will, start the winding process. After you see you watch has started, simply wear your watch to keep it wound.
Jul 31, 2010 | Bulova Watch
Suspension plate
The suspension plate should be loose and float between the frame and base. The pin you saw was a shipping pin, they usually are caught in a little plastic cup attached to the base but sometimes fall to the floor, this is normal too. The tub being loose is normal for the top, it is held down by the springs below the tub but nothing on top. By a loud noise, what kind of noise is it? If it is a very loud ratcheting noise when it slows down then the basket drive(spin tube) and block need to be replaced. If it is a growling noise then that is pump and may be normal if the basket is not spinning. If this is the case look very close for an article of clothing caught between the tub and basket.
Apr 19, 2010 | Estate TAWS800JQ Top Load Washer
Hampton Bay Ceiling Fan
Are you talking about a Hampton Bay ceiling fan product. Is there a label stick attached to the top main housing unit that indicates the model & UPC #. If it;s a Hampton Bay...
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: kingoffans.com) that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
Nov 01, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Fan belt hitting housing when running.
the belt has streched out, a common problem, it just need a new one
Oct 31, 2008 | Garden
Ceiling fan makes a clicking noise
just apply some lubrication and if necessary change the ball bearings. u r all set
Oct 07, 2008 | Hunter Dryers
Fan motor noise
Does the fan seem to wobble when it is operating? If so, the fan blades may be out of balance. You can purchase self-adhesive weights to stick on the top of the blades to get them balanced properly. It is a trial-and error process, but it is the easiest and most cost-effective way of reducing fan noise. Other possible causes might be: the fan is loose in its mounting, or the mounting itself is loose .A wire inside the fan motor may be rubbing against some moving part. Also, the fan unit may not be properly grounded, or wired with reverse polarity., causing a 60 cycle "hum".
Aug 05, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Hampton Bay 24002 Ceiling Fan Logo
372 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
