Question about Hotpoint Aquarius WMA42 Front Load Washer
Have WD63 WASHER/DRYER & the drum stopped turning. motor ok & drum turns easily when turned manually.
  • 24 Answers
Could be the carbon brushes on the motor. They're usually quite cheap and easy to replace. In this area you can expect to see a lot of carbon dust (black). The brushes themselves should protrude from the case by around 4-6mm.
Could also be a loose connection between the power feed and the motor.
Will it pump? Some machines die completely when the pump fails.
Posted on Jul 18, 2009
Hotpoint Wt540 1400 wont spin
check the machine washes ok if it does not turn the drum on wash check the motor brushes if drum action is ok on wash check the drain pump for blockages
Mar 06, 2014 | Hotpoint Aquarius WD63 Front Load...
I have a hotpoint aquarius drier CTD00 when i turn it on the drum spins but there seems to be a grinding noise
It is so common that the washer /dryer machines can create terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
For replacement of bearings check for tips on this visual link:
Aug 08, 2011 | Hotpoint Aquarius WD63 Front Load...
The washer is coming on but wont spin
if you mean the drum wont turn after filling with water...... then the motor may need new brushes............ costs about £12 max n tack you about 10 to 15 mins to sort.........
cheers
Mar 24, 2011 | Hotpoint Aquarius WD63 Front Load...
The dryer drum will not turn, even manually with the belt removed
Sounds like something became wedged against the drum. Maybe a bearing?
Feb 20, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Bosch Classixx 1200 - Drum not turning
It could be the motor itself (is there any overheating smell from the motor) or it could be the capacitor which controls the motor. I had a similar problem and it turned out to be the motor brushes. I replaced the brushes and all was OK.
The only other thing that could be wrong especially if it overfills with water is the water level switch (this is a pressure switch on the side of the washer) You can easily check this by removing the hosepipe to the switch and blow gently into it, you should hear a clicking sound) This might be the clicking that you heard so it is probably Ok.
Aug 08, 2017 | Bosch Washing Machines
Drum will not move
Try to remove drum belt, and then turn drum by hand, if it does not turn , then you have either siezed drum bearigs, or some thing jammed between the inner and outer drum
If drum turns freely, then check motor to see if it is free to turn.
Please rate my solution.
Thanks.
Jul 24, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD63 Random Fault
if the drum will not turn it may be the motor brushes
Sep 30, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wd420
if the drum is tight to turn ,then the main bearings have probably seized, or their could be something fast in the drum. Remove belt, and try to turn the drum by hand , it shuold be free with no resitance.
If it is noisy or feels rough, then the bearings have gone.
Sep 01, 2008 | Hotpoint Aquarius WD63 Front Load...
Drum not turning
Hello
If you look at the motor which of course is on the top right of the drum. you will see either white or black palstic parts inserted eiterh side and a wire connected to them
These are the brush holders for the carbon brushes.. These have worn out and need replacing easily done just get yourselfthe parts and remove the old one and replace with the new ones....
Jan 12, 2008 | Hotpoint Aquarius WD63 Front Load...
Washer dryer
possibly foreign object between drum and tub - sock etc. take out heater and you can look in this area
Jan 20, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WMA42 Front Load Washer Logo
64 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
