Question about Acer Aspire 5315 Notebook
Have a del inspirion 1721 i just replaced the motherboard on it and it wont power up, the middle A lite just blinks at top of keep board where the tree leds are, what do i need to do to make it power up, its getting power, thank you gary
  • Acer Master
  • 13,433 Answers
Unplug and take battery out. open up the memory cover in the bottom of the laptop, take both memory modules out from the laptop, now with no memory plug in the power adapter and try starting up, wait 1 minute and turn the laptop off, now place one of the memory modules back into the laptop and try starting up again, remember to unplug the power when your connecting or disconnecting parts from the laptop.
Does the laptop start up? If not, then take the ram module out from the laptop again, this time place it on the other memory slot and try again. If it still doesn't start up repeat the above with the other memory module if you have two.
if theres no improvement take the laptop apart, just disconnect all extra not required components of the laptop, modem, wireless, dvd, etc.
see if it boots up with just motherboard, cpu, cpuheatsink, other heatsinks, and one memory ram module, on power adapter.
if it doesn't start up, reseat the cpu.
if theres no improvement, I would buy a card like this
http://www.dealextreme.com/details.dx/sku.25101
should come with a good manual of the code meanings, the service manual for the laptop may contain better list, but generally those dell service manuals that they have online don't.
if it turns out to be a motherboard problem, not cpu or memory related the replacement part should have somekind of warranty from the company you purchased it from.
Posted on Jul 18, 2009
Del 320 optiplex orange lite blinks won't boot up
For the Optiplex 320, a flashing amber light with no sound indication can mean 3 things.
1) Your power supply has failed
2) Your motherboard failed, most likely from a bad capacitor.
3) The front panel board (where the power button is located) is faulty or not connected properly.
I've worked with 10's of 1000's of Dell Optiplex's over the past 8 years and the flashing amber light is well known as a tell-tail sign of one of those three failure. Always start your trouble shoot with a PSU tester, then inspect the motherboard for domed or split/leaking capacitors...then on to the front panel which would require another panel and ribbon from the same model.
Jan 25, 2014 | Dell Optiplex GX280 (99301) Motherboard
Cpu fan wont come on dell inspirion 1721
it shows that the may gone out of order needs replacement
Jan 14, 2013 | Dell Inspiron Computers & Internet
I have a Dell inspiron 1721. The screen is dim ... when I try to adjust the brightness it won't adjust any brighter than it already is and makes some type of humming noise at the settings in the middle. ...
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp
Sep 06, 2010 | Dell Inspiron 1721 Notebook
Cannot get dell inspirion 1721 to find hard drive on system restore
Try restarting, and pressing f2 to access the bios, and making sure the bios is recognizing the hard drive..
If it is not, you will need to flash the bios for your machine..
Oct 29, 2009 | Dell Inspiron 1721 Notebook
My sons nintendo ds wont turn on, when we charge it, turn power on , the green light comes on and bottom screen blinks for a split second then goes dead.. Is this fixable , if so what do i try??? thanks
yes it is fixable sounds like your fault is with the top screen are the hinges ok has it been dropped.
most green light and screen flashes point to a defective screen or connection on the mother board or sometimes fuses. id start with checking the motherboard connection if its ok check the fuses if all is ok buy a new top screen and replace it.
Jun 30, 2009 | Nintendo DS Lite Console
Hitachi rear projection tv wont power on makes a chirp
You could have a bad HV Transformer causing it to shut down.
Jun 19, 2009 | Hitachi 43UWX10B 43" Rear Projection...
The power light keeps blinking and it doesnt matter if i unplug the tv and plug it back in when i go to turn it back on it just blinks.
the blinking power light is actually a diagnostic of a faulty part inside the set.
Here is the diagnostic info and which part you need to replace.
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
if this set is still unedr warranty, please use the warranty to replace the part. Else, have a professional install the new part for your safety.
hope this helps.
regards,
voodoo
Jun 09, 2009 | Panasonic Viera TH-50PZ85U Plasma TV
Wont turn on
Take the back off of the TV and look at the power supply board (middle of the set). One or more electrolitic capacitors will have the tops swelled up. Replace them with the same value parts and you will be OK.
May 17, 2009 | Philips 50MF231D 50 in. Plasma Television
My ds lite wont turn on i bought a new baterie and charged it with my cuzin charger and it still does not turn on it just goes on for 3 seconds and turns off and only the top screen blinks 1 and it just...
Nick625343,
Your DS Lite is damaged and needs to be sent to Nintendo for repair.
Nintendo will likely tell you the unit is beyond repair and must be replaced.
If you want to avoid the middle man, you can always purchase a new DS Lite from your local electronics retailer.
Apr 12, 2009 | Nintendo DS Lite Console
Acer Aspire 5315 Notebook Logo
19 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
