Question about Office Depot Ativa 802.11g Wireless Cable/DSL Router With 4-Port Switch (AWGR54)
Ativa router freezes and getting frusterated
I am having an issue with my Ativa freezing while wireless is on, I have this issue whether I have my laptop and my aunts laptop connected to the wirless or when I just have my Iphone connected it will randomly freeze and I have to do a full hard restart on the router and also go into my network connections and disable and re-enable my connection kinda frusterating, wondering if there is any simple fix other than buying a new router.
    Master:
    Sergeant:
  • 226 Answers
Try to go into the router interface and update the firmware and double check your settings
Posted on Jul 20, 2009
I lost the usb chord and cant get the router to charge. I do not know which one I need for this specific, Ativa, router.
this is a 24 hour free technical support number for Ativa... 866-912-8482
you can also call 18002234456 (BELKIN) and select the option for networking products... Belkin & Ativa are same...only the brand name differs...
Aug 01, 2010 | Office Depot Ativa 802.11g Wireless...
Can't port forward ativa router to ps3
www.portforward.com
They have a guide on almost every router
May 26, 2009 | Office Depot Ativa 802.11g Wireless...
My laptop freezes on boot when i insert my wireless card and also it freezes when i insert a pendrive or flash drive pls can u help me?
It sounds like a hardware issue. You didn't say whether the pendrive or flash drive was freezing on boot or not. It is possible your bios chip is loosely connected.
Apr 19, 2009 | Computers & Internet
Freezing Router
If you have tried 2 different routers, the problem there is the location of the router. I believe there's an interference happening. Make sure the router is located away from cordless phone especially 2.4 GHz wireless phones, microwaves and mirrors. If you can place the router on top of cabinet or mount it on a wall, that's better. The higher the better. Also changing the router's channel can greatly help. Normally, the router's default channel is 6. Change it to channel 11 and that will solve the interference issue.
Hope that helps!
Sep 16, 2008 | Linksys WRT54G3G Wireless Router...
Ativa wireless G router
Hi Lu,
Yeah, this is def a configuration issue. The fact that is says that network key is incorrect when you're trying to get on the wirless LAN signifies that either your WEP encryption key or someother security key that the router issues to the notebook is either expired or invalid. Plugging the notebook physically is is NOT an options (kinda defeats the whole wireless idea eh?) Your connection to your friend access point worked cause most probbaly he either had your mac address added into the router or there was no security in his WAP at all.
That said, what you might wanna do is log into your router as admin and reissue your WEP key from the router to the notebook. Alternatively, you can do away with this and use mac authentification, if there is such an option on your router. Let me know if you need assistance on this. Thanks.
-Technomancer
May 30, 2008 | Computers & Internet
Ativa router
ok, fine....
Reset the Ativa router to factory defaults. This is normally accomplished by holding the reset button down for 10 seconds or more with power on for most routers.
Once you do that, you need to connect the computer directly to the motorola modem and configure it to be in "bridge mode".
Putting your modem into bridge mode means to bypass the router function and make it work as a simple modem. And, yes, if you do that then you must configure your wireless router to make the internet connection. If you don't want to do that, you can leave the modem as it is, I think the Ativa wireless router can still work even if your modem is still in PPPoE & you can still configure the router as an ethernet switch & wireless access point.
Now you can connect the router (after powering EVERYTHING down), turn on the modem, wait for steady connect, turn on the router, wait two minutes, boot the connected PC.
After you get a wired machine connected, you can enter the Ativa setup and configure the wireless security.
Open up IE or Firefox. On address bar, type in "192.168.2.1" and click enter.
Ativa wireless setup should load up. On top right, there is a Log In button. If this is your first time login in, leave it blank and submit.
Check up on the following: a) Internet WAN > Connection Type > select Dynamic; b) Wireless > Channel and SSID > Disable ESSID Broadcast, also set wireless channel to AUTO; b) Wireless > Security > set up your security, you should know what to do.
Now for the most important thing. Click Firewall, and DISABLE IT!! By doing this, it said that you'll will be vulnerable to hacker etc...blah blah, but with security keys to access wireless and virus program/window firewall should be enough to make you stop worrying. Apply changes, then the thing restarts.
*** also leave MTU setting to 1454 & set it to auto connect; leave the DNS & MAC settings alone; also leave LAN settings as it is.
i would greatly appreciate if you could give me the modem's exact model no. (such as SB4200, 2100 etc.) and the router's as well....
Apr 23, 2008 | Computers & Internet
Ativa router and at&t
there is a link in the motorola UI that allows it to be put in "bridged mode" so you can configure the router. however, before you do this, i suggest you have to make the motorola (is it 2100?) modem work with your computer, connect this modem to your computer using ethernet connection, access the UI (192.168.1.254), type your user id & password in the login page, then connect. make sure that you are able to connect to the internet. then access the UI again, click on "advanced" choose PPP location. in the PPP location page, click on bridged mode, that will restart the modem automatically, & you will notice the modem's internet light will turn off. then you can connect the ativa router to this modem using manufacturer's instructions. you can now login to the router's page and make the necessary changes.
Apr 20, 2008 | Computers & Internet
I have a belkin n wireless router keeps freezing
First step of solution would be performing Reset. Press and hold the reset button about 30 seconds and release. Check again. If you need customized settings just type 192.168.2.1 in your browser and get into settings.
If issue persist please post for further troubleshooting.
Good Luck
Jan 24, 2008 | Belkin (F5D7231-4) Wireless Router
Router Reboots and Freezes
I have found a router freezes up due to memory leaks. After a while it just uses up all its available memory and can't make a new connection. Calling the manufacture and raving until they send you the firmware fix for the memory leak is the best option. In the meantime, just pull the power plug on the thing and when it comes back up it will be fine (until it uses up all its memory).
Oct 12, 2006 | D-Link AirPlus Xtreme G DI-624 Wireless...
Open Questions:
See all Office Depot Ativa 802.11g Wireless Cable/DSL Questions
Office Depot Ativa 802.11g Wireless Cable/DSL Router With 4-Port Switch (AWGR54) Logo
262 people viewed this question
Top Office Depot Computers & Internet Experts
k24674
Vernon Taylor
Are you an Office Depot Computer and Internet Expert? Answer questions, earn points and help others
