Question about Black & Decker Steam Generator SG200 Iron
I have a Swan S15040 steam generator iron, the stand by light is permanently flashing, no matter what temperature setting i put the iron on. No steam is generated. I have tried holding the steam button down, on both the iron and the unit for well over 20 seconds, still no change. Can antone help?
I had same issue , now , once you turn the unit on , you should see displayed 3 steam jets and the flashing standby , turn the dial on the iron to max ,press the steam button on the machine to max steam , leave for a minute or so , now press the steam button on the iron , does it make a noise ? if it does , slightly raise the whole front end of the unit ( easier if you have the iron on the worktop and not on the unit !) for a minute then try and press the steam button on the iron again . I think there is a bit of an issue about the conection between the water tank and the filter . This solved my issues and i do hope it will help you .
Posted on Oct 16, 2009
  • jo hoggarth Jan 31, 2013
    thankyou although i have tried this but it has not corrected the prob
  • Llyn Humes
    Llyn Humes May 15, 2013
    Thanks for your suggestion but I have tried this and it doesn't work.
Swan steam iron
The iron has failed and is leaking steam where it shouldn't be leaking.
May 23, 2017 | Irons
I need a manual for swan steam generator iron item si4030n
http://www.swan-brand.co.uk/swan-2200w-steam-generator-iron-1.html see Documentation http://www.swan-brand.co.uk/media/swan/ib/SI4030N.pdf
Jun 15, 2012 | Irons
My swan steam generator iron s15040 is brand new and i cannot get steam ,and i have followed the instructions ..please help before i have to return it ..does any one else have the same problem and if so...
Hi Im having the same problem but mine is 6mths old..I think its the cartridge that needs replacing as everything else works but the steam..Gonna order one today if that doesnt work I shall return it..They reckon to change it every 3/6/12 mths according to being in hard/medium/soft water area.I took the cartridge out one day and let it dry out it worked for 2 days then packed in on me again.
Nov 10, 2009 | Irons
STEAM ONLY COMING OUT OF TOP HOLES SWAN S15040
The iron is probably clogged up from mineral deposits in the water. Fill the iron with a 50/50 mix of water and white vinegar. Heat the iron and let it set for awhile. Then steam the solution through the iron. Repeat the process if this does not work. If the Vinegar and water does not work, then try a product such as Lime Away or CLR to remove the deposits. After the iron is cleaned out, try using distilled bottled water in the iron, to reduce the mineral build up.
Hope this helps you!
Aug 15, 2009 | Black & Decker Steam Generator SG200 Iron
Need manual for swan steam generater iron model s15040
you have probably solved this by now but
I just got the same model new
switch on instructions as follows
press and HOLD the POWER button for 3 seconds to switch the unit on
once temperature has been reached, press and HOLD the steam button on top of the iron for up to 20 seconds
this will prime the steam pump and only has to be done once for each ironing session
the pump noise will stop once it has been primed with water
hope this helps if still needed
if you need the user guide, let me know, I'll scan it for you
Wendy
Jun 29, 2009 | Black & Decker Steam Generator SG200 Iron
Swan steam station S12010
i have a steam station , the stand-by light keeps flashing on and off, how do i reset it, there is no steam comin thriugh at all, please help.......thank you xx
Oct 14, 2008 | Irons
Black & Decker Steam Generator SG200 Iron Logo
4,133 people viewed this question
Top Black & Decker Irons Experts
tfelton3
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
