Question about Intel DG31PR Motherboard
Intel dg31pr mother board why dont show display?
Question is intel dg31pr mother board why dont show display? before this motherboard i add two H.D.D. after added two hdd then i will trai to set up windows to another hdd.when successfully installed the windows after restart the windows and then not come display
    President:
  • 1,383 Answers
First check your num lock led if it on and off when you press num lock key then your cpu is ok.
Then therer is issue with monitor to cpu loose connection
or
Screen resolution problem.
For that when you power up press F8 key then enter in enable vga mode.then go to control panel and dispaly then settings then change screeen resolution to 1024*768 then apply and ok.
Aslo reconnect connection from monitor to cpu vga port.
Also check in bios some times your harddisk is not detected proeprly.
If problem still remains open cpu cabinet and reconnect data cable and power cable to harddisk.
Refix RAM memory.
Pull cmos cell for 15 minutes then check.
Thanks for using fixya.
Pls rate solution if it help you .
Posted on Jul 18, 2009
Mother board no display
display port may not working so you need to check for the same .. n also chek it by adding other display card on PCI slot,,,
May 19, 2010 | Intel DG31PR Motherboard
Hi, im kind of lost with this issue. I got a new pc with a mother board intel DG31PR, it works fine at least as far as i have tested. The problem is that i dont find how to remove the intel logo on the...
All this info can be found on the computer once she's up and running. Just go to System info under "Help" section.They know you didn't need to see that sticker for the info.
Aug 25, 2009 | Intel DG31PR Motherboard
Problem with installing win2003 on motherboard DG31pr
It mainly due to the lower version of driver trying to install at the time of installation of windows 2003.because older windows does not contain proper driver for latest Mother board chipset.
So install latest Windows 2003 or updated windows 2003 Operating system.
Jun 25, 2009 | Intel DG31PR Motherboard
Can i install xp-sp3 without Sata driver on motherboard 'DG31PR'
You have a board with 4 SATA ports on it and a SATA HDD. The hardware detection routines will see this and load the SATA drivers. Why would you even want to try to set it up without them?
Mar 21, 2009 | Intel DG31PR Motherboard
How can i disable built in audio and add creative live value in mother board?
hi salu
check the book that comes with the motherboard , it should show the location of the small jumper switch on the motherboard which enables/disables onboard audio. if there isnt one press the "delete" key at start-up and enter the system BIOS you may be able to disable it there
Oct 25, 2008 | Intel DG31PR Motherboard
Intel DG31PR Motherboard Logo
246 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
