Question about Toshiba P000392200 - Satellite A40, A45 Series 2.4GHz Intel Pentium 4 Processor (P000392200CPU) PC Notebook
Wi fi card or adapter
Have a toshiba satellite pro a60en and want to fit a wi fi board there seems to be a door on the bottom of the laptop with the wi fi sign but nothing inside to fit the board to any ideas it does have two screw placements for like an adapter to be screwed to the board like the soft modem is in the other panel next to it any help would be greatfull
  • 29 Answers
First check that you have got right adapter for your laptop.
then check that your motherboard actually supports a wi fi. IF you have everthing sorted then go ahead and plugin the compatible adapter. Also, be sure to have the latest driver installation disk ready.
Start your PC, it should detect it and then ask you for the driver.
If this dosen't work or you are unsure then my best advice is to take it to an authorised vendor and let him do it, no use playig around with an expensive laptop.
Posted on Jul 18, 2009
Problem with speed of wifi of toshiba satellite l50-b
I wasn't aware this model had wi-fi. Have you a wireless card inserted into the side?
Jun 26, 2014 | Toshiba Satellite 2805-S301 Notebook
Tip
Toshiba Bios Password Deletion Satellite P100 & Satellite Pro P100 With...
With notebook turned off;
  • Open Wi-Fi Cover
  • Remove Mini Card Wi-Fi card
  • Locate & Short Out JP8 for 5 Seconds
  • Remove short and turn on
  • NO BOOT
  • Press & Hold Power button to turn off
  • Turn on again & password is cleared
Satellite L10, L20, L30 & Satellite Pro L20
  • Open Wi-Fi Cover
  • Locate & Short Out JP1 for 15 Seconds
  • (Satellite L10)
  • Satellite L20/Pro L20 short out G1
Satellite M100 & Tecra A6
  • Open Memory Cover
  • Remove Memory
  • Remove Black plastic insulation
  • Locate & Short CMOS CLR1 for 15 Seconds
NOTE:
All the following models use the same password removal process.
Satellite: 17xx Series, 1000, 1110,1130, 1200, 1900, 2430, 3000 P20,P30, P33, A30, A70, A80, M40X, M50,M60, M70, M100
Tecra A3/S2, A5, A6
  • The jumper is always located under or near the memory modules
  • Depending on the model the jumper could be labelled J1, J2, J5, J7, J9 or CMOS CLR1 (M100 & A6)
Satellite A100 & Tecra A7
  1. Remove Strip cover
  2. Remove 2 x K/B screws
  3. Move K/B Unit up but don’t disconnect
  4. Release & Remove Mini Card Wi-Fi Card
  5. Locate & short C88 Pin 1 & 2 together
  6. Power on Machine while still shorting Pin 1 & 2
  7. As soon as the TOSHIBA logo appears, remove short
  8. If machine boots, Password has been removed
  9. Satellite A100 (PSAA2A-02C01N)
    1. Remove Memory Cover from base of machine
    2. Release & remove right side Memory Module
    3. Lift black plastic insulation
    4. Locate & short PAD500 Pin 1 & 2 together
    5. Power on machine while still shorting Pin 1 & 2
    6. As soon as the TOSHIBA logo appears, remove short
    7. If machine boots, password has been removed
    TECRA A4 & Satellite M40
    1. Open modem & Wi-Fi card cover
    2. Remove mini PCI Wi-Fi card
    3. Lift up black plastic
    4. Locate & short C738 Pin 1 & 2 together
    TECRA S1
    1. Open palm rest cover
    4. Locate & short C5071 Pin 1 & 2 together
    TE 2300
    1. Remove 2 x B12 screws from bottom of system
    2. Remove strip cover
    3. Remove keyboard screws 1 x B2.5 & 1 x SF4
    4. Remove 1 x 4mm screw & Wi-Fi cover
    5. Remove mini PCI Wi-Fi card if fitted
    6. Locate & short points as shown in picture below
    7. Power on machine while still shorting points
    8. Short for 5 seconds
    9. Nothing will appear on the screen
    10. Turn system off holding down power button
    11. Password is now removed
    Satellite A60
    1. Open Wi-Fi slot cover
    2. Lift up black plastic
    3. Locate & short C561 Pin 1 & 2 together
    4. Power on machine while still shorting Pin 1 & 2
    5. As soon as the TOSHIBA logo appears, remove short
    6. If machine boots, password has been removed
    If you need your Toshiba bios password removed and your model is not listed above then chances are it's a procedure that can only be done at an authorised repair centre.
on Jun 08, 2010 | Computers & Internet
What year was toshiba satellite 2410-S203 pc notebook first launched?was it equiped by WIFI?
My sources indicate 2003.
It has > Optional
http://www.csd.toshiba.com/content/pr/html/Satellite%201410%20and%202410%20Press%20Release%20%289-24-02%29.html
The Wireless Antenna On-Off switch is on the Right side. The Wireless Antenna LED is to the left of the On-Off switch. It glows when the wireless antenna is in use.
It has to have an > optional
Turn the laptop over, Front facing you.
The Battery Compartment is on the Front Right corner.
The Wi-Fi Compartment Cover is on the Back Left corner.
Remove the single screw in the right middle of the cover. (Philips head)
See if a Wi-Fi PCI Mini Card is installed.
No?
You'll have to obtain a Wi-Fi PCI Mini Card for your Toshiba.
From a quick search just now, (Not advertising for this website),
http://www.impactcomputers.com/p000339520.html
(Remember to remove ALL power to the laptop Before installing. AC adapter {Charger} and Battery.
Also remember to observe Anti-Static Precautions before handling the Wi-Fi card, and when installing)
Here is the Toshiba Satellite 2410-S203 Notebook PC User Manual, also,
http://www.fixya.com/support/p265858-toshiba_satellite_2410_s203_pc_notebook/manual-14885
Nov 16, 2010 | Toshiba Satellite 2410-S203 Notebook
How to turn on wireless switch on a Toshiba 5205-S505?
First - Determine if your Toshiba Satellite has built-in Wi-Fi. Open the Start menu in the lower left corner of the desktop. Choose "Control Panel" and select "Performance and Maintenance." Click on the "System" icon and click on the "Hardware" tab in the System Properties window. Click on the "Device Manager" button. Click on the plus sign next to "Network adapters." Look for a device that has "Wireless" or "WLAN" in the name. If you see this device listed, then you have built-in wireless.
Next - Turn on the wireless by holding down the "Fn" key on the keyboard and then pressing "F8" at the top of the keyboard. Press this combination until the window indicates that Wi-Fi is on. Some Toshiba notebooks have a switch on the front left side of the laptop that will turn the Wi-Fi on. Many Toshiba Satellites have an LED indicator light on the right front edge of the notebook that will turn on when the Wi-Fi is on.
Finally - Click on the Start menu in the lower left corner of the desktop. Select "My Network Places" and click on "View network connections" in the menu on the left side of the window. Double click on the "Wireless Network Connection" icon. This will open a window that lists available wireless networks. Click on the name of the network you wish to connect to and click on the "Connect" button at the bottom. Type in the password if required and connect to to the network. Open a web browser to test the connection.
Apr 15, 2010 | Toshiba Satelite 5205-S505 Notebook
Can my 1625CDT be made WI-FI adaptable
Any laptop computer that doesn't have a built-in wireless card can be wireless enabled by installing a PCMCIA wireless card or an USB wireless adapter. Go and see your friendly computer shop.
Aug 06, 2009 | Toshiba Computers & Internet
Just got a toshiba satellite pro a60en laptop. do these generally have wi-fi built in or do they nhand eed a wireless card. on the right side there seems to be a blanket covering what i presume to be
Depends on the model mate most do but, as for the ones that don't then the ATHEROS chipset WIFI board that fits insde and is widley available froom sellers on-line better on ebay though also you can always use a wireless PCMCIA card in the card slot or, buy the internal one and fit it.
Domonium
May 18, 2009 | Toshiba P000392200 - Satellite A40, A45...
Wi-Fi not connecting on Toshiba Satellite A15-S157 PC Notebook
you tried giving it a static IP address rather than using automatic settings (i.e. DHCP). Sure enough, this cured the problem, connected fine. I looked in the dhcp server logs and while it was not complaining that the IP address pool was all used, it did seem that all the IP addresses available were being used. I increased the number of IP addresses available to be allocated by the dhcp server and problem solved. The big mystery to me is why Windows XP would report this as a problem with a weak signal? Isn't the access to the dhcp server and the allocation of the IP address at a layer above the wireless connection? Anyway, it's useful to be warned that the wireless diagnostics are misleading.
Nov 05, 2008 | Toshiba Satellite A15-S157 Notebook
go to services.msc and chk if the wireless zero is on or off
Toshiba P000392200 - Satellite A40, A45 Series 2.4GHz Intel Pentium 4 Processor (P000392200CPU) PC Notebook Logo
110 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
