Question about Lexmark X5470 All-In-One InkJet Printer
I have just change printer cartridge, the display is now showing printer error 1203 followed by cartridge missing could you assist me with this issue please
    Brigadier General:
  • 8,619 Answers
Hi!
To resolve the printer error 1203 on your Lexmark X5470 All-In-One (AIO) Inkjet Printer, you need to perform the following tasks---
Power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on. if the error message return then continue to print a test page. If the test page prints, the error is resolved. If still the power persists then you need to open the top cover of the AIO and remove both cartridges from the AIO. After that power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on and if the error message return then there is a hardware problem with the printer. If error message not return then you need to again power off the AIO and remove the power supply from the back of the unit. Reinsert the power supply and power the AIO on. Open the top cover of the AIO and insert the color cartridge. Close the top cover. If the error message returns then you need to clean the cartridge contacts.
Again try to rest it by powering off the AIO and remove the power supply from the back of the unit. Reinsert the power supply and power the AIO on. Open the top cover of the AIO and insert the black/photo cartridge. Close the top cover. Now print a tests page. If the test page prints, the error is resolved.
Cleaning the Cartridge Contacts
1 Open the top cover of the AIO and remove the cartridges.
2 Remove the cartridges. Clean the cartridge contacts and the AIO carrier contacts.
Checking the Cartridge
To see if the cartridge is defective, replace it with either a new cartridge or a known good cartridge from another printer of this type.
1. Turn the printer/All-In-One off and unplug the power cable from the outlet.
2. Open the printer/All-In-One lid so that the cartridge carrier can be accessed.
3. Remove the print cartridges. (For information on cleaning the cartridge contacts, click here.)
4. Using a dry, clean cloth wipe the carrier contacts gently from top to bottom.
5. Repeat Step 4 for the other cartridge slot (if applicable).
6. Reinsert the cartridges, slide the cartridge carrier to its original position, and close the printer/All-In-One lid.
7. Plug the printer/All-In-One back into the power outlet and turn it back on.
You should only follow the steps below to resolve a print quality problem if you have already attempted to solve the problem by printing a "Clean Print Nozzles" page.
Cleaning procedure - Remove the print cartridges. Moisten a clean, lint-free cloth with water. Gently hold the cloth against the nozzles for about three seconds, and then wipe in the downward direction while keeping the print head in downward position on the cloth. Using another clean section of the cloth, gently hold the cloth against the contacts for about three seconds, and then wipe in the upward direction of the print head.
With another clean section of the cloth, repeat steps 2 through 4 above. Allow the nozzles and contacts to dry completely. Reinsert the print cartridges. Print the document again. If the print quality does not improve, repeat the steps for cleaning the nozzles and contacts up to two more times.
If still the error message persists then you need to contact the Lexmark.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jul 18, 2009
How to fix error 1203
ERROR 1203 LEXMARK ERROR 1200 Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Or try
Reset Factory Defaults on the Dellâ„¢ 964 or 966 Printer
To reset factory defaults on the printer, perform the following steps:
1. Press the down arrow button until Maintenance is highlighted and press the Select button.
2. Press the down arrow button until Reset Defaults is hightlighted and press the Select button.
3. The printer displays a confirmation message. Highlight Yes and press the Select button
Note:
Some settings such as phone lists, time, date, and country are not changed.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 15, 2010 | Lexmark X5470 All-In-One InkJet Printer
I turned my printer on and have a message reading Cartridge Error Error:1203 See guide. I do not have a guide, it is missing as well as my install disc.
or
Dec 08, 2009 | Lexmark X7170 All-In-One InkJet Printer
Error code 1203 on display
or
All the best Pineworks
Jun 05, 2009 | Dell 962 Photo All-In-One InkJet Printer
Error 1203
The error 1203 error message on the operator panel could indicate a problem with one of the ink cartridges. Please follow the steps given below:
1. Please make sure the All-In-One is powered on.
2. Pull the control panel towards you, and then open the cartridge access door. The print cartridge carrier moves and stops at the loading position.
3. Pull the old cartridges towards you, and then lift them out.
4. With the cartridges out of the printer, shut the access door and the control panel.
5. Power the printer OFF and then back ON.
6. Please check the operator panel to see if the same error has returned or if a new message has appeared.
7. If the message displayed is 1203, there is something wrong with the printer hardware.
If the message now displaying is Cartridge Missing, do the following:
1. Reinstall the cartridges into the printer.
2. Insert the color cartridge in the left carrier. Insert the black cartridge in the right carrier.
3. Push back firmly on the cartridges until they snap securely into place.
4. Close the cartridge access door, and then close the control panel.
5. If the 1203 message is still present on the operator panel, you need to insert one cartridge at a time to determine which cartridge is producing the failure.
6. With one cartridge in the carrier, close the access door and control panel.
7. Please check the operator panel. If the 1203 error is displayed, this cartridge is the defective item. If the Cartridge Missing message is displayed, the second cartridge is producing the failure.
8. Please replace the defective cartridge.
May 21, 2009 | Lexmark X4270 All-In-One InkJet Printer
My printer says error 1203 catridge error...can you help me with this...I can not find my owners manual?
May 18, 2009 | Lexmark C533DN InkJet Printer
Displays Error Code 1203 - What is that? User Manual is lost.
May 05, 2009 | Lexmark X7170 All-In-One InkJet Printer
I receive code 1203 after changeing cartridge
Try the following link - http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:0:0:0
1. Enter your printer model
2. On the following page under "Search the KnowledgeBase" enter the text "error 1203"
3. From the results select "Troubleshooting a 1203 Error Message on the Lexmark X5450/X5470"
4. Follow the directions there and see if it solves your issue.
If not, you may want to try calling Lexmark Customer support.
Apr 27, 2009 | Lexmark X5470 All-In-One InkJet Printer
My printer dont want to print
Apr 12, 2009 | Lexmark X5470 All-In-One InkJet Printer
Error #1203
Error #1203
A 1203 error message on the operator panel could indicate a problem with one of the ink cartridges. Please carry out the steps below the image to confirm that this is a cartridge failure rather than a hardware problem
  1. Make sure the All-In-One is powered on.
  6. Check the operator panel to see if the same error has returned or if a new message has appeared.
    7. Check the operator panel. If the 1203 error is displayed, this cartridge is the defective item.
Mar 03, 2008 | Lexmark F4270 Plain Paper Inkjet Fax
Error code 1203
To determine whether this error is due to a cartridge failure or a hardware problem with the printer, do the following: Make sure the printer is powered on. Open the printer's top cover. The print cartridge carrier moves and stops at the loading position. Press down on the cartridge lever to raise the cartridge lid. Remove the cartridges. With the cartridges out of the printer, close the top cover. Power the printer OFF and then back ON. Check the operator panel to see if the 1203 error has returned or if a new message is displayed. If the message displayed is 1203, there is something wrong with the printer hardware. Please contact Lexmark Technical Support. If the message is Cartridge Missing, reinstall the cartridges into the printer. Insert the black cartridge in the left carrier. Insert the color cartridge in the right carrier. Snap the lids closed. Close the top cover. Check the operator panel. If the 1203 message is still present, you need to insert one cartridge at a time to determine which cartridge is producing the failure. With one cartridge in the carrier, close the top cover and check the operator panel. If the 1203 message is displayed, that cartridge is producing the error. If Cartridge Missing is displayed, the second cartridge is the defective item. Please replace the defective cartridge.
Aug 20, 2007 | Lexmark P315 InkJet Photo Printer
Lexmark X5470 All-In-One InkJet Printer Logo
228 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
