Question about Fujitsu AMILO M-6500 Notebook
My laptop doesn't want to switch on. It almost seems like the battery is flat, but it is connected to the ac adapter and still doesn't work.
    Problem Solver:
  • 5 Answers
Dfghrh
Posted on Jul 18, 2009
My laptop Compac NX 7400 doesn't run when I connect it on AC sector with the battery removed. Even with battery nothing comes. What the problem ?
That sounds like you may need a new AC adapter. If you need help finding the right AC adapter, I can help you.
Apr 23, 2013 | Computers & Internet
Acer travelmate 8472 not switching on
Take out the battery and hook up the AC Adapter to it. Hook up the adapter to a working outlet. If the laptop still doesn't turn on then try another working AC Adapter. If the laptop doesn't turn on at this point then that means the motheboard is bad and would need to be replaced.
Feb 05, 2012 | Acer Computers & Internet
There's seems to be a short where the AC adapter goes into the Laptop. Loose parts in that area of the Laptop where the adapter goes in. It won't turn on. Maybe it's the battery.
Unfortunately, this is a frequent issue with laptops. Being moved around frequently can cause the AC Adapter to pull at the DC Jack on the laptop. If it is loose, it can mean there is a broken connection within the laptop. What you can try is powering the laptop on with it plugged in and the battery removed. If that doesn't work, I'd recommend going to your local Best Buy and picking up a universal AC Adapter. If that doesn't work, you can always return it, even if opened.
Aug 27, 2011 | Acer Aspire 5735 Notebook
I was using my laptop and it automatically powered down. I thought the battery was flat so plugged into the mains. When I switch on button nothing happens, there are no lights on. Green light on AC...
Hello.
The most common reasons are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter may be faulty and need replacement.
Or, unfortunately, your motherboard could be faulty.
Hope this helps.
Mar 18, 2011 | Computers & Internet
Ac adapter does not connect to battery
You either have a faulty ac adapter; a bad power supply in your laptop; a bad battery; or a blown LED indicator light.
1. If the connection is not loose when you plug in your ac adapter try letting the laptop charge for a while. (If you are using the correct ac adapter)
2. Try removing your battery and using the ac adapter. If this works the battery is bad.
3. Try a new ac adapter.
4. Power supply is bad
Jun 05, 2009 | Dell Inspiron E1505 Notebook
No power. Adapter light flashes when connected to laptop
thanks for using fixya!!
Please do and observe the following:
1. Uninstall the battery pack.
2. Then, connect the AC adapter, we will try to use the power coming from the AC, then turn on your laptop.
3. Observe what will happen.
4. If still doesn't work, install again the battery, then connect the AC adapter, check if its going to work.
5. If not, perhaps you have a problem neither with the battery or the AC adapter.
I suggest that you bring your laptop to a service center. Good luck!
pls rate me positively! thanks!
Mar 30, 2009 | Acer Aspire 3680 Laptop
My monitor goes black when it is connected to AC Adaptor.
Hi..there,
It's seems your AC Adapter are busted... Check to see if it still lite green on the AC Adapter. If not then you need to replaced a new AC Adapter.
Nov 01, 2008 | Fuji FP-988D 19" Flat Panel LCD Monitor
Power problems
If you have a spare ac adapter, try that just to check if it's the ac adapter.
When you power it on, are there any lights on the notebook?
If there are lights, it is indicating that the computer is receiving power but is not able to go through POST ( power on self test ) and normally it's the mainboard that has the problem.
Either way, if there's no lights, it is also the mainboard that is the main cause.
The notebook will have to be sent in for repairs or just replace the motherboard.
Oct 07, 2008 | Fujitsu AMILO M-6500 Notebook
Acer Travelmate C112TCi- Won't power on
Remove the adapter and the battery from the laptop.
Press the power button and hold it down for 20 seconds(without the battery or adapter plugged in to it). This process is called POWER DRAIN.
Now connect only the adapter and try to turn it on.
If it starts up, there is no problem with the adapter or the laptop.
If it doesn't, it can be either the adapter or the laptop.
You will have to check it with a different adapter to confirm which one is faulty.
The second case is that the computer powers on only with the adapter.
Then you can put the battery back in and try powering it up.
If it doesn't work, try connecting the adapter too.
If still it doesn't work, its a faulty battery.
Sometimes after doing a power drain, the computer will work fine.
If you have any more issues, feel free to contact me.
Aug 25, 2008 | Acer TravelMate C112TCi-SP2 Tablet PC
Fujitsu AMILO M-6500 Notebook Logo
140 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
