Question about New Home Sewing Machines
My New Home sewing machine model 541, when i set it to straight stitch the stitch is not straight- it is a kind of zig zag stitch.
RickE1
  • 202 Answers
SOURCE: Zig Zag Not working on my Bernina 830.
Basically it is a matter of a stuck part. Flip open the top by prying up on the front or ends of the lid. You already noticed the hinges on the back. When you get it open, exercise the right hand lever on top (marked ZZ at bottom and 1-20 at top. If you look just to the right of this lever against the back wall you will see that it moves a little part back and forth into triangle shaped grooves. The part is not going completely into the grooves so drop some oil in there and exercise it a few more times, using your fingers if necessary to make the part move into the triangle grooves at the front and back. After a while it will loosen up where it should operate by itself smoothly . Hope this helps.
Posted on Dec 12, 2008
  • 980 Answers
SOURCE: Skipping stitches while zig-zagging
If you have put a new needle in then the chances are the machine has gone out of time, you can either take it in to the repair shop or you can contact me and I will attach timing instructions drivewithken@blueyonder.co.uk
Posted on May 14, 2009
SOURCE: zip zag troubleshooting for Ero Pro Shark Model 384
how to thead the euro-pro 373
Posted on Jul 11, 2009
  • 980 Answers
SOURCE: how do you set the zig zag stitch on a Jones
Change the needle first it may be slightly bent, if you are sewing on fabric that creates static you will need a special needle, failing that you may need to retime the machine.
Posted on Sep 11, 2009
WonderTech
  • 268 Answers
SOURCE: Whenever I zig zag my machine skips stitches.
Try these solutions.
* Re-thread your needle
It may be threaded incorrectly (backwards).
* Reinsert your needle
Make sure it goes all the way into the holder and that it’s positioned correctly – usually with the
flat side away from the bobbin, but consult your machine’s manual to be sure.
*Change your needle
Your needle may be blunt, bent, or otherwise damaged.
*Your fabric may require a different needle. Generally, heavier fabrics require larger needles and
thinner fabrics, smaller needles. You may also need a larger needle if
you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for wovens (or a universal needle for either).
And make sure your needle is appropriate for the type of thread you’re using.
* Adjust the pressure of your pressure foot
It may be too light for your fabric.
* Change your thread
If your upper thread and bobbin threads are different types, try using the same thread for
both. And use a good quality, brand name thread.
* Adjust your thread tension
It may be too tight or too loose.
* Re-thread your machine
It may be threaded incorrectly.
* Change your needle plate
Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Important: If you change your needle plate, check to make sure your needle aligns perfectly with
this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which
could be dangerous. And make sure to change your needle plate back for zigzag and other wide
stitches.
I hope this helps you.
Posted on Sep 15, 2009
Testimonial: "great advice!"
My new Singer 4411 will not do zig zag or other stitches, just plain sewing
josephamoi Nov 17, 2017
When sewing ziz zag stitches the zig zag dial on your top right hand must be set any thing thing above 0. The setting is 0 to 6. Only on straight stitch this dial be set at zero.
Nov 15, 2017 | Singer Sewing Machines
How do I adjust the needle position for straight sewing?
The stitch Width selection regulates straight-stitch or zig-zag width. Needle position does not determine straight or zig-zag. Needle position just determines whether the needle's home position is center, left, or right. Needle position can be used with straight or zig-zag stitching.
Jul 03, 2016 | Sewing Machines
HOW DO YOU CHANGE THE STITCHING FROM STRAIGHT TO ZIGZAG
Check that your sewing machine is even capable of zig-zag. Some machines are straight-stitch only.
Consult your owner's manual.
If your machine can do zig-zag, somewhere there is a dial or setting called "stitch width" that will determine how wide the zig-zag will be.
May 21, 2016 | Sewing Machines
Why won't my zig-zag zig zag?
Check your stitch width setting if its too low it will just straight stitch.
Jan 21, 2015 | Sewing Machines
White sewing machine won't stop the zig zag stitch
my suggestion is take the machine in to a sewing machine shop
to be check to see if something inside is broken or come loose
knowing the machine is in good working order gives peace of mind
instead of wanting to through it out the window
and get a instruction manual
Go to the singer website for a free pdf manual
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example w265) & click search
Jul 24, 2012 | Sewing Machines
Trouble sewing lycra fabric using a zig zag stitch
You have the machine set for blind hem stitching. Change the stitch selector to stretch stitch, which is a single, in line stitching zig zag stitch.
Cheers,
Embroidery Services
San Diego, CA
Sep 13, 2017 | Sewing Machines
Will only sew zig zag, even though the dial shows it on straight line.
Check the stitch width dial and see if your model requires the setting be at zero for a straight stitch.
Mar 13, 2010 | New Home Sewing Machines
Only does zig zag stitches, no straight stitches,
make sure the pattern selector is set for straight stitch first. If it is set correct then the machine may be "stuck" is zig zag mode. May need to be de greased and then re lubricated.
Jul 26, 2009 | Necchi Sewing Machines
Sewing Machines Logo
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
Nava Hirshenson
Nava Hirshenson
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
