Ryobi 40-Volt Lithium-Ion Cordless String Trimmer Logo
b
brian d Posted on Aug 08, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ryobi 40v trimmer stops working with 1/2 charge left on battery
My Ryobi 40v trimmer is no longer working as long as it used to. It starts dying with 2 and sometimes 3 of the 4 lights still lit. It charges fine, no red lights on the charger. When it's done, the charger light is solid green and all 4 lights on the battery indicate. Is there any maintenance or reset I can do?
bigdawg7299
Level 3:
  • Master 2,559 Answers
  • Posted on Aug 08, 2016
bigdawg7299
Master
Level 3:
Answers
2559
Questions
0
Helped
556363
Points
7776
Battery is weak. Those lights are really useless...more a marketing gimmick. It almost sounds like it developed a memory...this happens when certain types of batteries are not fully discharged before being placed on the charger. Replace the battery and make sure to follow charging directions for that particular type of battery
Testimonial: "I did follow the charging recommendations: took it off the charger after full charge, etc. It is 3 years + 2 months old and the Ryobi warranty is 3 years. :( I'm taking it to an authorized Ryobi support center and he says he will see what he can do but he is 3 weeks backed up on them."
Ryobi RY40002 String Trimmer motor runs slowly and rough
Question edited to add FULL make model (what it is).
Category moved from Washing Machines to Ryobi Trimmer.
Replace the spark plug. Strip and clean the carburetor. Replace the fuel with fresh. But hang on though, the RY40002 is electric and runs with a 40 volt battery, so no spark plug and carburetor! :>D Replace the battery, lubricate everything from the motor to the head. Check the motor with nothing attached to it. The carbon brushes may need replacing or its bearings need greasing.
Ryobi RY40002 40V Power Head and RY15523A Expand-It ...
https://www.walmart.com > ... > All Trimmers and Edgers
Includes (1) RY40002 40V Power Head and (1) RY15523A Expand-It Trimmer Attachment · Compatible with All Ryobi 40V Lithium-Ion Batteries (Sold Separately) ...
US$119.90 · ‎Out of stock
I bought the Ryobi 15 in cordless weedeater today. I charged the battery. Now I can't figure out how to get the battery back off the weedeater to store it. Can you help? Instructions not helpful.
Do you mean the Ryobi 40V X-head cordless string trimmer? This model has a 12-15" cutting width. For the 40V battery, you remove it by pressing and holding the latch button at the bottom of the battery (on the side closest to you). Then pull the battery out of the power head, exactly reversing how you slid it into place. Do not release the latch button until the battery slide free of the tool. The latch is usually stiff and takes a lot of force to hold down. See Fig 4 for the position of the latch in the manual: https://images.homedepot-static.com/catalog/pdfimages/fa/fab7f50b-d65b-40de-9e1c-5fecce2436f5.pdf . The same directions apply to removing the battery from the Ryobi 40V string trimmer with the fixed head.
For the 18V batteries, there are two latches, one on each side of the battery. Press and hold again. These are so stiff that my mother and I often need someone else take off the battery from any of the Ryobi tools. (We're both about 5' tall and 100 pounds. The tools aren't designed for our proportions.)
I hope this helps.
2helpful
Ryobi 40V 2.6A battery. When I put it on the charger the charger blinks green for about 10 minutes and then goes to solid green. However, after 5 minutes of use my Ryobi trimmer dies. I repeat the...
From your description the battery is probably faulty. If the batteries are still quite young it is possibly just one cell and while Ryobi don't refurbish batteries there are companies dotted around that do.
If it is a nicad battery, Ryobi told me just a couple of days ago they no longer supply nicad replacements and expect everyone to upgrade to lithium, which means also buying a charger.
1helpful
Ryobi 40022 trimmer (40v lithium battery) has completely stopped working. Battery and charger kept inside when not in use. Battery indicates that it is fully charged when in the charger. Any ideas?
Sounds like a bad charger my friend..test suposly charged battery with a multimeter and you will find your answer...can also test charging unit with it too...GL
Fuel mixture ratio for Ryobi SS300 weed eater
Are you sure about the model number? I see several 30CC engine string trimmers by Ryobi. Two are the Ryobi RY30040B (SS30) and a RY30544 (SS30).
For both of these models, mix a high quality 2-cycle engine oil at 2.6 oz. per gallon of gasoline to pour into the gas tank. This ratio is used in several other Ryobi string trimmer models. Many Ryobi product manuals are available here: https://www.ryobitools.com/power-tools/support/manuals . Most Ryobi gas powered and 40V battery-powered tools will have a model number that starts with RY. The 18 V battery powered models often start with a P.
I hope this helps. If you add a comment with the actual model number, I may be able to provide more information.
Top Ryobi Garden Experts
Jay Finke
Jay Finke
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
