Question about Kingston Kpex100 Digital Media Player
K-pex 100 does not enter usb mode
If I plug in my usb connector to my k-pex 100 mp3 player, the device goes into charging mode and does not go into usb mode. Repeated attempts don't solve the problem, and neither do repeated attempts to reset it. It seems like once in a very rare while I can get it to connect and then transfer files.
4 Suggested Answers
lukem9962
  • 144 Answers
SOURCE: K-PEX 100 2GB not recognized by computer
try reinstalling the driver from the other solution or got to kinstons website and update the firmaware
try installing windoes xp service pack 3 if not allreadyinstalled
Posted on Jul 24, 2009
  • 14 Answers
SOURCE: Kingston K-PEX 100 2GB not recognized by computer! HELP!
you can try other usb cable or if you have multi tester check all the line if all is ok.
i have check the lines with the help of this thread
http://www.fixya.com/support/t2808851-kingston_kpex_100_need_usb_cable
be sure that the black line is connected to ground,or you'll get charging only.
just solve one today by connecting theblack wire to grouind...
Posted on Feb 19, 2010
bobhifi
  • 635 Answers
SOURCE: Where/how did you find the USB connector for the
Its a mini USB connector under a removable rubber cap.
Posted on Mar 07, 2011
Where/how did you find the USB connector for the K-PEX?
Mar 07, 2011 | Kingston Kpex100 Digital Media Player
I dont how charge battery on my mp3 player
Some things to check for when your player does not act like its taking a charge. USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player. Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player. USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems). USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device. Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery. Latest firmware Depending on what player you have, make sure it's up to date with the latest firmware. AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port.
Dec 25, 2010 | Audio Players & Recorders
How dont know how to charge my mp3 player
Dec 25, 2010 | Philips GoGear Flash MP3 Player
The battery is not charging
You can try and reset the player. resetting a Clip player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Latest firmware Depending on what Sansa player you have, make sure it's up to date with the latest firmware.
I have some tips posted here on MP3 players and their problems. Connection problems MP3 player not found by computer
SanDisk Mp3 Player Frozen
Dec 25, 2010 | SanDisk Sansa Clip MP3 Player
My fuse wont charge at all. i bought a new charger and still get no charge
USB Port 2.0
USB Port location
Battery
Latest firmware
Depending on what Sansa player you have, make sure it's up to date with the latest Firmware.
AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port. These accessories are available at SanDisk web site.
Dec 04, 2010 | SanDisk Sansa Fuse MP3 Player
Does not charge
Below are some things to check for when your Sansa player does not charge..
USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player. Also try ports on the back of your computer, these ports have more available power. Some computers have limited power to charge up the device...
AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port. These accessories are available on our online store.
Jun 08, 2010 | SanDisk Sansa Fuse MP3 Player
I plug up my mp3 to the computer to charge. It
Maybe your battery is already weakening. Try a new batter and see how it goes.
Jun 21, 2009 | Philips SA5125/37 MP3 Player
My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
USB Port 2.0
Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
I hope this helps, and don't forget to rate the answer.
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
When i connect my sansa clip 2gb it will not charge. it say connected and then goes off. I thought it was charging but when i checked it the battery had died what do you suggest i do to get it working...
Check for the following:
USB Cable
Make sure the computer isn’t entering hibernate or sleep mode while the device is connected.  The computer must be on in order to charge your player.
USB Port 2.0
Make sure the player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Battery
Latest firmware
Jan 23, 2009 | SanDisk Sansa e250 MP3 Player
there's a small hole where you can insert a needle size pin or any thing that will fit there to reset it. you can try this first.
Jan 22, 2009 | Kingston Kpex100 Digital Media Player
Kingston Kpex100 Digital Media Player Logo
145 people viewed this question
Top Kingston Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Kingston Audio Player and Recorder Expert? Answer questions, earn points and help others
