Question about Sharp Aqous LC-26D5U Television
No signal: E 202
I have bought a new Pioneer KRL 32V TV. Trying to install it, I got the message: no signal: error 2002
Canon image class all in one 4412 printer error code e-202-2002
Same problem on an older LC-C3742U SHARP AQUOS. Other tv in my house receives ch 4.1 at the same cable spot and bad tv will not receive this ch in the good tv's spot so I know it is the tv. It receives all other channels well just not 4.1 which shows E202.... Tried your reset protocol but it merely started the tv and held the channel it was last set on.
For more help visit cbr tech solutions
Apr 20, 2014 | Office Equipment & Supplies
Failed search for TV Channel Pioneer KRL37 - error code 202
Could be a system corrupted error. This might need attention by a qualified service technician.
Jul 15, 2012 | Televison & Video
Pioneer KRL-37V manual
Hi my HDMI is not connecting to my tv any more it says there is an incompatible video signal being received, something along those lines. please help!!
Oct 20, 2011 | Pioneer Kuro KRL-32V 32 in. LCD TV
No hdmi funktion to my new LED TV.
Most likely the output from the Pioneer is not compatible with the TV.
Try resetting the output by holding Stop (on the pioneers front) and press the Open/close button. This will reset the output signal. Also, if the harddrive in the Pioneer is defect, the HDMI signal will not output.
Jan 12, 2010 | Pioneer DVR-550HS HDD Recorder
Problems with Sharp Blu Ray Player "copy protected signal"
Possible solution: You set up your remote to run your amp from the TV control, using the AQUOS Link. Even though your amp is out of the loop, it's still recognized by the TV. You might have to reset the TV back to default and run the AQUOS Link again.
Apr 19, 2009 | Pioneer VSX-D514 Receiver
Can't use menu function on remote control for pioneer krl-32v TV
ok try this first, remove the batteries from the remote and yes make sure you replace them with brand new ones, but before you do that unplug the tv from it's power source and let it sit for a couple minutes at least 3, then plug it back in , put the batteries back in the remote and see if you have everything back, if not I would return everything since you said you had just purchased this set, or contact the makers web site and see if they will provide a new remote since taking the tv back is a real pain.
Mar 14, 2009 | Electronics - Others
Pioneer DVR-540HX DVD recorder Error message 'REPAIRING HDD'
Greeting, I have same problem too, and now recorder is in warranty service. HDD sucks. This recorder is piece of ****. HHD is noisy and poor quality.
Stay in peace
Nov 17, 2007 | Pioneer DVR-540HX DVD Recorder/HDD...
Sharp Aqous LC-26D5U Television Logo
274 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
