I believe the board is gone on my a/c unit.what do
I believe the main board is gone on my a/c unit.what do they cost and where can i get one
  • 614 Answers
You can order the board online. Just get the model and serial of the unit and possibly the board. Cost anywhere from 15 to 80 dollars. RUSS
Posted on Jul 18, 2009
WMG30GS Whirlpool microwave display
please follow this steps and fix it. God bless you
  1. Main control board If the display on your microwave has gone out completely this is usually a sign that it is a malfunctioned main control board. To correct the issue the main control board would need to be replaced.
  2. Display board A display board can either malfunction completely or partially, causing two separate results. If the display on the unit has completely gone out, this can be attributed to either a bad main control board or display board. On the other hand, if the display has only partially gone out, this is usually a sign that the display board is defective and will need to be replaced
Nov 27, 2013 | Microwave Ovens
Miele vacuum s5980 no power
your main circuit board is also your speed control the motor should not have a circuit board i don't believe. open your machine up all the way to the motor and cord reel. check voltage at cord reel should be 120 +/- 10. if voltage is correct then replace speed control board.
Feb 12, 2013 | Miele S 5980 + SEB 217 Bagged Canister...
Light for water dispenser is on and flap keeps opening and closing. No Water, just flapping sound and sound like motor running. Can only be stopped by cutting power to unit. How to fix??????
you have a bad main control board. ( called the jazz board .. ) it will have to be leplace to correct problem .. mm hope this helps feed back pls ..
Jul 10, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Can send faxes but not receiving, comes thru blank piece of paper
What about copies or internal prints?
If even a copy doesn't work then it sounds like your LASER unit has gone out, in which case I'd just replace the machine.
If the internal pages or copies come out but not faxes, and you know the sender is sending correctly, then it could be an issue with the main board.
I'd get a second opinion from a service tech locally but I can at least give you the part numbers for both so you have an idea of the cost of parts.
LASER UNIT
LM4578001
MAIN BOARD
LG6141001
Jun 13, 2011 | Brother IntelliFax-2820 Laser Fax
I have a Samsung LN-T1953H TV and the sound suddenly stopped working. We were watching a DVD and suddenly no sound. The TV picture still works fine but there is no sound. on any of the connections or...
It sounds like the main board has gone out. The only audio components are the main board, wiring and speakers. Since audio is missing from external speakers as well, that tells you that the main board is at fault. The cost of the board could be from $150.00 to almost $300.00 depending on the version # of your unit and dealer mark up. You can call 1-800-samsung for nearest service center.
Mar 18, 2010 | Samsung LN-T1953H 19 in. LCD HDTV
GE model PDS22MFSAWW, clicking as if the unit is turning on and off? The digit temperature lights are gone, but fridge is running okay?
Due to the digital temp lights no showing , this is a sign of the main control board bad . The clicking from behind the refrig , clarrifies this . Replaceing the main control board , behind the refrig , behind the small 8 " X 10 " panel , will solve both problems . The part # WR55X10942 .
Dec 14, 2009 | GE Refrigerators
Casio ex-z75
Hello, we are in Australia and the cost of the repair is very expensive due to the part cost.
Depending exactly what Casio you have will determin weather it is a main board issue or something else (may be alot cheaper) but starting costs for main board replacments are $180 AUD upwards.
Nov 12, 2008 | Casio Exilim EX-Z750 Digital Camera
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
