It could be worn. What parts will fix this. Thanks for any knowledge provided
Go to the power panel of your home and locate the circuit breaker for the oven. Turn this breaker on and off several times then check the oven controls. If this restores normal operation, then I would replace the breaker. If the breaker trips instantly every time you try to reset it then suspect the heating element and the thermostat. When a heating element shorts, it can ruin the contacts inside the thermostat.
Testimonial: "Thank you so much for your assistance. Tried it but nothing changed. Still can't get the display to work. Clock is on but can't be reset."
