Question about Mitsubishi VS-5043 50" Rear Projection Television
Mitsubishi VS-5062 My picture is scolling about 90% of the time. Any suggestions?
  • Anonymous Dec 20, 2007
    Our screen has horizontal lines all of the time now that move up then down
    President:
  • 4,402 Answers
This is a VZ3 chassisMitsubishi VS-5062 - 1.gif....notorious for cracked solder connections on the yoke plugs. Look at each yoke on the 3 CRT necks , you'll see a Molex plug on each yoke. The top two connections are for the vertical winding. There is a plastic tab that hinders easy soldering of these....carefully clip it off with a good pair of ****. You can then access the top 2 solder connections. Resolder these and also resolder the vertical output IC401. This should take care of the problem.
Posted on Dec 21, 2007
Mitsubishi has a problem
Ur Horizontal/Vertical ic stablizer is dead or it supporting componnents.90% is ur IC.
Aug 25, 2009 | Mitsubishi VS-5043 50" Rear Projection...
Vertical lines that scoll the screen picture.
Ok this problem is coming from either your tv sets vertical circuit or the tuner itself is faulty, most likely the problem is coming from your vertical circuit with bad solder on the vertical ic or you have a faulty capacitor which can also cause this problem what i would suggest unless you have electronic experience on troubleshooting electronic components is to take it to near by tv repair shop and have then troubleshoot this circuit to see which component is giving you this problem, thank you,hope this helps.
Aug 11, 2009 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi VS-5004R No Picture and No Audio
not enough power, you may need to rebuilt or replaced the power board
Mar 31, 2009 | Mitsubishi VS-50605 50" Rear Projection...
VS-50609 no picture no sound
Seems to be the power button is stuck on the tv itself
Jun 24, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi big screen tv model vs-5062
HEY DOG-UNLESS YOU ARE GOOD W/VOLTMETERS THIS TYPE FAILURE ON THIS MODEL TV CAN BE VERY DIFFICULT.THE BEST ADVICE I CAN GIVE IS CALL A TV TECH EXPERIENCED W/MITSUBUSHI TVS AND GET AN ESTIMATE.
Nov 14, 2007 | Pioneer PRO-200 60" Rear Projection...
No picture
Do the self test first ctechnicians.com
Nov 08, 2007 | Mitsubishi VS-45607 45" Rear Projection...
MITSUBISHI VS-4543
PVAT!!Look for bad connects--start w/easy first. Power supply,then vertical IC pins,then regulators.Take your time,be thorough.
Oct 01, 2007 | Mitsubishi VS-4543 45" TV
Mitsubishi VS-60705 - picture flutters vertically and horizontally
This sounds like one of the 9 volt regulators on the small signal board is going bad, supplying less than 8 volts. I have seen this is several of those sets. The IC needs to be replaced and if you do not have experience in servicing projection TV's then I suggest letting a qualified tech handle it for you.
Jul 09, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Televison & Video Logo
254 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
