Question about Makita 12 Volt Cordless Drill/Driver Kit
18v makita bhp451 cordless hammer drill.clutch slipping
Its prob stuck between gears one and two try a little wd40 on the gear selector switch
Posted on Jul 31, 2009
Makita dril 18v stopped working
check switch it may have over heated and burned out
Oct 22, 2012 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
My chuck is broke , on my 18v makita cordless drill , how do i fix it
Put the chuck key on and strike it with a hammer counter clockwise. the chuck key must be properly seated in the hole. Once the chuck is brokrn free, you can unscrew it my hand. Buy a new chuck an screw it in olace and againm strike the key but no as hard clockwise. It will self tighten more as it is used, Good Luck-Ned-
Sep 17, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
3rd gear slips AGAIN!
A gear needs replacement.
Most likely the speed change ring.
It's a known defect on these drills.
Jul 05, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita cordless driver drill model-6347d. ni-mh rechargeable nickel metal hydride battery 1834 18v 2.6ah will not stay charged. battery charter dc 1804- works great.
You say will not stay charged? Over what time period? Are you aware Nicad and NiMh rechargeables discharge naturally at 1% per day so where does that leave your power tool after 3 months? Furthermore they only have around 1000 charges in their useful life so you can immediately see how these tools are not for intermittent(ie handyman) use.
Mar 03, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
How do i re-assemble a makita 18v cordless drill
check out ereplacementparts.com and type in your model eg bhp451 they should have an exploded diagram.
Dec 21, 2008 | Makita 12 Volt Cordless Drill/Driver Kit
Makita BHP451 Question
Buy a hitachi li-ion 18 volt ds18dl.
All parts are repairable & replacebable should they breakdown. Ie gearbox.
Gearbox parts are not available on makita , only whole gearboix which can be expensive.
Cheers
Laurie
Aug 27, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
My Makita handrill is not working. It's just like loose,and the drill is not rotating anymore.
Your bearings in the Clutch have fallen out of place.
Basically the tension screws pulling the clutch against the body.
Have became loose. If you Tighten them most likely wont fix it.
You should contact Makita. If you do open the drill. The Clutch assembly will be a task to reassemble. And the warranty might be voided.
Aug 17, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita 8444d mxt drill
what is the setting in your clutch. if you set the clutch to the highest setting and it`s still slipping then you need transmission assy.
May 28, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Chuck change
After removing the screw and inserting the allen wrench shift the drill to the LOW position and turn the clutch to the drill only position. Use an allen wrench about the size of the chuck capacity so that it will not flex when hitting it with a mallet. Sometimes they are stubborn because of the torque but this should work. Put the allen wrench at about a 30deg angle and hit the wrench. I support the chuck on a workbench or a block of wood will do fine. The chuck has standard threads.
May 10, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita 650watt corded drill
tap the 3 jaw with hammer not too hard. then the sleeve clockwise
Nov 24, 2007 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita 12 Volt Cordless Drill/Driver Kit Logo
1,004 people viewed this question
Top Makita Drills Experts
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
